cop > 1
Started by Inquorate, May 09, 2010, 05:42:08 PM
guruji
Hi Groundloop about that circuit is it ok on the upper wire that one is positive and on the other end is negative?
Groundloop
@guruji,
The circuit output side is a direct copy of the circuit drawing you posted.
Groundloop.
gyulasun
Quote from: guruji on May 13, 2010, 06:54:20 AM
Probably he means in Reply#33 in the schematics the upper right hand side connection symbol has a green color, just like the negative connection symbol on the lower left side.  And the same wire from the upper right hand connection point goes to the upper left connection point which is clored as red,  his problem is the same piece of wire has differing polarity symbols at its ends....
Guruji,  it is green because of the OUTPUT point of view that is all, ok?
With respect to the INPUT the upper wire from red to green is fully positive, ok?
Gyula
Groundloop
@gyulasun,
Yes, you are correct.
Groundloop.
guruji
Hi Groundloop and Gyulasun thanks for help. Groundloop that circuit worked fine thanks. How can I hook multicoil with it?;the same as bedini coils in his circuit?.
Thanks again.
