Help with Ed Leedskalnin Riddle , any idea .
Started by Mk1, July 25, 2010, 11:45:22 PM
Do you enjoy this topic ?
yes
48 (80%)
I am listening . Keep going ! but its hard to understand .
6 (10%)
Your are crazy stop waisting my time , lol
6 (10%)
Total Members Voted: 60
sm0ky2
Quote from: gravityblock on July 29, 2010, 02:17:43 PM
You have the magnet order wrong.  This video shows the magnetic pole configuration on Leedskalnin's generator.  The flywheel has a north south north south.....pattern, http://www.youtube.com/watch?v=GemkVvlaMNU
GB
i wasnt going to comment on that, because there are so many different theories floating around about that wheel of his..
when i went there in the 80's, it seemed quite clear to me that this was a Generator, not a motor. the chains and weights drove the generator, wound up on the horizontal sprocket above.
i believe this is what ed used to recharge his batteries, and create magnets. when the weights hit the bottom, he wound them back up like a clock to operate te generator again.
but even way back then, it was only half assembled, and missing several pieces.  from what i hear, its in even worse shape today..
which i think is the cause of most of the confusion.
Mk1
@all
I would not really make conclusions on the magnet as of yet , the reason are simple , magnets in close proximity of each other can reverse the field or plain stop , and you clearly see in this video the magnets need recharging.
Second , Ed liked his girls weak , girls is the south pole , he told us about it .
The way the video is made is not precise enough for me , there are 5 rows of magnet are they all the same ?
How much decay is responsible for the current results ?
It would take many hours of meticulous verification before i will admit it to be the way .
Now if that is true , its a good news , no need to make special magnets , any old magnet will work ...
To make a real test , you need a real compass , those magnetic readers are only good to make movies , you learn nothing from using those , you can't see the magnetic lines .
The way the test was performed was inconclusive , he is checking the peak of 2 magnets at a time ? The reader can only show one polarity at one time most likely the strongest .
If you want cavitation you need a vortex implosion , Ed made basically a Magnetron with the cavitation cavity on the out side instead of inside like the microwave.
@all
I know i sound crazy at time , but come on your guys are just looking for excuses to go back to sleep , the world is changing will you have your word to say in it ?
If yes , then do it !
There is no right or wrong there is only logic , you don't need any experts on that , you are one!
Mk1
Quote from: sm0ky2 on July 29, 2010, 10:04:48 PM
I agree it is not motor but a generator , but not a electrical generator but a magnetic current generator , hence the magnetic current tittle , and on the
picture you can clearly see that once you know what to look for and have some idea on what gravity is .
But i have to say i had many theories before this one , but none made sense with the evidence and clues left , i bet most just don't see clues as clues but plain rocks without meaning .
I have studied Art history 4 years , also took astronomy , electronics , mechanics , physics , chemistry class in college , was painter , sculptor photographer , i also am a musician play many instruments and i am also proud to say i am a chess master (if you don't play at a competitive level you don't get it, if you want super brain function you have to train it.
I quite versed in most intellectual fields , this is why i see stuff others just dismiss , i am only stating what to me is evident , for the last 2 years i worked on the assumption that if it is evident to me it evident that is all , i am not one usually to state the obvious but since clearly learned this to be false ...
I oblige my self to do so , otherwise no one will see it .
I will not go to Africa to help or be a missionary , because i will help even more by sharing what i am good at , apparently its to see invisible things , lol.
Everyone wants to save the world , first save your self , help by doing what you can do best...
What will i have to answer and build and explain everything my self .
Mk1
@all
I will try to illustrate magnetic current in its simplest form ...
The holder :
The holder is a piece of iron you put at the end of u shape magnet to keep the magnetic strength up in the iron magnet.
Simple as it looks , its is quite interesting .
First thing to observe is that the magnetic field around the magnet is gone .
This can be observed with a computer screen quite fast .
The magnet is still active but the magnetic current is not circulating inside the iron bar not outside around the magnet .
That is magnetic current !!!
How to use it ?
I will show you all in the next few post , this is nothing new it was used in the old days i have seen it on the Ford Model t magneto , and many other example of the same thing like eds machine.
Mk1
