Finally - A Quick Cheap Natural and Legal Cure for Cancer
Started by Cap-Z-ro, May 06, 2010, 06:27:10 AM
Tito L. Oracion
Quote from: Bob Smith on May 08, 2010, 08:07:35 AM
Alkalyzing the body thru an alkaline, raw plant-based (grain-free) diet is the most powerful way to reverse cancer. Drinking water with lemon juice squeezed into it also helps alkalyze the body.  An alkalyzed body becomes extremely efficient at carrying oxygen. Cancer cannot survive in an oxygenated environment.  A plant-based raw food diet will also reverse type II diabetes, according to doctors here http://www.rawfor30days.com/RawFor30/ReverseDiabetes.html
B
Ya, i second demotion. gooooood   ;D
TheOne
B
I am Type 1 unfortunately :(
TheOne
Costco have HTC product with 65% Calcium Hypochlorite.
I was reading the caution from the box, its was scary. but here the cote from the link posted from this thread
QuoteGood luck in using MMS2. Don't let the terrifying cautions on the pouch of Calcium Hypochlorite scare you away. I've tested it for years. If you voluntarily and privately prepare MMS2 as suggested here (in size zero capsules only), it's both safe and beneficial - a chemical produced and needed by your own body in limited quantities. Be sure to drink ample water if you experiment with this discovery. I take it myself quite often as a maintenance-preventative strateg
So next time i go to costco I will by the 4kg box for 25$ CAN
Where we can buy empty size zero capsule?
Cap-Z-ro
When reading the MMS 2 protocol it was stressed to make sure to use calcium HC...and not sodium HC.
I 'assumed' the soduum type was toxic...it is not.
It is MMS 1...it heals other ailments.
I made the necessary thread modifications above to correct the misinformation.
Regards...
lwh
Quote from: Cap-Z-ro on May 12, 2010, 09:34:43 PM
Regards...
Sorry Cap, that's not correct.  MMS1 is a sodium chlorite and water mix, not sodium hypochlorite (commonly known as bleach).  And as far as I understand it, taking the sodium chlorite solution on its own, without combining it with five parts citric acid, would also be harmful (although it can be used as a water purifier).
