a new kind of visible radiant energy?
Started by david lambright, August 17, 2010, 04:01:43 AM
do you like this topic?
yes, i will tell others about it
 no, it is BS
sm0ky2
ive been running some calculations on noble gasses
it seems that krypton-chloride would give us the best reactivity with this radiation. im going to see if i can find some, in a neon-tube or something. round, like the letter "O" or whatever.
then build the device to fit the neon
i have this image stuck in my head of that thing from the Iron Man movie....
cletushowell
I already did that polarity i told you I have every antigravity
polarity email you see Ill send you the suit
i defined thr flying triangle too so it can be pulsed to one from
4 yoi guys are catching up fast check out my
self oscilating overlimt wireless dc
feedback system its tight as shit
keep up the good work email me serious ill give you the polarity for the suit
ch@record7.com
Rosemary Ainslie
Quote from: Low-Q on August 18, 2010, 05:56:53 PM
Looks to me it is used either a heavy or lighter gas, or a colder or hotter air. Any of these methods will show a similar effect in air and sometimes hard to spot. The tube can also be very cold or heated by sunlight and the changes the temperature of the air inside it. I cannot see the special about this yet, but maybe science havent discovered these effects yet...
Please correct me if I'm wrong about my explanation of what it is.
Br.
Vidar
Hi Vidar,  I'm actually going through this thread to get up to speed and saw this from you.  Apologies for not answering you before.
I think the 'light' or, as EF.com refer to it 'the Lambright Glimmer' is simply the most extraordinary property of this rig.  In the first instance it is absolutely NOT a schlieren effect - as tested and proven.  I built a version of Dave's rig and did NOT see lights - but I have seen that glimmer off a video on Dave's youtube.  I'll post a link again when I've finished here.  It is readily evident to some people - but apparently not to all.  And there are those, such as Bruce (who was the happy recipient of a prototype) who first did NOT see it and then DID.  Meanwhile his family saw it clearly and 'first off'.  Definitely elusive.  I wonder if we are somehow being 'educated' into a new sensory capacity.  But that's definitely off topic and I digress.  It just reminds me of those people who can detect the early stages of milk turning - and others who simply cannot. A kind of something that is 'genetically' determined - perhaps?  Just don't know.
Then.  There's the simple fact that any object - regardless of it's magnetic properties or lack of them - simply gets attracted or repelled to various parts of that rig.  And this much I have definitely seen.  It's mind bending.  The actual field on the rig has yet to be defined.  I'm going through some really involved tests to see if I can find this - definitively - but it's a long haul.  If one bears in mind the short duration of applied current - as required to secure the 'lock' then the fact that it should evince any kind of continued magnetic property - is extraordinary.  A small compass in the centre of the rig goes haywire - indicating that there's definitely a polarity or a magnetised condition to the rig.  But nothing actually 'sticks'.  Not even iron filings.  I'm still reasonably certain that the entire rig holds the secret to Leedskalnin's miracles at Coral Castle.  Somehow he used this force to enable his control of stone blocks that weighed up to 30 tons - I believe.  In fact the door to the castle may even weigh more.
But I think Sm0ky may be wise to exercise a little caution in getting this into full functionality (if there is such a word).  This simply because Ed died of cancer - and I would be very wary of what seems like some real energies.  We all know what happened to Madame Curie.  But - having said that - on the level that this is being investigated - then I also think it's relatively harmless.  Certainly I didn't experience any headaches or any harmful effects.  I'm still testing.  But I'm testing around the concepts rather than the concept itself.  I'm entirely engrossed in this subject.
Kindest regards,
Rosemary
Rosemary Ainslie
Quote from: Hope on August 21, 2010, 03:12:18 PM
If we are seeking physical work done from our devices, using electricity is only one way of doing the job.  We are going to have to design what will look pretty weird to the masses at first. But when they understand it is just using a newly (re) found radiant energy, they will comprehend it no problem.   Our normal electricity theory based test equipment won't be of much use to us, so I look forward to the new tools we will be discovering.
Well said Hope.  I entirely agree.
Kindest regards,
Rosemary
cletushowell
Seriouusly you guys are getting on my nerves I already gave you the whole code all the math here and on coral castle video the formula
and most important the carvings the
unified feild theory the carvings are the whole key
bit carving a radiated rock is fucking stupid
i finished his book I gavd you all the answers
polorise charge remove
circle the rock
remove to earth polorises it stop remoning charges it
then remove it to earth put frequency below lifts the rock
but remove excess weight by carving it
determine hoe much radiationit stores by the amount of moisture not yo much girls drop the rock by adding more watter
you can never move his castle till you move the capstone
