my version of the sqm
Started by kooler, August 15, 2010, 03:55:10 PM
stprue
Quote from: kooler on August 24, 2010, 09:05:42 PM
stprue
without knowing how the transformers are wired i can't say if thats right but i am going to post a pic below..
and also the driver you got may be to high of a freq.. i think it runs at 30khz.. you will need lower freq..
also you will have to do something that would be hard without a scope but you may be able to check the output of the aircoil with a meter.. you need as much voltage out of the aircoil as you can get.. with a scope you can see the very tall spikes .. that a meter won't show..
it would be nice if you have a driver that was adjustable with the freq..
i would love to have a function generator.. but maybe later if things get better..
below is how they have to be wired.. on the transformers are hard to get cause you have to know were the beginning and end on the windings are wound..
let me know if you need anything
robbie
Thanks Robbie, I will try this tonight, I will use one air coil and my function generator and scope it at the same time! I think you are right about the frequency....too high! If I can't get the transformers wired right I will try winding some torroids up!  If this deosnt have to be high voltage then 10-12v from my function gene should be fine but I was under the assumption that it the input had to be HV!  I also noticed no vibration at all.  More trouble shooting!
cletushowell
Im trying to help take what i say
and think dont take it for evidence
reverse the air battery to the zinc inside
like moray and hutchesion sonething with aluminum
and stainless he puts stainless run car
theres something up with the incandescent bulb were all missing
theres a frequency spiral put in the fillament
the energy is going thru the wire not out
some how moray backed the energy up
to go thru the wire we dont need a shit load of power we need
a injector of some sort that backs energy up
but pulses the same 60 hz forcing the
energy out the bulb this will be hard to understand
the wire fills the light with frequency
that frequency is not lost it has to be building
i think moray used his 50 bulbs
to back the energy up when you connect
one it stops the razor but energy is not stoped
its lowered working in reverse current
means thinking backwards using 50 bulbs
some how chokes the energy into the cells
now what should the cells be
well i beleive a light bulb inside granite
emits the frequecy of the bulb then the
frequency is stored in granite and then the wood
structure of the cell must have the perfect water
like air battery to stop frequency loss
he had a v on the end the iron
and then a plate of steel this must the force the
energy thru the 50 bulbs either in reverse or pulls it to the
iron out the Glass its crazy to jump a spark and not be able to power
unlimited lights tesla and moray busted this part
we havent I hope im helping if you can explain
what the vibration does I got my coils vibrating
but dont know why its important
tesla said frequency vibration and sonething else
how do you harness vibration?
Please email if you know this is pretty complicated
I know im pushing the limits of everything at once.
Till we bust this power the energy can be
manipulated to increase the amps thru one coil
i increased from .001 to 1.35
by changing wire direction thats huge but I dont know
how to harness the 1.35 amps going thru yet
the video will be up shortly hope this helps sorry its so long
stprue
No luck yet!  I have tried multiple freq's on my gene, biggo JT is a no go (not sure why??? over saturation probably), exciter circuit results below!
http://www.youtube.com/watch?v=uHhxj_WD6vc
blah...blah...
stprue
ok after playing around with this circuit today I have had some better results.  over 600vAmp/200vRMS/vAve3.2 or so enough to drive a floro at least. After disconnecting power I noticed a rouge spike...small but there!  Is this spike due to my scope being connected or is it something else???
stprue
Ok I am using much more powerful transformers rated to 2A.  This is nothing too special but using my gene at 9.6v I can produce some voltage and more importantly see the potential.  My next task will be to wind a powerful JT and use that instead of my gene.  Sorry for all the wires but I am using Koolers simple schematic above!
