Mehess Motor
Started by billmehess, April 07, 2006, 01:33:35 AM
billmehess
Good morning group!
Its always interesting how projects seem to go thru a evolutionary process. I have decided to run the motor totally from capacitors instead of using the battery.
This will I feel move the device into a true over unity status.
To accomplish this I need to do the following:
The clock takes 12 seconds to completely rewind which will then allow it to run the system for up to 30 days.
I will rewind the clock in approx. 6 second shots instead of 12 seconds for the following reason.
Using the equation e=.5(c)(v)(v)
c= capacitance
v=voltage
I will be using 500 ea 4700uf cap.rated at 35 v. with an input voltage of 1 volt that is generated from the device.
Plugging in the numbers:
e=.5(.004700)(500)(500)
e=.00235 x 250,000
e= 587
I will be winding two clocks with the motor which draws 7.5 amps at 12 volts for a total of 90 watts.
90/587 gives me 6.5 seconds of run time. This in effect "rewinds" the unit to run up to another 14-15 days. I can generate the 500 volts needed in approx. 100 hours.
I can thus power the unit from the caps and still have excess power.
No batteries, totally self contained, closed loop system, with extra power generated.
Is this not overunity?
I am ordering in the 500 caps today and figure it will most likely take about a week to ten days to put it all together
I wish all a happy thanksgiving!
hartiberlin
Bill, if you put the fivehundread caps in series to get 500 Volts total, you only have a capacity of 4700 uF / 500, so your equation result is wrong. you have a factor 500 less energy available....
allcanadian
Captain if I giver any more power she's gonna Blowwww! :o
More power Bill we need more power.
billmehess
Opps!!
Stepan was right. I have a lot of juice being generated over a 28 day period I will figure out some way to charge a capacitor(s) to run the motor.
Dingus Mungus
Quote from: billmehess on November 22, 2006, 05:52:01 PM
Opps!!
I'm quite pleased to see your plan to remove the battery from the equation. The outcome of your next experiment will truely show us all if your device is indeed over unity. Thanks for sharing your plans and information.
Good luck,
~Dingus
