Working Air Battery
Started by lasersaber, June 08, 2010, 11:39:33 AM
guruji
Hi Bizzy regarding the wire you wrapped it around the magnesium rod? You should do a Joule thief or stingo circuit to one of these and test if it charges a 12v battery.
Thanks for the info.
Bizzy
Quote from: guruji on February 23, 2011, 07:50:27 AM
Hi Guruji
Actually the wire is incerted into the carbon parallel to the magnesium rod. The reason for this test was just to compare a wire versus copper tubing for electricity production. Since I didn't use a JT for the tubing I didn't use one for the wire either.
Do you have a schematic for the stingo circuit?
Thanks
Bizzy
markdansie
Hi Bizzy
did you manage to get those Milliamp readings under load
Mark
Bizzy
Quote from: markdansie on February 23, 2011, 08:45:40 AM
Hi Bizzy
Mark
Hi Mark
yes I tried it under load and with no load.
Bizzy
markdansie
Hi bizzy
I must have missed the MA results..or I am a real dumbass (many might agree with that)
I intend to build some up using the copper tube .
Please post the MA results (your volts are great)
mark
