a new kind of visible radiant energy?
Started by david lambright, August 17, 2010, 04:01:43 AM
do you like this topic?
yes, i will tell others about it
 no, it is BS
IotaYodi
QuoteWhere did you get the iron oxide?
http://alphachemicals.com/home
I took a 3 foot  3/4" flexible aluminum conduit stuffed full of iron oxide and wrapped 2 coils around it and energized it like a Pmh. Didnt see the waves but the magnetic pole orientation at different points around it is interesting. Its been energized over a month now.
What I know I know!
Its what I don't know that's a problem!
david lambright
Quote from: IotaYodi on October 27, 2012, 08:40:24 AM
are you using a battery to energize? try using only one coil when energizing, and reversing the battery, like first pos to neg, then neg to pos. i know you must have some rocks around, find one with some quartz in it, then hold the rock in the middle of the ring and turn it slowly. in low light watch as you move the stone, watch the edge of the stone , that is where you should see the  field. try covering one eye, it helps. use a compass when energizing, you should be able to get the needle to move 180 degrees, when reversing the polarity. i hope this helps
IotaYodi
Cant remember If I used a a battery or dc power supply. I think it was my dc power supply.  I have a sample collection  of small rocks and some Uranium ore. Ill check it out with only one coil.
These are the sample rocks I bought minus the Uranium ore.
http://www.xump.com/Science/GC-Sedimentary-Rock-Science-Kit%20.cfm
Good stuff Dave!
What I know I know!
