Help with Ed Leedskalnin Riddle , any idea .
Started by Mk1, July 25, 2010, 11:45:22 PM
Do you enjoy this topic ?
yes
48 (80%)
I am listening . Keep going ! but its hard to understand .
6 (10%)
Your are crazy stop waisting my time , lol
6 (10%)
Total Members Voted: 60
xadmx
Quote from: IotaYodi on September 08, 2012, 02:24:19 PM
Heres just one source.
http://www.modeltford.com/item/3276B.aspx
thanks for the link.
has anyone made a connection with the numbers on his door frame, does this mean ( look high look low ) as on his certificate his height is 5 ( 5 magnets high ) and his weight is 120 ( 120 magnets )  i have linked a few other things on the certificate but i am still checking them out.
adam
T-1000
Hi guys,
There was some crosstalk in Muller dynamo thread so I left some information:
http://www.overunity.com/3842/muller-dynamo/msg338227/#msg338227
Quote from: magneto_DC on September 28, 2012, 06:41:54 AM
Hi T-1000,
some questions regarding ED L-device.
The pic above shows (mainly) the stator of the device?
What is the active side of the stator?
Is it outer ring (area) NN-SS-NN-S...? (I would say: No).
Is it inner ring (area), the Bloch Wall? (I would say: Yes). But I am asking YOU.
And the rotor is mostly gone?
It was in inside area? And had a (one or more) radial, iron-core, high-impedance coil? Going from Bloch wall to bloch wall?
Or was the rotor outside? What design?
Thanks in advance.
magneto_DC
The flywheel in one of many videos:
http://www.youtube.com/watch?v=Z_X17dEI1J8
Magnetic polarity: http://www.alexpetty.com/wp-content/uploads/2011/06/flywheel-1.png
All magnets are "V" phorm, the bloch wall is inside of rotor. They are 24, phorming "VV" connections with N+N-S+S (same poles from 2 magnets forced together) combination.
The PMH is missing there. The only one place where you can see it attached to flywheel is in this photo: http://www.leedskalnin.com/Generator.jpg ( http://www.leedskalnin.com/LeedskalninImageArchive.html )
Also people are playing with it:  http://www.youtube.com/watch?v=UFcd_QCLK5w
logos
Quote from: scotty1 on May 06, 2012, 02:02:36 AM
@Derek.....my explanation about facing East was only one of a few reasons as you note....
Ed also faced East when he made his measurements of the Earth's true path, using his polaris telescope and sundial ect.
The compass dial he used to mark his findings has "looking East" written on it as well.
In fact....alot of the tests in Magnetic Currents have multiple meanings and when cross referenced, lead to other information.
I've attatched a pic of Ed's compass dial that i edited. (the words on the original pic were hard to read so i put them in bold)
hey scotty!
i'm a big fan of your work.
you do realize that this is a 2D picture of a 3D event ;)
david lambright
What i have found is that Eds PMH held this energy forever, till the core loop is broken. His generator at coral castle is a PMH, the magnetism is residual, left over from being energized like any iron PMH will do. The field that PMH makes can be oriented by gravity, artificial or natural. The artificial way Ed used was centrifugal so that the center line [axis] and equatorial plane are opposite sides of the energy he termed magnetic current. I have also found that this energy is absolutely and completely visible.  http://www.youtube.com/watch?v=KsyUU0fPxeo and http://www.youtube.com/watch?v=uRgcC_mK97k  are a couple of examples of just how visible this field can be. I am still trying to get usable video of a piece of coral deforming in this field, what i mean by that is i can push down on the coral and it bends ever so slightly but even a deformation of hundredths or even thousandths would be significant, wouldn't it ? And the way a PMH can induce giant paramagnetism in MANY metals, [aluminum, LEAD, magnesium etc.] and even heating the lead to melting did not cause the metal to loose its newfound property, just showing that this energy is profound in its abilities. With the coral, it is like the density is being manipulated, making it become softer and lighter. There is another thing i have noticed, is that at times, certain objects SEEM to loose some of their opaque-ness, but movement, or another form of energy has to be added to get that effect. I have seen a video from John Hutchinson that has many similarities to what I and many others are experiencing with the devices I make. I believe John makes something similar but with HF radio and other waves as the extra energy needed, added to a PMH type field, to obtain his effects. I believe that he looses a lot in controlability of the effect, using electrically produced fields and that Ed made the same type of field using magnetics as its source so he gained a better control of the energy fields . Edward Leedskalnin cut and placed many tons of stone. He said he used the generator, at his castle, to accomplish this feat, i believe he did just that and it is those same energy fields that I have rediscovered.
OzTrAlien
As this is my 1st post i would like to begin by thanking everyone who has been studying the works of EDL and others and have been sharing their findings and i urge those pondering the works to list any thoughts they have as even the smallest of thought from someone may expose a direction overlooked or as yet unseen that may help to unlock this puzzle.
Just some thoughts on the bike in the pic, i think it represents the bi-cycle nature of the forces we are attempting to uncover, Ed was very meticulous in all he did, i feel the chains represent the flow of the "current" as ED has pointed out both sides move together, if one is made to move so to will the other, the chains going up present the field being created by the "currents" moving up out of the generator and back down to the castle walls and vice versa , the walls had thick flattened copper cable run along the top of them, this i feel worked much like a "high-voltage lifter" does except the walls do not rise as they are grounded and no gap is between the cable and wall, this passed the "energy" to the walls and a  field "box" made out of the walls, the walls are in 2 halves around the complex not 1 continuous piece, so one side of the "currents" was drawn to one side of the castle wall and the other to to opposite side, this is represented by the pic, the chains going up being intertwined through all the block and tackles (ie : the lifting mechanism placed high) and then coming down in their bi-cycle form to the walls, as Ed has pointed out 1 side goes up from the earth one side goes down into it, depending on where you are and the direction you face, by moving the currents around the walls the lifted object could be controlled by passing the correct type of magnets through the object to get the desired outcome, this is a 2 part "system" the walls being 1 part to form the field and the other part was placed high above the field so as not to interact with the field directly, but could be used to induce the flow of the desired "magnets" into an object to allow for lift to be controlled/made, hence the box on the top of the tripods and the cables running from it, this was "tuned" from the wall field or if you see it like this was drawing from the generated "energy" and if it is as i suspect a PMH inside it this allowed for one current form to be passed down the cable to a "wrapped" stone, this made the stone lift as we know opposites attract and like poles repel, the PMH has the ability to "separate" the 2 sides of the currents much like how a Lord Kelvin Generator causes the water to separate the polarities of the water molecules and allows one side to drip for one end of the pipe and the other to to drip from the other end but not actually separate the water. It is this wall/Top of Tripod relationship i think Ed was referring to with "raising the girls too big" will make them "round" if you make the field strength in the wall too strong it will connect both sides and make a big "bubble" or become 1 whole field encompassing the tripod and loosing the ability for it to be able to be separate of the field and used to make/control the lift, so you need to keep the wall field strength at a point to create like a figure 8 on its side and have the tripod siting above the lines of force that are being formed, i hope this is showing how it might have been done, i think the "field" relationship strength wise is like Jupiter and Saturn, how they are almost the same size as seen in the sculptures, or the harmonic value is created within the 2 waves tuned to these values, i dont think the "flywheel" rotated, this is mainly because of the wire that is set in the flywheel came out through the hole and connected to somewhere below, if it rotated this wire would bind and break, i believe it rocked back and forth through a very specific arc, that would create the pulse rate needed to give the specific value needed for the field to be developed, i believe water was in the inside of the flywheel and this is what allowed for the rotation to be passed to the field, Ed's favorite presentation to guests was him sitting in his bath and the water not rising, which i feel he was showing how water will displace any energy put into it, and yet not change, just a hunch and he had obviously calculated his displacement that was carved as the step in the bath :), but as he pointed out in the book about Matter/Life water traps magnets/sunlight and this is then conveyed on to the things that use the water, ie: through the water, well i have gone right of track so will leave it at this for now, but that's my thoughts on the bike in the pick and the chains, well some of them and i'll ramble more later.
Be Well
