This device is the real self-running overunity?
Started by Arthurs, May 17, 2010, 03:45:15 PM
Arthurs
Hello everyone:
Occasionally found in You Tube.
Inventor----I ,Wendell Ray Walker, am the sole inventor of the electric generator which, not only, produces enough electricity to run itself, but, produces extra electricity as well, I apologize for any confusion that may have been caused in this video. This is the end result of 25 years of work and this video was filmed after an exhausting day's effort to finally reduce it to practice.
Video Links:
http://www.youtube.com/watch?v=etFCzIe-D2Y&feature=channel
http://www.youtube.com/watch?v=mhEUD4kdjrY&feature=channel
http://www.youtube.com/watch?v=_9ktD7kAI7Y&feature=channel
http://www.youtube.com/watch?v=P_EK07Nv8E8&feature=channel
True? Or false?
A replication of success? If true, perhaps true to cause confusion???
Xu Yuan
gauschor
A replication should be possible very easy, as you see there is nothing complicated to it. He claims he has overcome Lenz Law by using the disc shaped magnet which can rotate freely and that the Back EMF from the coil can be avoided because the magnet can simply rotate away. Btw. the magnet is magnetized back/tail and not top bottom (I guess this is important for replication).
I think it should be investigated further...
Arthurs
Hello everyone:
I'm ready to Replication, However, structural details have not yet fully understand, Does not seem simple.
Xu Yuan
gauschor
These are only magnet bearings. However you don't really need them and can use other good ball bearings instead. The whole point of this device is, that the magnetic discs can rotate freely and easily in order to evade Back EMF. The inventor suggests one can use more than 2 magnets/coil e.g. the same arrangement crosswise as well: the more the greater the power.
The current induced into the coils is an alternating current. He shows in one of the clips a sketch in which he leads this AC into a rectifier each one (he uses simple diodes for that). He smoothes it out with a capacitor and there is the power output -at least that's the way I interpreted it. Sounds logical though...
Arthurs
Hi Gauschor:
Thanks Reply, Do you think that the correct polarity of the magnet is in the image (A) or (B) ?
Xu Yuan
