do you like this topic?
 no, it is BS
david lambright
hi everyone!.....smokey, thanks for helping explain how to charge/troubleshoot the device....it really helps having another person to share their point of view...did you try the image thing i told you about?...it really does do what i say....it makes sense that this radiation is in the optical range and reproducing the image also reproduces the radiation from it!....and to jesus... i will send you a device by monday...i just sent one to jetijs in latvia...Ed was from latvia also!....i know that you guys will test these devices, and will find out more interesting things.....i cant thank you enough!...david
david lambright
Quote from: sm0ky2 on August 25, 2010, 03:38:05 PM
Quotei know having a center to the device enables you to make it spin.
but what im interested in are its solid-state applications.
i know that photonics technologys will like this energetic radiation...i think it will be easier to "aim" this with their latest wave guide tech.....remember my post about fiber optic cable/energy transfer at EF.....smokey, try aiming a laser at the device, holding it very lightly.....if you notice anything, please post.....and again smokey2, thank you.....david....i was only trying to quote smokey2s interest in solid state apps......the rest is my post ???david
david lambright
i posted this at EF PREVIOUSLY...................you know, an ED style PMH emits this same radiation, even with a steel U and keeper...just energize one and watch it. if you rotate the PMH slowly, you might start to see it, very, very subtle, like in the peripheral at first, then when you realize what it is, you start to see it easier and easier.....did you see the OU posts?...i am not sure if toner vs. oxide will work....the oxide works, with an aluminum tube....i am sending jetijs the device with the internal coil, sorry jet, but today, wed. aug 25, 2010 i will put it in the mail, i had to work late.....i wonder what would happen if someone wrapped a rodin around an oxide core device or now about using ferro-fluid inside a hollow aluminum toroid and THEN putting a rodin coil on it!.....i know you can get a magnetic lock/flow with off the shelf FF......a small C shaped steel with 3/16"gap, 20 wraps insulated wire, submerge gap in FF and energize...the FF will bridge the gap or magnetic lock, that is the lock/flow i refer to....smokey2s posts at UO might shed some light or radiation'....the fact that Tesla saw this type of effect is significant also.......david
sm0ky2
@ Dave
the ferrofluid gives me some ideas..
you could put it into a clear plastic tube
like those glow-necklaces.
be a trick to get it 100% full, but once you do and seal it up,
you could energize it, and have a liquid PMH
and see if there was any motion of the fluid.
or like i mentiond earlier, a solar-cell that can pick up IR light would be a real simple test that would clarify 99% of our questions.
If you could pull that off, and definitively prove the radiating energy, they'd put yur name in the history books right next to Rontgen, Becquerel, or Marie Curie herself.
cletushowell
Yes glow neclaces work I poweered my black light boat with them
in tub also a spral puls coil with a
tight wind around one wire gives it frequency
pulse propulsion the glow was pretty cool i use a
neon tube you need a black light no
phosphur interuption of double
reaction
