Does Anyone Know What's Happened to Dr. Timothy Thrapp & Co?
Started by Bob Smith, May 08, 2010, 10:22:49 AM
Bob Smith
I couldn't find Dr. Timothy Thrapp's affiliated www.witts.ws website - seems a 404.  The Youtube account his vids were first displayed on is also no longer available. Any thoughts?
B
NTesla
WITTS sent me this message:
"Website
having technical issues. give our volunteers a few weeks to fix it
thx!"
See this thread for more info: http://www.overunity.com/index.php?topic=9134.0
gyulasun
Yes, but a website maintenance or any technical issue has got Nothing to do with a fully independent youtube video store,  why they took their videos down then?
quarktoo
"Dr. Thrapp"?  :D Gee last time I checked he was "Sir Timothy Trapp" and prior to that he was an inmate with Arizona State Corrections doing time on fraud charges.
In regard to the hot water heater, the technology is real (unlike Thrapp and his merry band or retarded con artists) and even Tesla stated this when Tesla said "with the round form, all things become possible."
Why does it work? Because the chamber is isotropic meaning it resonates equally from all directions. This compresses the water in the center when it is at resonance. This compression causes the universe to push back at the speed and pressure of the universe when the electron orbit gets too close to the proton center. (speed of light) This sonofusion then results in fission known as electron cascade effect and that is why there is a "electron blue" glow in the center of the tank. (see water glow experiment)
The technology was offered for sale in China for a short time but was suppressed.
If you really think that Thrapp is going to build a factory or tell you how to make it you are a fool. The device is so simple that if you need help building it, you need to find a new hobby. Most likely Thrapp was busted and is now paying his dues to the man by gathering names of free energy inventors and ripping them off to weaken them in the process.
Thrapps tank held approx. 1.8 gals of water. If you do the math using the speed of sound through water, you can calculate that his piezo was operating at around 2500 hz which is a common off the shelf resonant frequency for piezo material.
You don't need the center piezo sensor in the tank, it can be replaced with another piezo on the other side and a micro-controller can do the math on the frequency. You will need to adjust the frequency as the water heats or salinity changes since that affects the speed of sound through water so the micro-controller is useful anyway..
It is without a doubt one of the easiest free energy devices to build once you build the tank and have the piezo manufactured. Personally, I would size the tank around an off the shelf piezo that has the focal point that is close to what you need for that tank size. You can obtain immersible piezo transducers up to 900 degrees F.
Here are three rules to understanding free energy devices:
1. All free energy devices convert mass into the atomic energy contained within the mass, not the chemical energy. The energy is free since only the universe is capable of compressing the energy into mass and it takes very little energy to cause it to convert back. I.e., I can convert the chemical energy stored in a forest of trees with a single spark.
2. All free energy devices use acceleration to accomplish that conversion.
3. There are many ways to produce acceleration, vacuum, magnetic compression centrifugal force, ect. can all be used to produce acceleration. Understand the different methods of compression and you understand how they all work.
If a free energy device is real, you will be able to spot the acceleration device. I.e., notice that Don Smith always used silver coated wire on his devices shown on youtube? Watch the youtube videos about E.V. Gray and notice how he states the use of silver wire?
That clueless punk from energetic forum had the balls to tell me how I should stick to something I know and how he knows so much about EV Gray while he uses copper wire and has no clue how any of these devices work. I know how most of them work and they all basically work the same at a core level.
I also laid out the big secret to Meyer on another thread, you can read it here: http://www.overunity.com/index.php?topic=9104.msg240889#msg240889
EDIT  One last note - Einstein was most likely working for J.P.Morgan. Einstein changed Maxwell's E=M into E-MC2 which is wrong - Maxwell had it right. Mass to atomic energy conversion = MC2 and E=M.
The atomic energy contained within the mass is something along the line of 10 to the 23 power the mass. So 1 gram of hydrogen can produce 1 gram of force but when converted into atomic energy can produce 1,000,000,000,000,000,000,000,000 of force. There may also be an exponent which is the number of protons but don't quote me on that.
Bottom line, that is how all free energy devices work and it does not violate thermodynamics when you use the atomic energy to calculate it instead of the chemical energy. That is how they trick students in school into thinking they are impossible.
ZeroFossilFuel
If you want a good wrap up of witts, and maybe a chuckle or two, check out my video #228
http://www.youtube.com/watch?v=I5q-pQy2uXA
Cheers!
Z
My public PGP key. Please help support my work. Donate by PayPal
