UFO propulsion theory....
Started by infringer, June 17, 2010, 11:21:40 PM
NickZ
  GK & Infringer:  Great posts guys.  Nice!
  I stumbled on the following article on -Scalar Technologies- and thought that it might fit in:
http://www.zoklet.net/totse/en/fringe/gravity_anti_gravity/scalar1.html
   It goes along with my ideas:
  " Scalar is a means of engineering a controled vortex to produce a desired effect. Using scalar technology we can produce an Aether pump (Aether diode) with control. This means that we can
produce a gravity point, and everything within our field will fall to that point, without affecting the normal gravity field of the planet, since our new field overides the earths field".
  Open ended Vortex Theory- on Propulsion Technology, as well as electrical production,
out of the dence solution of space.
                                                  NZ
NickZ
   @ GK:
   Magnetic Flux Line Controls:
(OAHSPE -page 568 on)  It's good to read that part of the book as it reinforces that type of not curently accepted reality about our planet.
  What is still being taught in school has already been disproved, but still being taught as reality.
Example:  That light and heat are coming from the Sun to our planet.  When there is only darkness and extreme cold between our world and the sun. Once Outside the planets vortex (that is making it's own light on the side that is facing towards the Sun).    Also that light travels,  when there is no movement at all in light, but instead a rate of polarization of light, when refering to  the speed of light.  So, why are we being taught these things as reality, when the Nasa knows very well that its not true, and has known it for years.
Makes me wonder...
    Keely mentioned the use of not only Harmonic but also Inharmonic Frequencies.
The normal Aether condition in equilibrium needs a DISRUPTION in order to produce the results that we're looking for. That's where the combined use of inharmonic wave pulse may come in.
  SM also mentioned to throw the most disruptive combination of pulses that we can at the device.
   Vortexian waves erroniously called Gravity Waves flow one way, Towards the center of a Vortex or the Earth, and then out throught the poles. Some vortexes are open ended, and not all are closed,
  The  Aether Diode idea may be a way to tap that gravity wave flow, and draw out useful power.  I'll will study further on that, and see if there may be something usefull to it.
  As we can see, each frequency or vibration is so intricate and very different in its effect and its form of flow pattern... if we miss the right combination by just a little bit, we get nothing at all,  just like with a radio signal.  But I feel like there must be an true example in nature to prove the point, like with the thunderheads analogy perhaps, or....
  Good luck with your tests.
                                         NZ
sparks
  If we learned how to attenuate the cosmic background radiation waves in an antennae or large crystal we could travel most anywhere in the Universe and have a constant scource of power.  The scource of this emwave energy is unknown as it appears to be emitted from the vacuum of space itself.  I look at it this way.  There was some sort of event that caused what we call the Universe to inflate like a balloon.   Mass is just the remnants of the uninflated or condensed universe inside the expanding balloon.  As the balloon expands the internal pressure drops and everything gets cooler.  The balloon gas is around 2.7degrees k around here.  We are moving relavent to this gas as proven by the doppler frequency shift of the cmbr in a vector determined by the milkyway galaxy travel as a whole. The nearest apparent remnant not inflating would be our galaxtic core.  It persists and resists inflation as it embodies the force which concentrated the primeval heat or vibrations in what I believe to be a continous cycle of condensation and inflation as the power of the universe breathes  Does a blackhole feel another blackholes attraction.  Is there a network of filaments connecting all that was so that it can retain the information and become it again.   These filaments able to be tugged at and the whole deal collapses into what it was.   Time and space contracting back into before the beginning at will as the power at the helm decides to try it again and see what happens this time with creation.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
sm0ky2
Quote from: infringer on July 01, 2010, 12:32:23 AM
well we cannot doubt the hutchinson effect...
Sound is proven to levitate objects without a doubt...
i once met a group of tibetan monks who hummed (moaned) in chorus, along side oddly assymetrical instruments that make a bass sax sound like a mouse.
the ceremony they created, i can only describe as a display of boulders dancing in the night sky...... you could feel the atmosphere moving on your skin, and im quite certain if a man stepped inside the center circle, he too would have flown.
Cherryman
Quote from: sm0ky2 on July 12, 2010, 12:27:26 AM
You may have witnessed something very ancient and mysterious!
http://www.thelivingmoon.com/44cosmic_wisdom/02files/Levitation03.html
http://www.thelivingmoon.com/44cosmic_wisdom/02files/Levitation06.html
