Help with Ed Leedskalnin Riddle , any idea .
Started by Mk1, July 25, 2010, 11:45:22 PM
Do you enjoy this topic ?
yes
48 (80%)
I am listening . Keep going ! but its hard to understand .
6 (10%)
Your are crazy stop waisting my time , lol
6 (10%)
Total Members Voted: 60
7redorbs
Quote from: sparks on May 06, 2012, 02:13:10 PM
The Earth is moving at 600km/sec towards the constellation Leo, along with the rest of the galaxy and alot of other galaxies.  This motion is relative to the cosmic background radiation which is in the microwave spectrum.  (If you have a circuit and receiver that is tuned into this signal then you'll get some energy out of the vacuum.)  So if you look at just one point on Earth from a fixed position in the cmbr with your back to Leo the point on Earth would be doing a very complicated dance.  Small rotation of 1000mph and a large rotation at 60,000 mph solar rotation   and an even larger rotation at the galactic rotating mph.  Speeding up and slowing down really complicated to think about.  Einstein or someone finally threw in the towel and said that motion only exists relative to the observer.  The observers motrion is irrelavent.  This is really counterproductive.  Everything we see is an abberation.  Granted 600km/sec is not even close to 300,000 km/sec but it is way faster than our fastest vehicles.  Can this motion be exploited?  Say we have a coil of wire with an attached voltmeter or led.  This coil of wire is actually moving 600km/sec.  We know the coil is not going to generate any voltage unless the magnetic field it passes through is changing perpendicular to the coils motion.  So we have a set of permanent magnets but they are also moving 6ookm/sec.  What if we can somehow make the permanent magnets stay put.  This would require that we move the magnets relative to the wire and moving them would require energy to overcome the inertia of the permanent magnets mass. Hmmm.  What would happen if we create a magnetic field  disruption that appears to move from our observation post but in reality stays fixed as our coil moves through it.  Our coil would have to move perpendicular to the produced magnetic field.  The magnetic field would have to move away from the constellation Leo at 600km/sec and the coil aligned to intersect this "moving" magnetic field.  No small task.
I really enjoyed reading this. The sun put's out magnets, it's true, the sun is moving, it's true. So, the sun is a moving source, and the magnets that the sun puts out are moving in and out at their own speed(s) too. Any given individual magnet leaving the sun is equal to it's emission speed, added to the mechanical movement of the "Sun" , or "Armature" if you prefer.
The earth absorbs the magnets coming from the Sun, per time, that is to say, the Earth is charged over time by the magnets hitting it. The sun's new magnet emisions, and their sources mechanical speed added to their individual magnet emission speed is added to the earth's current individual magnets, per time. Fluctuations in the sun's emissions, or objects passing inbetween the sun and the earth, that might make it in a shadow, at any given moment will cause more or less individual magnets to reach the magnet we call earth. More magnets means that the earth is reflecting more magnets, and absorbing more magnets, and losing more magnets, simultaneously. The Sun is akin to a north and south pole transformer, depending on the time of day. IF you can overcome the transient of time via energy storage making the two compatible is not difficult. The real question is what is heat, but the presence of no obstacles between a heat source and a subject, in this case it is the sun and the earth, but it is equally true with electricity and wire. It is interesting to note that the presence of no obstacles between the sun and the earth generates the absence of shadow, whereas the presence of obstacles in an electrical current creates the presence of light. I think this requires more study.
Afterall, I hope I have clearly established that all of the currents that are perpetually generated by the giant magnetic molten iron core we call earth, usually with a hole in the middle, and, that it is the Vertical position of the Sun that generates heat on any one half of that circle. the proof is that where there was heat, there was magnets, but the most important understanding is that where there is magnets there is heat, the Sun puts out more magnets that most men can imagine, and, also, heats the earth. This confirms again, that where you find heat you will find an abundance of magnets. I believe this to exist in the principle of the heating of any element material to exist, whereby heating can cause a positive or negative contraction or expansion akin to a counter-clockwise rotation vs a clockwise rotation, or rather, north and south poles, pushing and pulling forces. It is these forces that come from within the material, or mass, when the mass no longer holds together. I believe I can unnecssarilly complicate things, so for those that find this hard I will make it simpler for you.
The sun makes half the earth hot and the other half colder than that, because the concentration of magnets changes throughout the day, the induction changes, and that is why Ed told you that there will be a change in the voltage and current between his foot and his tongue depending on the time of day, Ed may not have had an interest in biology, but I do, the veins and arteries in the blood are golden ratio logarithmic in nature (look at a leaf and how it resembles the aerial Television / Radio Frequency Antennae, I do not believe this can be a coincidence any more than the shape a tree groes above and below the ground, nor how above ground it seeks light through aether via magnets, and below ground it seeks the water through the earth, via magnets, I believe this is the basis of the old alchemical elemental system, to which I do not have as much expertise as the Mason Edward Leedskalnin. I can tell you that the masonic hammer shows that MECHANICAL energy is derived into electrical energy, and electrical energy is derived into other energies, some of which Leedskalnin and Tesla most certainly were experimenting with, given the spark gap and primary secondary is enough to generate Tesla's Longitudinal magneto dielectric waves, also known as the Marconi Wireless System.
Furthermore, the ocean and it's movement, has a heat current and a mechanical current (existing wave of magnets field and earth field), and it has the moon and any other planet. Engineers at Radio Corporation America, the government military people that stole away Marconi in 1914, knew all about the problem of inductance from traversing cosmic objects, and indeed the effect of local magnetic fields such as planets, they designed a multitude of equipment, much of which is still in use, to control overloading that might result from long transmission lines receiving extra currents from 'solar radiation'.
In truth this solar radiation must be magnetic in nature, like Radium and Uranium is at it's atomic centre's, because not only was there heat like there was magnets before, but, there was induced voltage, and electrical energy in that long transmission line wire, so, you see, we know for sure whatever is coming in the wire and putting that extra power that R.C.A and Tesla Marconi as well as C.P.Steinmetz and the designers of the telegraphy systems, and equations of mechanical engineering operation, such as Heaviside's equations, you see, they actually prove that the force is there, that it is documented, exists, is magnetic in nature, and is certainly still today making those so-called electrons appear in great numbers, at the end's of transmission line capacitances, of great harmonic length, and as a result purely from the magnetic influence of the Sun, is able to create those so called 'electrons' from just magnets and metal alone. This proves that not only are magnets at the base of things, but that the inheritors of Tesla Marconi knew all about it, because they had to (This cosmic induction is a serious issue that has been worked on for 100's of years!), see the hundreds of Anomalous Voltages and references in my work on conspiracy.co or alternatively read Eric Dollards books, they have the references amany to such anomalous transformers blowing up at the power station, some are due to magnetic harmonic effects of the earth (like with AC power line transmission increasing with voltage instead of decreasing as electricians are taught today), note that the military use Maxwell V1, and Einstein uses Maxwell V2. V2 doesn't go above second order derivatives, the sun, the moon, the ocean, and their specific phase relationships though, all of them do, and that is why they have the power of perpetual motion, provided that the angular relationship supports equilibrium in the gallilean frame of reference, motion is most certainly unceasing, in fact, it appears the bubble expanding of the universe, is doing something that we consider impossible for a battery's electrochemical boundaries to do, expand infinitely, and accelerating , this proves that the force creating the universe is like a battery, and thus is like a magnetic current, along with everything else in this universe. As long as there is darkness cold, and light, heat, there will always be movement, and magnets, or their absence. I challenge anyone to break this rule,
http://www.youtube.com/watch?v=LseEv0MZiOY
Thank you so much for your post sparks, it has inspired me,  you too Mr. Scotty, I hope you enjoy my video and my post.
Best,
A
7redorbs
I really like the guitar man. I'm jealous, I was thinking about creating a piano box myself, not your usual instrument though... oscillating current instrument, impulse based ;-)
It is quite simply really, if each note has a specific energy output (per note), then compressing many notes , fitting progressively more impulses per second (and thus more energy per second), the T.M.T works this way, and a mechanical means of increasing the step speed of the note (or even an electronic means for a speaker based self referencing wave), the trigger speed must increase to a resolution infinitely small asymptotically, no easy feat. A self referencing wave might do it, (whereby the pulses each second effect the duration of the next, and so on),
Best,
a
7redorbs
I dont want to sound gunhoe, but given I am getting 1000-2000V minimum impulses from a 3.00V (2X AA) and a single PMH, I'm thinking 5 PMH x 24 is a lot of voltage if you put it in a capacitor.
http://www.youtube.com/watch?v=n-qEErJa_6w see attached video
Best,
A
7redorbs
Everyone went quiet, so here is something to get you all excited again.
You will have never have thought this before. Look towards Sankofa, and please, this sankofa discovery, for once, should be credit to me. :) Go check what I said it means in previous posts.
It's surprising. Anyway, recently my site has been under DDOS attack and brute force attempts, and recently we had our ads pulled down because our content is a violation "Unacceptable Site content", you guys have to wonder if there is any intention to make this stuff public.
My point in hand, whatever happened to that patent for it anyway that Leedskalnin spoke about in his book Magnetic Current. Damnit, It's frustrating, right? We need to stick together . I dunno :( I just know this is really important
We have musicians here, so, they will understand this post was about the origins of music, and the base of all sound.
Best,
A
7redorbs
Quote from: Mk1 on January 28, 2011, 10:43:42 PM
Hi mine is sideways ...
I can do better ;) but that is not to say I didn't love your post ;)
I can pretty much guarantee my book is going to be quite interesting. I hope people show more interest... this is so important. I share all I have... out of the kindness of my heart, for the sins of man. reallly, I mean it. I might not be that smart, but I know more than some smarter people for sure about some of this, *shrug :)
Peace and respect guys, keep it up
PS: as you can see ladies and gentleman the picture I have below is a perfect representation of Ed's experiments in his book magnetic current page 1 - 14. Given ed's claim about the Pyramid Builders, and the age of this artwork in the picture, I hope people realise what I'm saying about Sankofa and the lost knowledge of Solomon, and that which predates him, deserves much more attention than it is being given, I know, it's a fantastic discovery, even the 22.5 degrees is there, there is a lot more than just his experiments in this logo. It really is a holy grail of EDL's work.
Best,
A
