Seiki S, The Principles of Ultra-Relativity
Started by ashtweth_nihilisti, April 17, 2006, 11:22:14 PM
ashtweth_nihilisti
Seiki S, The Principles of Ultra-Relativity, Ninomiya Press, PO Box 33, Uwajima City, Ehime (798),Japan, 10th edition, Dec.1990.
http://rapidshare.de/files/18285814/Seike.pdf.html
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panacea-bocaf.org
http://www.panaceauniversity.org
http://www.geocities.com/glorybangla/cqtes.htm
ashtweth_nihilisti
any body have any experience with his rotary formulas into real devices?
richardasher
Would anybody who downloaded this book be so kind to upload it again? The rapidshare link is dead.
Thanks in advance for your help.
ashtweth_nihilisti
Seike's book - printed in English (on even numbered pages) and Japanese (on odd) - is completely incomprehensible to the lay-person, but for an engineer it contains replicable  theories on mysterious Moebius-wound coils and other devices which would provide you with free energy, antigravitation and eternal youth.
mathematical calculations are mixed with the relevant formulas, it takes a lot of patience to read his credulous treatment of the claims of 'Professor'Despite this, Seike's writings have inspired many researchers to employ his ideas and circuitry.
Based on work of Prof. Shinichi Seike's Nuclear Electrical Resonance Theories, JL labs successfuly tested his G Strain energy absorber. The conclusion proved his theories on the Gstrain are correct. http://jnaudin.free.fr/seike/gseav3.htm
Other continuations of seike's research can be found in The Roto Verter (RV) originally the intellectual property of Hector D Perez Torres,publicly released open sourced.
Hector states, Seike formulations are 300 years ahead of this timeline, the background is contained in the ROTARY phase kaweyama model. The RV is the physical demonstration of this principle and all seike's work is related to it.
Seike could have used 3 PH motors to demonstrate this principle, However there are physical dangers involved when you create hi power rotating self oscillating engines.
A NOTE :
In some Motors which are set in wye and are feeding pure DC to L center and capacitor (C) which are being negative fed to a tripleflux wye center flux, will create a rotary field with infinite acceleration capcity.
The Konehead RV lawn mower demonstrated a tendency to accelerate towards infinity from creating its own incremental harmonics in a self cycloconverting effect. conditions to create this effect are critical in adjustment
SEIKE clearly explains self rotary effect ...(Easy) A,B,C is PHASES.
The RV needs to break the 24 LAW rule
Up to date 23 does not suffice to break the collective barrier to materialize it from 4rth dimension coordinates to physical reality. AB,BA,CA  Look for that in seike formulations , your eyes will open as you realize its 3 phases.
The self spining of delta wye seike model responds to a gravitic spiral flow component (as coreolis electrical force) being constructed a Rotary Engine and made to accelerate over the Spin 4D vector G (gravity),it then enters a NEGATIVE state as the rotary transform becomes a reverse flow in time relative to gravitic one.
Simple, More simple as you have RV "GATE" to enter the portal.
The RV is well justified in SEIKE'S rotary formulations , and is the theoretical complement to the RV. Seike failed to apply such formulas to rotary machines, the  RV well demostrates that his formulations are a physical realit , including TIME TRAVEL and Anomalic gravitic phenomena at hi energy, this is relative to a 1 meter wavelenght in a RF rotary dipole element triad.Just be carefull with experimentation in RF rotary fields as you can end TELEPORTED with no return to Other place other time.
The  book ofs prof. S, Seike, Principles of Ultra Relativity, 5th ed. Put some insight into these concepts upon examination. The RV?s ability to save power comes in fact from a receding time variable, from the STATOR rotating field view the rotor is a receding resistive force were the power used is measured in pressure and as angle of rotation variable in field  ( inductance reluctance).
Like is physics initial acceleration from a mass at rest until it equals the force moving it, once is equal the only energy used is the one raised by entropy losses. Extracting OU requires all this basics to be digested in models, else theory standard deviates mind toward entropy again. Its the Method what matters.
Book
http://www.megaupload.com/?d=4NZVDLHF
Also there is a german patent which is related to biological
Quote"The patent was rather vague about the exact mechanism behind the construction, so that's why I wanted to check the references to get the theory behind it. I attached the patent to this post, I hope you can read German tho! In short, the patent is about regulation of biological systems."
patent-http://www.megaupload.com/?d=CJU0NUBI
pese
Es ist typisch Naudin das Birnen und ?pfel verglichen werden.  Nicht nur dass sein SEIKE Nachbau nichts mit SEIKE oder FE  zu tun hat. Es ergibt keine Overunity , weil er in einem   anderen Link , schon "offengelegt hat , dass die Transistoren  heiss werden (= LOST !!!) , und das die Frequenz sich anfangs stark   ver?ndert (ohne zu verstehen , dass es mit der Erhitzung zu tun hat.  (Unstabile Schaltung !! Jede Transistorschaltung seines Labs hat  garvierende Fehler und M?ngel - er versteht es einfach nicht ! )    zu dem Link gseav3.htm    zum Beispiel Folgendes:    3. Bild = Setup #1  Man kan einfach nicht so messen .
1. ist dies Analogmeter mit seiner eingebauten   Gleichrichtung f?r niedrige Frequenzen halbwegs genau..
2, sind hier Pulsspannungen , Sqarewaves und Mischung daraus enthalten     also ALLES , nur kein SINUS , Diese Ger?te sind f?r 50/50 Hz SINUS     nur "halbwegs" genau .  Hier muss ein "TRUE RMS Meter her".
2a.Das messen nichtsinusf?rmiger Spannungen ist grunds?tzlich so grunds?tzlich     nicht mal "ann?hernd" mit mit Wirkleistungen identisch.
3. Eine weiterer Fehler ist hier dass eine Gleichspannung zus?tzlich auf     die Wechselspannung  "aufgedr?ckt" wird . Das heisst dass durch ABSICHT     oder "Dummheit"  , oder entschuldigend : "Nichtwissen"     etwa die "halbe Betriebspannung" Collector zu Emitter oder Minus gemessen     wird - als DC  + eine Wechselspannung sich hinzuaddiert !! Was jedem     Elektronikbastler auff?lt und verst?ndlich ist . Auch wenn hier g?nzlich     un?blich , oder zur "verwiirung Collector gegen Basis gemessen wird ist es     bis auf 0,7 Volt Differenz praktisch der gleiche Nonsens
3a. Um sich dies besser vorstellen zu k?nnen , sehen Sie au das Setup #2      Hier erkennen Sie das der DC Anteil der Schaltung direkt - ?ber die Dioden -      an + und - des Digitalvoltmeters gelangen . und sich der Wechselspannungs       AC Anteil hinzuaddieren wird.    Die "SHOW wird dadurch nicht perfekter statt des SANWA Analog Instrumentes ein  teures FLUKE Digitameter zu nehmen.
Das ganze ist SHOW und UNVERSTAND um LEUTE auf seine Seiten zu ziehen , die mit  nur wenig Elektronik-Kenntnissen alle nicht ansehenswert sind.    Diese "Labs" sind dazu geeignet , den Glauben an FE OU und ZPE zu verlieren,  wenn das nicht die tiefere Absicht ist , sind die Seiten nur schlecht , da diese  kein VERTRAUEN geben.
Gustav Pese
P.S. Ich bin nicht "DER" Fachmann in dem Bereich ,
habe nur 50 Jahre damit gearbeitet ,   davon 40 im Bereich "Tubes" ? Vakuum-Valves" = R?hren und Halbleiter =  Transistoren Dioden SCR  Fets . Halbleitermesstechnik wie Entwicklung von Messautomaten.  Dies Wissen ist , indem Falle nicht n?tig um Obige NAUDIN Messungen zu beanstanden.  In fast keinem seiner "Setups" wird eine Ausgangsleistung zu einer Eingangsleistung  korrekt verglichen . Hier Voltzahlen zu vergleichen und von 200% effizens oder   Wirkungsgrad zu schreiben . Ist den Leuten "Sand in die Augen streuen" , denn wenn  keine Ampere dabei stehen (die ja kleiner sein k?nnen ) hat man kein VERGLEICHE :  KEINE VA = keine Watts.    Mir erregt die seid langem , sodass ich einen l?ngeren Text abgebe , damit "Newbies"  etwas nachdenkender solchen Schaltungen "begegnen" .  Mein "english" ist ausser den  Fachausdr?cken "unpolished" , weswegen ich den in Deutsch abgebe und "Google" ?ber-  setzen lasse , ich hoffe das der nicht schlechte ?bersetzt wie ich (was ich annehme  wenn ich "english to german " Texte sehe.)  So k?nnen Sie immer diesen deutschen Text   auch Ihrem Translator geben.
It is typically Naudin pears and apples to be compared. That its SEIKE reproduction does not only have to do nothing with SEIKE or FE. It does not result in Overunity, because it revealed in another left, already ?the fact that the transistors become hot (= DRAWS!!!) , and the frequency at first strongly changes to understand (without that it has to do with the heating. (Instable circuit!! Each transistor switching of its lab has four-ends errors and lack - it does not understand it simply! ) to the left gseav3.htm for example the following: 3. Picture = Setup #1 one kan simply in such a way do not measure.
1. is this analog meter with its inserted rectification for low frequencies halfway exactly.
2, is pulse voltages, Sqarewaves and mixture from it contained thus EVERYTHING, only no SINE, these devices is only ?halfway? exact for 50/50 cycles per second of SINE here. Here a ?TRUE RMS meter must ago?.
2a.Das do not measure not-sinusoidal tensions are times ?approximately? also identical to active powers in principle so in principle.
3. Further error is here that DC voltage additionally on the alternating voltage ?pushed open? becomes. That is called that by INTENTION or ?stupidity?, or excusing: ?Ignorance? for instance the ?half operating tension? Collector to emitter or minus is measured - as DC + an alternating voltage adds itself!! Which each electronics amateur handicraftsman auff?lt and understandable is. Even if here completely uncommon, or to ?verwiirung the Collector against basis is it is measured up to 0.7 V difference practical the same nonsense 3a. In order to be able to imagine this better, you see recognizing to the outer Setup #2 here you that DC portion of the circuit directly - over the diodes - on + and - the digital voltmeter to arrive. and the alternating voltage AC portion will add itself. The ?SHOW will not take thereby perfectly instead of the SAMWA similar instrument an expensive FLUKE Digitameter. The whole is to be pulled SHOW and UNVERSTAND around PEOPLE on its sides, which are not regard worth all with only few electronics knowledge. These ?labs? are suitable for losing the faith in FE OU and ZPE if that is not the deeper intention, are only bad the sides, since this give no CONFIDENCE.
Gustav Pese
P.S.
I ams not ?? the SUOER-specialist in the range,
but only 50 years thereby worked, of it 40 within the range ?Tubes?? Vacuum Valves? = tubes and semiconductors = transistors diodes SCR Fets. Semiconductor measuring technique such as development of measuring automats. This knowledge is, to complain of by case necessarily around above NAUDIN measurements. In nearly none its ?Setups? is correctly compared a power output to an input wattage. Here to compare volt numbers and write from 200% effizens or efficiency. The people ?sand is into the eyes strews?, because if no ampere stand thereby (to be smaller can) have one no COMPARISONS: NO VA = no Watt. Me those are excited long, so that I deliver a longer text, thus ?Newbies? somewhat more thinking such circuits ?meet?. Mine ?english? is except the technical terms ?unpolished?, why I deliver into German and ?Google? the over set let, I hopes that the not bad translated like I (which I accept if I ?english tons of German? of texts see.) in such a way to be able you this deutschen text also your translator to always give. ----------------------------------
