This device is the real self-running overunity?
Started by Arthurs, May 17, 2010, 03:45:15 PM
zapjosh
Quote from: Airstriker on May 22, 2010, 01:11:00 PM
Who has replicated this so far ? I haven't seen anybody.
  I have replicated it!! Look at TheRealdealinlife on youtube.
gyulasun
Quote from: zapjosh on April 15, 2011, 03:12:56 PM
Hi zapjosh,
I have seen your video here http://www.youtube.com/watch?v=V6gaN8gRs5A  and I guess it is Wendell's setup which was serving as the "sample" after which you built this present setup.
It would be very good if you made input power and output power measurements. You mentioned the regulated power supply for driving the input motor so measuring the average DC input current at the DC output voltage coming out from the supply when the motor is running would give the input power WHEN you apply a load for both output coils.
Regarding the output power measurement it would be better to rectify the AC output from your coils and smooth it with a puffer capacitor, this way you could also measure the DC output current a power resistor draws from the capacitor. The DC voltage across this capacitor multiplied by the measured load current taken by the load resistor would give the output power so it could be compared to the input power.
Could you show a closeup picture from your rotor where the rotating magnets are fixed? It cannot be seen clearly in your video because it "always" turns.  By the way if you start your rotor from a total standstill, by giving the main rotor a small push as in the video, how the small rotors with the magnets on them start also rotating?
Thanks,  Gyula
zapjosh
I have some what read throught the hole thread and I know the hole story about Wendell.
I would like you to know I will try to do anything I can to help all of you out there.
    For one, I am upload a video right now about the generator And It has some  measurements in it. And I will try to do anther video about what you explanded In one of your 2 paragraph. And I know you are all trying to build one but it is a pan in the but to Build. It looks like a child's toy but it is not, There is more then that. And the magnet do not start spining until the coil are underload.
zapjosh
gauschor
Ah, this topic is still alive. Very nice replication of Wendells build.
Unfortunately I am missing the most important thing: the device shows no sign of being a selfrunner or overunity, it's just generating power while on the same time drawing more power from the grid. As soon as the source power is cut off, the machine is dead. Therefore I wonder what really is the special effect. Please correct me if I'm wrong.
edit: have you tried to feedback the power from the 2 other coils to the motor or is the power too weak?
