Help with Ed Leedskalnin Riddle , any idea .
Started by Mk1, July 25, 2010, 11:45:22 PM
Do you enjoy this topic ?
yes
48 (80%)
I am listening . Keep going ! but its hard to understand .
6 (10%)
Your are crazy stop waisting my time , lol
6 (10%)
Total Members Voted: 60
david lambright
the energy in a PMH is in its nature magnetic. the flash of light when the crossbar is pulled off the PMH shows this, but once the bar is pulled the field dissipates. i believe Eds generator IS a PMH. there is a visible field around every charged PMH that is polar like magnetism. it can be separated, the same way temperature aligns itself with a gravitational field, artificial or natural, a centrifuge can separate the PMH's energy field. this energy is visible. this energy is NOT electricity. the dissipation of energy from a PMH will make electricity[tiny flash]. an analogy of a PMH's field is ambient temperature. a vortex tube spins air and separates temperature, google it. spinning a PMH separates the magnetic energy it holds into its polar opposites. this is magnetic current.
david lambright
i saw some images of fire tornadoes, the way the vortice enlongates and concentrates the heat in the center is very interesting. in a rotating mass of air with a source of flame or heat, the fire is driven to the center and spins faster. the PMH energy follows the same thermodynamic flows and laws
derekwillstar
Quote from: david lambright on March 19, 2013, 12:26:03 AM
Exactly!
David, I will follow you on youtube, thank you for your precious revelations!
The nature do not need electricity! (do not know what to do)
the flash you see is mono-magnetic positive energy, the same one that comes from our sun ...
PMH currents flow in mono-magnetic "N" (positive , yang , light) and  the "S" negative yin opaque.
the same energy exchange that occurs between the sun and the earth.
Please consider the law of rhythm by Pier Luigi Ighina: http://www.fortunadrago.it/?page_id=279
(Traslation on the right)
greetings from Italy
DOM
FatBird
I know exactly how Ed Leedskalnin moved HUGE & heavy boulders AT NIGHT without touching them.
Click on the Link below & you can know too (if you are NOT closed minded).
Of course, Ed did NOT use any drums or electronics.
http://www.thelivingmoon.com/44cosmic_wisdom/02files/Levitation03.html
truesearch
@Fatbird
Is your opinion that Leedskalnin used sound oscillation/harmonics for moving the stones at Coral Castle?
truesearch
