Mehess Motor
Started by billmehess, April 07, 2006, 01:33:35 AM
billmehess
I didn't mean run the clcok down I meant run  the battery down
hartiberlin
Hi Bill the problem what you face is, that your system as it is now only generates maybe constantly about 10 to 20 milliWatts only. So you must wait a long time, until you can generate enough juice to fully upcharge the battery again. So when the battery will power a 100 Watts bulb then the battery will drain down quickly and the 10 MilliWatts from the pendulum will not reach out to recharge the battery.. So better try first to see, if you can make the output from the coils much bigger...
billmehess
Stepan
When I run the motor the voltage drop is around 100 mv for the 12 seconds that it runs.
It would take approx 200 caps charged to 500 millivolts each pulsing at 1 pr second (200 seconds) to recharge the battery. Charging 200 caps to 500 millvolts each would take about 1.50 minutes per cap or a total of
300 minutes this is 5 hours out of the 28 days that must be devoted to charging the battery.
The process of charging the battery to keep the system operating continously uses only a small percentage of the total amount of energy generated.
Dingus Mungus
Quote from: billmehess on November 15, 2006, 09:54:55 PM
How would this prove overunity?
The weight falling for a month would generate more power then that required to lift it in 10 seconds...
Hence... Overunity!
First if I totally drain the battery it will most likely wreck it. So lets say I take it down 50% to 6 volts. During the month I charge it back up to 11-12 volts by paulseing daily once I have enough juice stored in the caps do do so efficiently.
Use a deep cycle 12v or rechargable battery pile, it will recharge and wont be "wrecked". Also the important thing is not the voltage its the current... if the battery can no longer light a bulb its dead and cant contribute any energy to the equation and thats really important here.
At the end of the month I run the clock and rewind so it starts again.
You cant touch the weights once it starts dropping, if you need to push a button or something thats ok but you cant introduce any energy.
This is what I have been proposing all along. The only difference is that why do I have to run the clock down so It can set for a month and not do anything.
Possibly I'm not getting what you mean. Your input has been very helpful so far but I guess I don't quite
understand this suggestion.
I dont know what you mean either...
LOL
~Dingus
