This device is the real self-running overunity?
Started by Arthurs, May 17, 2010, 03:45:15 PM
gyulasun
Hi gauschor,
Well, lots of text as the 'answer' but little or no fact on his setup. I think if he could be politely asked to make a new video when his output coils feed the upper electric motor and he starts it by speeding the rotor up by hand, no input battery and then show it self runs without decelerating, this would be the best proof, and ask him to make the video for 10 minutes what youtube limits.  Maybe a 10 minute long youtube video is still not convincing?  possibly will not slow down to a full stop if it happens to decelerate but probably some members here could analyze his video by certain methods as for instance in Mylow's case... whether the rotor keeps its speed or accelerates or decelerates.
And of course tests are needed to do by those members who can build his setup.
Thanks,  Gyula
Sprocket
Yikes, after reading Mr. Walker's email, I'm even more confused! ???
I forgot to mention that as most seem to contend, my rotor magnets do not 'appear' to spin - not at low speeds anyway, and as Scotty1 noted, the magnets will start to rotate when the rotor is braked, confusing things further...
There are too many unknowns that Mr. Walker could easily answer;
1: are both rotor magnets orientated the same way?
2: the make-up of his coil, is it air-core, what gauge wire, turns etc.?
3: the all-important 'magnetic-bearings, a break-down on how exactly he makes them?
4: rpm's, what's the minimum speed for the 'effect' to manifests?
5: current measurement of motor when in self-runner mode?
It's very hard see how his one coil could provide the hundreds of milli-amps of current needed to power the motor - unless it's not 'conventional' current being produced, or else the there is some kind of coil-magnet 'kick' interaction taking place.  Motor current usage when self-running would clarify things...
gauschor
I can understand your points, for I am also not a 100% clear. I believe he wrote this mail first so that we have a "base" to build upon, and now is the time for precise questions. I will write a new email today/tomorrow and bring these additional questions to attention  :)
scotty1
Hi all.
I also have trouble with the letter?
When the magnet approaches the coil the coil wants to repel the magnet field...ok...but when the magnet is directly under the coil, then the coil is at zero voltage! And if there was an iron core the core would be attracted to the magnet at that time. Then as soon as the magnet begins to leave the coil in any way the current is reversed instantly....there is no stopping it.
So if we cancel out other forces with wings ect, the magnets would still be able to vibrate.
Let's say they don't vibrate but move up and down smootly......if on the approach the coil pushes down on the magnet it will change the field strength in the coil and the coil will change, now the magnet can come back up but as soon as it does the coil changes again. The magnet exits and the coil changes again!
From the letter,
Then when the magnet is  emerging on the other side of the coil unlike a magnet that would repel  it on onside and then pull it back on the other side with equal force,  it is also repelled on that side, too.  ???
I just don't see it.
I think a scope would show multiple current reversals relating to magnet vibration.
Scotty.
overyounity
Hello,
I just discovered this thread last night and am a bit concerned about some of
the replies I have read. Let us remember our history. Nikola Tesla never divulged the secret of his box that powered a vehicle for many days without charging because someone ridiculed his genius. This inventor, Wendell Ray Walker, is graciously giving us all something new to discover. He has stated that this deal looks easy to build but is actually not that easy at all.
I applaud the efforts of the individuals that will try and get the man some equipment so that we may all understand better what the equipment tells us.  Keep in mind though that equipment does not yet exist for devices such as Walters.  The readings can only give indications.  Listen carefully to everything Walter says as he will let us know how this deal works... Patience and experimentation is what is needed.  Now if only I had some of them magnets that spin like Walters...  Maybe another delve into the world of Ed Leedskalnin will help me understand them and lead me to how I can make me some of those there  magnets of Walters.
Sean
