do you like this topic?
 no, it is BS
david lambright
smokey! ......mere words cannot convey my thanks....and i must say you are right, these devices must be tested to be "safe" as far as what energies are are being radiated....please be careful when replicating any of these devices....smokey, this radiance is something pretty interesting, i will think you will agree...did you get my PM that i sent?....if you have a working replication of my device, and you have "felt" the anomalies with quartz or metals, i want you to try something that will blow your mind, not literally of course, but you must keep an open mind, and you have.....but i think you will find this almost unbelievable!.......david
sm0ky2
@ Dave
This whole thing has been amazing to me. i have to admit it was a bit spooky at first. but i think ive wrapped my head around this enough times, that i dont need to go buy a geiger counter just yet..
im fairly certain this is on the tail end of the red spectrum, so its relatively safe. but there are a couple concerns.. i'll draw a picture of the waves, to show what i mean.
i dont have any good quartz,
what little bit i had collected over the years was turned into quartz powder when i was experimenting with quartz-doped
oscillatory semiconductors. (long story)
if i need to i can find some more.
What is this other amazing thing?
      have you done anything with aluminum?
sm0ky2
here, i didnt feel like drawing one. so this will have to do.
this is actually from a quantum light experiment, but the images look identicle, so here you go
an estimated assesment of frequencies involved here
your main three are going to be 281, 562, and 140 Ghz
that last one is potentially harmful at high power levels,
like standing in front of the transmitter antenae
but it shouldn't be dangerous from anything we're going to get off a 6 - 12 v battery.
i still have to cut the pipe segments, i may go about that differently, by just cutting a slit down one side of the whole pipe.
then cut it into chunks.
pry them open a bit.
instead of trying to cut the pipe into a bunch of 1/2 segments.
my small one concetrates the effect nicely. i fabricated it by hand out of a high-permeability sheet metal, with tin-snips and pliers.
i have it completely dissasembled. still debating wether or not to conduct these experiments inside an old microwave housing or something, to try and isolate it to some degree.
i also worry about interference.  technically the FCC has no jurisdiction over non-moving permanent magnets, but something like this may cause the rule-book on that matter to be reassesed.
what i worry about is it going to interfere with anything nearby..
like somebodies remote controlled device, or the neighbors pacemaker... is it going to cause abnormalities in my childrends DNA replication, resulting in cancer 30 yrs from now?
i dont have these answers completely. and this is like a little man on my shoulder telling me not to play with this stuff.
then i have this other guy, whos sitting there like " thats so KEWL! how can you NOT want to play with it?"
im still on the fence on this one, but im leaning towards
"relatively safe to proceed with caution"
i mean, i could wear a lead suit, and have all kinds of instruments monitoring my surroundings and do this with a 10-ft pole.
but then again, walking across the street in broad daylight could prove more lethal...
my free spirit tells me to go for it, but the little voice that has kept me alive for this long, says theres just something wrong here...
sm0ky2
Quote from: Loner on August 24, 2010, 01:53:33 AM
Not to sound too stupid, But I would like to replicate this, but have seen no plan or detailed description to enable me to do that.
Is such information available?  If on another site, please list a link and I'll run over there.
I'm VERY eager to see what interactions there are via basic electrical interactions, as in, what levels "Overload" these intrinsic ones...
Any information would be appreciated!  (I'm thinking inverse control...)
ok, FIRST you need to understand what the Perpetual Motion Holder is.  Ed Leedskalnin gave this magical wonder to the world.
its basically a metal loop, with a piece that can be open and closed like a switch. Ed used a seperate metal piece, called a "keeper", its like the bar you see across a "U"-magnet
a coil is wound around each end of the loop, opposite the gap.
and wound opposite one another, to form two electromagnets.
when current is sent through the coils, and the "keeper" is in place, a magnetic current will develop through the entire loop, holding the keeper in place. even after the electricity is shut off.
After you understand this simple concept
then go to Dave's YouTube page and watch all his videos.
he shows a few different ways to make the PMH.
its all the same concept, just applied differently.
this new device is modeled after Ed's wheel, found in coral castle
Dave added his own creativity to it, and discovered that it radiates energy.
its a very simple design, and Dave walks you through the building process in YouTube video. plus several other videos of him playing with it. I have to tell you, what you see in the videos doesnt do it justice, you have to see this for yourself. (all words of caution i mentioned above still apply)
This is Scotty demonstrating a PMH holding a 23lb weight,
    with magnetic current.
http://www.youtube.com/watch?v=_uZdEJALdiQ
and this is Dave's chanell
http://www.youtube.com/user/potatoheadist
Low-Q
A coil should not be able to pick up a constant current flow. This is the biggest problem of transformation of energy. Energy is dynamic potentials. If this potential is almost not dynamic at all, it is hard to harness anything at all.
A moving coil should do a better job in a static field. However, picking up energy will provide a counter force that wants to fight back. It will be interesting to see any result on this.
