Magnacoaster - Vorktex
Started by kyler, August 03, 2010, 11:45:23 AM
bolt
Quote from: gyulasun on August 03, 2010, 06:19:31 PM
Ok, thanks.  One more thing what secondary voltage should the transformer have if I were to use a mains transformer at the input? 6-10V? 10-24V? higher?
Try a 120/240 or 120/120 or  240/110 isolation transformers.
Goat
@ gyulasun
Thanks Gyula for asking bolt the right questions.
@ bolt
Thanks for being straight forward on your replies to our questions.
Could we open a new thread for this experiment?  I would like to continue a conversation on tuning the circuit and other questions about the circuit there if you please.
Paul
bolt
Quote from: Goat on August 03, 2010, 11:03:35 PM
@ gyulasun
@ bolt
Paul
I was here to answer what i know about magnacoaster and explain his current situation and let others know the technology works. But as usual Trolls, drifters and saboteurs, drift past and try to tell ME that RE is all a pipe dream so i gave one example of many to think about. Anyone want more then read back through some of my posts.
So no sorry i don't want to start a new thread dealing with stuff i did over 10+ years but you can if you wish.
Honk
Hi Bolt. Just ignore trolls, they are everywhere.
I have some questions if you don't mind?
1) Is the LC circuit on the output, series connected or parallel connected with the transformer?
    But I do think you mean in series?
2) In your LC circuit, do you say there is no inflow of current at the 110VAC input to the transformer
    when tuned correctly while the lamp being fully lit?
3) How do you measure the voltage and current into the lamp?
    I'd use a series current shunt with the lamp and then measure the voltage across both the
    shunt and across the lamp by a two channel scope. Lamp wattage = Volt times current.
4) Have you performed this type of measurement to exclude power errors?
I hope you find some time to answer my questions?  ;D
It would be most valuable to all of us.
Quote from: bolt on August 04, 2010, 07:04:05 AM
Magnet Power equals Clean Power
So you're saying if I put a transformer and an LC circuit in series with my load I could slash power by a factor of 100. Would this also work on electric water boilers  :P .
