Help with Ed Leedskalnin Riddle , any idea .
Started by Mk1, July 25, 2010, 11:45:22 PM
Do you enjoy this topic ?
yes
48 (80%)
I am listening . Keep going ! but its hard to understand .
6 (10%)
Your are crazy stop waisting my time , lol
6 (10%)
Total Members Voted: 60
T-1000
Quote from: IotaYodi on June 11, 2012, 12:21:36 PM
How is this power scheme any different than 60hz mains that would help him cut coral blocks and levitate them?
Im still seeing the standard  magnetic field cutting a coil.
The box is held down which I assume is to keep it from jumping {high voltage?}.
The resonant frequency of matter is definately not that low. :) If you can image Earth as big magnet and from basic principles the same poles pull each other apart while opposite attract, all the need just to make these conditions on atomic level in matter somehow.
In regards of box on tripod it definately was taking high voltage from spark gap in PMH near wheel and if you remember all those Leyden jars (bottles with wires) in Ed's workshop, it might be very possible he had same approach as N. Tesla had with spark gaps and capacitors...
7redorbs
Quote from: T-1000 on June 12, 2012, 07:04:15 PM
I am positive that a spark gap or PMH provided arc gap division existed inline with the wheel at 90 degree's to it.
I have to say the man who posted http://www.youtube.com/watch?v=xB0UMhpOHXk this video should be thanked greatly. At last! someone has built the PMH coil with the steel outer casing.
I have not tried AC with my coil yet. Only D.C. I also cannot afford the steel or the flywheel, but they are coming soon. I just wanted to say thank you to all of you who are contributing to this topic. I wish you could see the huge smile on my face right now.
Best,
A
7redorbs
Quote from: T-1000 on June 11, 2012, 07:56:57 AM
N. Tesla knew about problems with long transmission lines so he designed wireless one. But we still not use that today.
And self running generators are always on high frequency and based on Lenz force redirection to do rotor push for second cycle in useful way. This is opposed to what engineers are fighting when designing generators and motors for hundred years...
I never dreamed I would hear someone in my life time quote the operation of the Tesla Magnifying Transmitter as accurately as Eric Dollard.
I am seriously impressed by your comments right about now. The keyword I do believe you were looking for was recirculation.
Look at the Marconi Wireless System using the Multiple Loaded Flat Top Antennae, note longitudinal wave propagations of 291,000mi/sec and transverse wave propogations of 186,000mi/sec. Longitudinal propagations are infinitely flat (vertical per space time) wheras transverse are L shaped, or sinusoidal (horizontal + vertical e.g. space over time). The MLTA was capable of immense recirculating currents, much like the T.M.T was capable of generating with it's antennae.
Guess what , Leedskalnin has antennaes. I reckon it's cause the magnetic field have a different amplitude (strength) at different heights. Leedskalnin said batteries were unbalanced too, because of the way the annode and cathode connections were made. Perhaps by changing the height of one of the recirculating, rotating magnetic currents/fields he found a way to balance it without changing the battery design. Though, I doubt it.
That is probably why he speaks about trying glass in his book magnetic current. I think we need to design an energy storage device like Tesla's vacuum tube's and/or capacitors. Just like the ones that you rightly point to in ed's workshop. Bottle with wire wrapped around it, presumably with a dielectric substance and metal inside or around the bottle also. It is worth experimenting with. energy storage, is the key, as you have all seen. Storing up enough energy over time, and recirculating it n the right channels, it surely has the means of perpetual power. The problem for me is the 3rd order differentials, and getting all of the parts I need for the large flywheel.
Been talking to a guy called mikefromspace on youtube, he has some good stuff too.
Regarding what you said about the Tesla krap, here is something I typed just hours ago that you will enjoy, I guarantee. It is highly recommended for anyone working with this technology.
http://www.conspiracy.co/forums/main-wall/12764-post-project-camelot-definitive-energy-conspiracy-tap-tap-off-tapper.html
Best,
A
sparks
Quote from: Magluvin on June 10, 2012, 09:57:19 PM
Hey Sparks  ;]
You seem so well read in Tesla. I have a question.
What do you believe is the most important discovery Tesla had found, in the book Colorado Springs Notes.
Thanks for that post ;]
Mags
    I know the one that excited him the most was the standing waves existing in the ground.  He was all about developing wireless communications at this point.  Here was the solution for getting information to any point on the globe.  He did not want to mess with the oscillator frequency or amplitude to transmit the information. Damn he was spending months to get it pumped to maximum efficiency at one frequency.  How the heck to get a feeble microphone output into an oscillator rated in the thousands of horesepower.
  The solution appeared that july 4th 1899.Stationary wave field in the Earth.  I think these particular ground waves were around  68 khz carrying low frequency information with no modification of the oscilllator. Tesla never understood what he had discovered back in New York.  He saw the voltage multiplier effect and ran with it.  He knew any transfer of energy efficiently would have to get rid of current.  When he saw coronal effects coming off objects the voltage multiplier was born.  He maximized the effect and created the Tesla transformer and spent many years developing the magnifying transmitter.  I know why the MT lost it's funding and later got torn down by the US military. It has nothing to do with sequestering scientific data or JP Morgan or all the rest of that krap and everything to do with public safety concerns.  Ed makes a beautiful little theme park he hopes children enjoy.  He uses resonance to obtain large amounts of power from small scources of energy to do what appears to be majical to kids spying.  Resonance could not only lift the blocks ten feet it could throw them clear across the gulf of mexico and catapult them into the yucatan penninsula.  How does a catapault work.  You have a horse wind up a spring for an hour.  Then you release this one horsepower worth of wattage in a second.  You multiply your kva roughly a thousand by the inverse of delta t.  One hour has 3,600seconds in it. So your horse working on the oats you fed it now produces 3.6 times 10 to the 3 times 1 times 10 to the 3. Add the exponents muliply the integers and your oats investment in energy just got you a very energetic happening.  3.6 times 10to the 6th.  Or 3.6megawatts of energy.  More than enough to catapault a good size rock into space never mind set it on top of a wall.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
7redorbs
Quote from: sparks on June 12, 2012, 10:18:41 PM
I think you are correct. This is what a Giant Lever is capable of, energy storage over time. Like pushing a car with wheels. Hard at first, then easy once it is moving freely. The priceless question is, does this apply to magnetic current, or electrical velocities? I am tempted to say yes. Especially if the transformer is moving whilst the spark gap is in operation. Tesla insisted he had detected waves as fast as 50 times the speed of light. He also claimed to have "overcome distance". This is no small claim.
Here is my abstraction of the PMH oscillating http://www.youtube.com/watch?v=0ePe7SJf_KQ
It is still in the experimental stages. It is slightly assymetrical hence the balance change in weight distribution, I think. I'm still trying to explain it properly.
I think my experiment here proves that electrons don't exist in the battery. If so, then we are so so close to identifying the true source of the chemical batteries power redivision. If chemcials have orbits, then it is likely the battery is throwing out it's orbits, the assumption was that it was electrons that made them up. Remember Leedskalnin says JJ thompson got it wrong, and that Electrons don't exist.
The question is , is this video/ and the Russian Video proof of non existing electrons. I say yes. Dividing the current properly can prove it, again the question is, have I/we proved it sufficiently, and is there any alternative explanation for or against the electrons in the given video example.
Regarding the Marconi JP Morgan Krap, i couldn't agree more!! Here is something i typed just hours ago on the exact subject. http://www.conspiracy.co/forums/main-wall/12764-post-project-camelot-definitive-energy-conspiracy-tap-tap-off-tapper.html . I highly recommend it for anyone who suspects the military and government may have interfered in the development and dissemination of this technology in the 21st century, for the last 100 years, as you rightly state. It adds the ground work necessary to relate fully Leedskalnins works to Tesla's. In my mind anyway.
Hope it helps,
Best,
A
