Help with Ed Leedskalnin Riddle , any idea .
Started by Mk1, July 25, 2010, 11:45:22 PM
Do you enjoy this topic ?
yes
48 (80%)
I am listening . Keep going ! but its hard to understand .
6 (10%)
Your are crazy stop waisting my time , lol
6 (10%)
Total Members Voted: 60
penno64
Hi 7,
Would you please explain more regarding the revelation?
Kindest Regards, Penno
p.s. I wish you would at least show in light what you last video is about
7redorbs
Quote from: penno64 on June 09, 2012, 06:12:09 PM
Hi 7,
You are right. I am happy to accomodate that:
http://www.youtube.com/watch?v=UowavvqUti4
1. You should Look for the Longitudinal Blue Vertical
2. Look for the 90 degrees Leedskalnin Relationship
3. Study 4 Quadrant Theory of Eric Dollard and Maxwell Quaternions (before they were modified by Heaviside)
4. Observe Mechanical - Oscillating Current in Transformer that is A.C kind.
5. Observe that the electrical supply is not providing electrons, it is providing magnets, and that is why the device oscillates back and fro.
6. Observe there is mechanical movement from the `electricity` alone, but no electrons are in sight.
7. Observe that the transformer is in motion whilst the J rod is in motion, at the same moment that the magnetic current (what you might be calling 1 way electrons) from the battery is in motion. Here we see that something is going 2 ways, it is not resistance, it is the magnetic field pushing and pulling. Observe that this is a 3rd order differential, and requires Quaternion Theory and Maxwell I to resolve.
8. Observe that when there is 3 varying relationships, (3rd order differential) with 3 varying velocities, Electricity can create solid state-movement.
9. Notice that the "Electromagnet" I have, alternates, this means that between (or rather, in the middle of) each cycle it has 0 mass in the same way that the electricity pylons do to decrease the voltage losses.
10. Notice that when the mass is 0, (between alternations) the voltages are higher, and that is why A.C is used for long distance, by artificially reducing the mass of the wire, via impulses and thus decreasing the energy that can be lost ;-)
11. Here the battery is providing DC, and the air and magnets in/from spark to create AC impulse running currents.
12. As you can see it is fairly elementary the statements I make, and they can be verified for yourself, without the need to criticise the hard work I have made.
13. If you feel that you can give a better explanation than in my video you can go below and see how it works for yourself. Also feel free to make a comment.
Thank you and good day :)
Best,
A
penno64
Hi 7,
Sorry if you misunderstood my post.
I am intrigued by your experiments and want to know more.
I merely wished to see the device you were demontrating.
Again, apololiges if I offended.
Regards, Penno
7redorbs
Quote from: penno64 on June 09, 2012, 09:19:03 PM
Hi 7,
Regards, Penno
Hey Buddy ;)
I am not offended. I carbon copied the youtube description in my post. I will post more about the device for you shortly, but alas it is 3am and I must sleep now. I hope this satisfies your curiosity and I am all along delighted that people do show an interest in this work. Delighted. Not offended ;-)
Best,
A
sparks
     I don't know if this post belongs here but I will offer my lifelong experience with electric motors to help explain Ed's machine.  In order to convert electrical energy to magnetic energy you need to redistribute electrical charge.  The magnetic field is comprised of energised particles that respond to and are responsible for charge.  If you move a charged body like say an electron the particles that create the charge of the electron change their path.  This change in path is described as the propogation of a magnetic field.  An electrical current is not the movement of charged particles as some would have you believe.  Electrical current flows from anyplace that has different charge density.  In a permanent magnet the atoms comprising the magnet are caused to take on a crystallized form under the influence of an electrical current.  The metals are caused to be molten and exposed to current generated by an external scource.  As the metals are cooled they form a crystal that "remembers" the external current.  The atomic lattice is so disposed that the charged matter creates a predictable magnetic flow into and out of the field of the magnet.  Let me call these virtual particles magnetons.  A positively charged body (like a proton) has it's positive charge assigned to it because the space it occupies has less charge density than the electron's charge density.  This creates a constant current between the electron (which is now identified as being smeared in the atomic model not a little planet going about the neucleus) and the proton.  If there was no energy input from somewhere a hydrogen ion could not exist.  The electron atmosphere would quickly deplete itself of all charge anistrophy and the proton would become a neutron.  Now I have to refer to particle physics because it seems the "most validated" scientific theory in practice now.  The magnetons flow from a spot of higher charge concentration to one of a lower one.  The electron which has more charge density gives up these magnetons.  Monatomic hydrogen is the most reactive atom known to man.  As the monatomic hydrogen atom proton deplete's it's electron of charge it becomes a neutron unless it can reach magnetic equilibrium with an external field.
In any electric field there are magnetons being transferred from a point or plane or 3dimensional sector of high charge to a field of low charge.  They continually replenish the electron field at a rate that allows the electron to exist.  If we move the matter into which they are flowing in around and all about then a magnetic field arises.  In an electric motor we move electrons.  The magnetron current supporting the electron relativity then follows the movement of the charged matter.  Ed knows this.  He has been studying magnetism.  Taking batteries and watching cables jump as he moves massive amounts of electrons through the cables.  He studies which way they tend to jump in relationship to the ambient magnetic field of the Earth. He realizes that the magnetic field is a flow of something.  Why bother moving electrons in a wire why not just send magnetic shock waves down a steel cable.  If I want or need an electrical device to work distant from my magnetic flux generator I will transmit magnetic waves through the mass of the cable and just wrap a little copper wire around the end of the cable and get my electricity.  In an unloaded power transformer current is minimal.  The impedance of the primary is such that little current passes from line to line. When current is drawn from the secondary the primary is no longer choked. It's impedance drops and current flows through the line circuit.  Now imagine you take the core of that transformer and run it down into your house instead of a copper wire you have one steel wire.  You wrap some heavy wire around this steel cable.  When you draw current it does not affect the primary impedance at all.  Because it took time for the magnetic field flux change to be transmitted to your end of the transformer.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
