Rosemary Ainslie COP>17 Circuit / A First Application on a Hot Water Cylinder
Started by Rosemary Ainslie, July 18, 2010, 10:42:04 AM
Omnibus
Quote from: WilbyInebriated on August 17, 2010, 06:47:32 PM
this was the original point of contention before omnibus went off on a two page rant filled with nothing but logical fallacy...
see this page for a demonstration of how it IS NOT "practically impossible, if not difficult."
http://swirl.awardspace.com/e107_plugins/forum/forum_viewtopic.php?4.0
it took me less than 20 minutes to set up the forum, and less than a minute to change the timestamp so it is obviously not THAT difficult and NOT EVEN CLOSE TO "practically impossible". ::)
and i repeat, i WILL NOT NOW, OR EVER, be so unethical as to hack stefan's forum to prove a point to ignorant fools.
I will go on as many pages as needed to expose self-righteous nothings like you. Don't finagle. Change the time stamp of this post or shut up.
Omnibus
To claim you can change the time stamps in a forum like this is an absurdity and you know it. Just silently go away, don't continue to embarrass yourself and that episode will soon be forgotten.
WilbyInebriated
Quote from: Omnibus on August 17, 2010, 06:58:05 PM
you are back to your logical fallacies again. you are engaging in the use of strawman... is that one your favorite?
WilbyInebriated
Quote from: Omnibus on August 17, 2010, 06:59:58 PM
you are so ignorant it makes me laugh... sql injection is one way, i tried to educate you about that vulnerability (and in all likelihood this forum IS NOT vulnerable, but that is irrelevant because you and skcusitrah WERE NOT implying that. in point of fact, you both were unaware of sql insertion until i told you about it. however, IT WAS EXPLICITLY DECLARED that it was difficult if not practically impossible.) previously to no avail. i could also simply brute force hack the admin password... you would be amazed at the simplistic passwords that are so often used. then again, as simple as you are, maybe you wouldn't. i could care less.
skcusitrah
So wilbyinebriated has now proven that he resorts to mis-direction when his argument is weak or failing [how does a layman poster change the time stamp?, as an admin, that would be obvious, even to the uninitiated  ::) ]
and that he is a spineless showoff-off with no follow-through
Add these to the previous list I made.
