Tesla , the NS files , Cosmos Pump ...
Started by Mk1, June 09, 2010, 07:14:14 PM
Mk1
@all
I have solved , the cosmos energy idea , and will try to explain it .
I issue here will be to make it clear , my English is bad but this is of the most importance .
First i would like to talk about intelligent design , in this day and age , people are either left or right brained , but usually not both .
This is really important to understand , because this unbalance is not representative of Humans of all ages.
The reason this is so crucial , is we usually dismiss anything we cant see .
We can't see something beautiful as a tool , but to a balanced brain perfection needs to be as useful as beautiful . So they would not make something that needed power without including the power in the design .
The first intelligent design i have ever say was NS electromagnet battery radio coil ... Function and energy merged in a single design working on its own , connecting a battery to it would not only be useless and nonfunctional. Pyramids ...
Now Tesla visited NS and took a long look at NS coil , and decided to explore and push to the limits the NS design , this info can be verified on John bedini site (john studied the NS coil , but had to build one with an external battery , SGmotor) .
Now today i looked at the pancake coil , entitled electromagnet .
Back then copper wire was covered by cotton , it would not have needed much , look how the connection is the same as NS coil , this is a free standing electromagnet , no need for a battery ...
The same coil is used at the bottom of the Tesla coil ...
Those are intelligent designs , no one could figure it out because the battery is part of the design , putting a battery to it would not work ...
What to we all to , always try battery on everything , for anyone to understand what is happening , one would have to be born out side of the proverbial box , and speaking the language fluently .  :D
Now , everyone by now knows what happen , to a pulse coil , the back emf usually shows higher voltages , but the coil is a battery dose that mean we could adjust the output voltage of the battery by changing the pulse speed , i am sure we can .
Now if you are a man that studies nature , you can conceive and explain physics and its reaction as being caused by earth and the cosmos .
Siting still , sting in a car going at 100mph , does mean you are not moving , but you are far for standing still , we are always moving , while seeping the earth takes you for a spin , you are always under a 1G stress , we usually dismiss it in calculation , but this is a magnetic field , now this opens up the questioning a bit.
Compass needles seem to show it best .
In retrospect , this can explaine , the Tesla coil , Hubard coil , Hendershot , even Sm ...
The easy explanation , for all those machines are the cosmos energy  ;D , it sure is easier to explain .
Mark
DreamThinkBuild
Hi Mark,
I always wondered if a Vector Inversion Generator could be hooked to a Tesla pancake coil and if it works like your design as a NS then it could be a self priming VIG.
http://sbir.nasa.gov/SBIR/successes/ss/8-072text.html
I built one based on this patent:
http://www.google.com/patents/about?id=1v8uAAAAEBAJ
The patent makes it seem simple with the foil wrapped between the ribbon cable (I used 25ft long about an inch wide, 16 wire strand), pain to coil without constantly breaking the foil. It took me two days and constantly tearing it apart and rebuilding it again and again. I could never get it to pulse out after all the work, I tried up to 100watts 100vdc @ 1amp, no dice.
Now if you could take your design idea and wrap the iron wire with cotton and the copper magnet wire with foil then if it works as a Stubblefield it could be used as a self pulsing VIG. When electrostatic and electromagnetic energy converge that is when you get high voltage and current transients.
Mk1
@Dreamthinkbuild
Thanks for the posts , interesting ...
I made a prototype already , it works for me , i took a copper sheet and a iron one cut slices 1/3 of an inch wide , insulator on both sides , and you really need to keep them tight , the insulation needs to already be wet before adding the pressure to the coil .
Then check the dc voltage , now if you don't use a core and the coil design , it will be hard to know if it works , a well placed compass will tell you if it works or not . The meter will give you a low dc voltage .
But the magic is this coil , gives you dc and ac . If you pulse it will it respect the laws of a regular transformer or the laws of the battery current wise , 50 miliamp at .5 volts is nothing but at 120 ...
@those not familiar to the NS coil and the idea shown here .
Those are video of lasersaber , and are quite educative .
http://www.youtube.com/user/lasersaber#p/u/9/lcjxA7bYUp0
In this one he uses the coil , like a regular dc battery .
http://www.youtube.com/user/lasersaber#p/u/11/JHPKSdRRPCQ
http://www.youtube.com/user/lasersaber#p/u/7/ZuQGuXJ02fo
@all
Those that have exciter coil , tesla coil , etc , you need to make you primary into a galvanic pair .
The voltage is the same regardless of the size , the surface area determine the current , the choice of metals determine the longevity .
This means the voltage does not need to be 1.5 volts 2 coils in series makes it 3 volts , if you try this remember do not connect both side of the pairs that will only raise the current .
Mark
Pirate88179
Mark:
As you know, I have read all of the NS stuff I could get my hands on.  Tesla too, including his unclassified patents.  I have seen this pancake coil many, many times and i have also seen some very good (looking) replications of it.....
BUT
The replications all used insulated copper wire (modern) for their coils.  I never once stopped to think about what you have pointed out here with your discovery.  Not even one time.  Tesla and NS were friends or at least compatriots as I have read in the research.  Back then, there was no plastic insulated wire, if you wanted insulated wire, you used the cotton as that was all they had.  They were both in the same time period.  (NS and Tesla)
Now, looking at the pancake coil AFTER reading your posts...it looks a lot different.  It is an NS coil of a different design, but, basically the same.  The only real difference I see, as you pointed out, is the lack of a core on Tesla's but, maybe there was a core and he kept that part to himself, or, maybe he wanted higher frequency so he used an air core?
One could bury this in the ground and get the same, or higher output than the NS coil no doubt.
I admit I did not see this one coming.
Nice work and excellent thinking.
WilbyInebriated
check the last paragraph of this post. ;)
http://www.overunity.com/index.php?topic=7769.msg211810#msg211810
bill, i may have fleshed out the thought more completely in the pm i sent you about it months ago. i don't have it saved and can't fully recall what i said in it. do you have it saved?
