Mehess Motor
Started by billmehess, April 07, 2006, 01:33:35 AM
hartiberlin
Hi Bill,
what do you mean by
"I can produce 1 volt/minute or 60volts per hour"
Is that at a specific capacitor value ?
So if you have for instance 10000 uF as a capacitor,
do you mean, you can charge it up to 1 Volts from zero Volts
in about 1 minute of time with the magnets going into your coils ?
Or do you mean the battery voltage will rise 1 Volts/minute ?
And what do you mean by:
"When I connected to the LED I got a light burst. "
Is that this way, that the LED constantly then gets light bursts,
when the pendulum swings back and forth or did you only connect the
LED to discharge the cap in one big flash  ?
billmehess
I will answer all these questions as to exactly how it works with all values of diodes, capacitors, voltage generation how the system works in its entirety on Monday as soon as I file my provisional patent.
At this point in a nut shell capacitors are charged to be able to pulse a battary. The comment about the LED
was to show that it is generating amperage, it was a response to Dingus post.
This little device generates a hell of a lot of "storable" useable voltage.
pese
you must load an condensor ,like 1000mf  or 10000mf.
to "any voltage" , and than "unload" it over an Resistor to the led.
tat reduce an overamperade flow over the LED tat will only burn for example
at 2,0 to 2,5 volt . At more votage and higher current  it will disturbe.
So if you load to tehe capacitor to 12 Volt and unload over 500-ohm Resistor,
that will the Led light take 20mA if the Condensor is 12Volt load , abd the currend go down (over time) as the Voltage drops up to 2 Volts.
This way you can also SAY : My Invention produce xxx Mittiwats per hour.
If you find more technical Informations, you can use "insted the resistor" an constant current source (made from to transistors an some resistors). Also LED with buildin
constant current souces (as 10mA) are avaiable on the marked. (All Voltages from 5 to 25
Volts can directly connected to this LEDs)
Pese
Dingus Mungus
Just passing on some of my prior work in a similar field of mechanics and clock like power distribution.
This idea for rewinding without any electrical input, I hope this gives you new ideas about energy.
Enjoy! ;)
billmehess
This is interesting but I observe the following:
Its really big and massive. Also it needs a constant source of energy (in this case water) running at a constant rate. What if you are running no water at the time, based on this design nothing would happen. Also Not a closed loop system and it requires an external input from a non regulated source. A standard hydroelectic system with running water from a river or dam is an example.Fun to look at though, as always thank you for the input. This is a great community!
My motor will run 24 hours per day. It does not need any external input, it is a totally closed loop system.It can generate its own workable power and store additional. Its OU!!
I wanted to post today but I need to finish up some last minute additions to the unit. I will post tommorow
morning, Tues am. pacific standard time.
