Anyone have a cure for arthritis?
Started by Mark69, May 26, 2010, 12:47:52 PM
z.monkey
A lot of Arthritis symptoms are caused by Uric Acid Crystals that build up on your joints.  Cherries contain a compound that will neutralize the Uric acid Crystals and bring major relief quickly.  If the cause is joint wear then you can help it by using joint supplements like Glucosamine Sulfate, MSM, Shark Cartilage and others that are a mixture of these.  But the most important substance is water.  If your cartilage is dehydrated then its gonna hurt no matter what.  I have a problem with the disks in my lower back, and when they dehydrate they really hurt.  So I do stretches after drinking a pint of Vitalized Water, and it usually helps. Micro water, or Vitalized water is excellent for hydrating those krunchy joints...
Goodwill to All, for All is One!
giantkiller
The parts list is there from radio shack.
Quote from: Mark69 on May 26, 2010, 04:46:27 PM
Thanks everyone, yeah if you can't get HGH then it that won't help :(
GiantKiller, no I don't listen to those idiots at the FDA and the drug companies!  All they want is your money and get you hooked on "prescription" drugs.  Plus their drugs cause more side effects that you will need more drugs to counteract.  Ill check out the Rife machine too.  Have you built this Lee Crock thing yourself?  I am a beginner at electronics and would need help to build.  Can you simplify the circuit info, even make a pdf w/ step by step instructions, possible make a parts list so I can take to Radio Shack to get the components?  I would greatly appreciate it!!!
MrMag- what is MSM?
Mark
Ronwg
@ MARK69--see attached for PDF schematic for building the mexistim equivalent/Lee Crock unit.
Mk1
I would try Potato Juice ..
Its not only for batteries ..
Good luck !
chrisC
Quote from: Mark69 on May 26, 2010, 12:47:52 PM
Has anyone have a working ?  I would like to hear everyone's experiences and such.
Thanks!
Mark
@Mark
Not sure if my personal experience has any bearings on your problem. I know for (100%) sure that if my nasal passage is blocked and I can't breathe properly when I'm asleep, my joints will start to hurt in the mornings and sometimes, the ankles will swell! It hurts like ***.
When I get enough oxygen during sleep, the pain will start diminishing and eventually be gone. It's that simple. Try getting some medication to unblock your nose and you might thank me for this simple solution!
cheers
chrisC
