Are neon-sign transformers overunity ...
Started by DeepCut, June 18, 2010, 09:01:12 PM
DeepCut
OK i'm sure they aren't but check the input/output watts on this product :
http://www.signbuyer.co.uk/ever-light-neon-power-supply-5kv-25ma-2407-p.asp
INPUT : 240*0.4 = 96W
OUTPUT : 5000*0.2 = 100W
What am i not seeing here ?
Gary.
kooler
CompuTutor
Here are your clues:
1:
"Constant current output
allows a wide range of tube lengths
to be operated at consistent brightness levels"
2:
"Comprehensive safety protection
unit shuts down on earth leakage
and open circuit fault conditions"
3:
"Jelly bean inhibitor
eliminates patterning in neon tubes"
4:
"Output Frequency: 24kHz"
1 & 4:
A switch-mode high frequency inverter
with a constant current output follower
that is most likely charge-pump style.
2:
Has the equivalent of a
ground fault interrupter.
3:
Sorry, sounds like hyperbolic sales bullcrap initially.
But at a very low 50/60-Hz supply frequency,
perhaps wavelength "Nodes" occur along the path...
(Correct me if wrong, always willing to learn)
Please consider this.
Only an auto-transformer style device (Car coil)
that shares ground or common base reference
works above unity when the V ratio is extreme
and is pulsed correctly to resonance.
Yeah, I'm referring to basic Tesla mentality.
Let the voltage do the work, ignore the current.
Although he was attempting to build
a mechanical equivalent of our current
microwave switching speed circuitry
with dual counter-spinning switching contacts
that are magnetically quenched into cessation.
Bless his soul.
Figure he ever achieved a 1-4 nanosecond
microwave transition level switching speed ?
He had ICE on a few coils,
I dare say YES myself ... !
However, the day I see a proper pancake coil primary,
feeding a properly tapered ubber-wound secondary,
feeding a commercial available application device.
Is the day pigs will also fly...
But Long-H and Long-C framed transformers
have been developed for many years now.
Add a modern charge pump IC,
and shared commons protection
with a GFI style protection circuit.
And instead of using the usual
primary feedback to limit current,
use the feedback instead
from a secondary output shunt
for constant-current feedback
may yield over unity...IF:
The plasma in the ionizable gas tube driven
matches a resonance drive frequency
that allows the transformer to "Float"
by sustaining the required voltage
directly from inductive collapse
while supplying the required current
to sustain the ionization required.
while remaining in resonance at all times.
Remember, they are trying desperately
to implement an equivalent technology
to sustain all currently installed lighting
with what competes with CFL bulbs...
Being able to retrofit existing infrastructure
to observe current green initiatives
dictates the release of better technology.
I have no problem believing
that lead-out energy contributes
to the efficiency as excess out.
I apologize if this got a bit heady,
but the basics are the point here.
If you have a very slow (60-CPS) source,
and your load is sustained by voltage,
be-it a Stan Meyer's cell, or an ionized gas.
The way to go is a sustained high voltage,
moderated by current limitation secondarily.
OK, admittedly, Meyers persuit required
a repetitive train of pulses to achieve
the required voltage sustaining environment
to sustain the process with minimal current.
The basics are still the same.
Make a potential difference,
limit current to sustain it.
Hope my outlook helps
someone somewhere.
CompuTutor
Wow, Ouch, Sorry ...
I am a lousy steward of the english language,
and I spell like crap on top of that too ...
Can you belive spellcheck doesn't know
"ionization", and many other energy terms ?
To be clear, requires to many words frankly.
DeepCut
@Compututor
Nothing wrong with long answers what you said was interesting.
@Kooler
Sorry i put decimal point in the wrong place but the maths is correct still :
OUTPUT : 5000*0.02 = 100W
Gary.
