UFO propulsion theory....
Started by infringer, June 17, 2010, 11:21:40 PM
infringer
well india's monks were caught cheating not too long ago I dunno chris angel or david coperfield ring a bell?
Any magician with a good act looks downright holy!
REGISTER AND BECOME A MEMBER RIGHT NOW!!!!!
........::::::::: http://www.energyinfringer.com  :::::::::........
"""""""everything is energy and energy is everything""""""
-infringer-
ltseung888
The main thread I use is "UFO propu".
http://overunity.com/15077/ufo-propu-engine-closed-loop/#.Vds9gDZRFy0
The attached diagram contained the main points:
1.  The late Mr. Lee Cheung Kin was the first person who proposed that gravitational energy can be lead-out via a pulsed pendulum.  If gravitational energy can be lead-out, so can magnetic and electromagnetic energy.
2.  The simple magnetic repulsion experiment can conclusively confirm that Output Gravitational Energy can be greater than Input Electrical Energy.  The Input Electrical Energy aligned the tiny magnets of the iron-core to provide the lead-out energy.
3. The higher the angular velocity, the higher will be the centrifugal force.  If an object moves at higher angular velocity in the top part of a circle and slower at the bottom part, it will produce a net upward thrust.  This was coined the King David Sling technology by some Christians.
China and USA already produced UFOs using such technology.  The 225 HP Pulse Motor was funded by Mr. Andrew Wong of Hong Kong and developed in USA.  When will China or USA disclose the top secret?
Divine Wine flows...
Lawrence Tseung
ltseung888
The proposal from Prof. Dennis Leung of Hong Kong University:
1.  Break the project down into  many small student projects.
2.  Let the students compete and shine.
3.  The first experiment will be the vertical tube magnet/coil repulsion.
4.  Try to achieve the highest COP.  Even if COP could not be greater than 1, it would still be a good learning experience (use of DSO, best electromagnet, pulsing techniques, tuning etc.)
5.  The preliminary tests showed that COP was greater than 1.  Same electrical energy input, iron-core produced magnetic field hundreds times more powerful than air-core.
6.  The COP greater than 1 experiments will already be a big scientific breakthrough.  It must be proved beyond any possible doubt.  The present estimate for the scientific paper is 6 to 12 months...
7.  The next experiment is likely to be determining the net thrust due to varying angular velocity.
8.  The competition is likely to be generating the highest net thrust horizontally first.
9.  The last academic experiment is likely to be a demonstration of a lead-out energy flying saucer.
10.  Rumor was that the Nanjing UFO shown on YouTube in Oct, 2006 was done by the Chinese Military and accidentally flew over Nanjing...
https://www.youtube.com/watch?v=f-_OH6nu7V8
Scientists and engineers in Hong Kong will have much to do...
Lawrence Tseung
ltseung888
Quote from: idegen on August 24, 2015, 02:53:15 PM
NO upward thrust!
Drive down electromagnetic force.
the two forces cancel each other out.
Impact-back effect.
Newton's law.
Please study the youtube video
https://www.youtube.com/watch?v=w_yMdmavq_U
The inventor already achieved net thrust via centrifugal force.  He used a much more complicated mechanism.
Experimental proof will tell the scientific truth.
ltseung888
The second experiment is to determine the net thrust.
The trick is to turn the pulse on when the permanent magnet moves to the exact position of the wheel.  There is a relatively simple solution.  We can use either a contact switch or a non-contact switch.
This experiment can be performed as a separate project.  The students can compete on getting the highest net thrust with some conditions.
