do you like this topic?
 no, it is BS
cletushowell
Wow spark that was a lot did I upset you
I already stated theres no negative energy
in fact the neucleus is not neutral either
2.1 is exact middle + two energies
- one energy negative is called one
but there is no negative I tried to explain
this the neuclues is the frequency
so what did eienstien split please tell
me a frequency hutchesion splits frequency
all day and even puts papaer through it
eistien split the hull of the ship put people in it alive
splitting a attom is a myth the nueclear bomb
is a myth its a way to get money and scare the shit out
people every country has caught on
theres no nukes every country thinks
theres nukes and scared to death some one
is going to build one they cant its impossible
to split the atom if you split 2 energies it becomes
1 if you split 1 it becomes 2
so ya they probly got really charged plutonium
radiated rods that have enough energy
to burn and melt but first day im on the Job
no fucking scientist is getting a penny for there hydrogen
bombs they call nukes if you split a atom
then you have particles smaller then the attom and a whole different
structure that cannot conform to the key so im telling you they didnt
split shit if they did prove it to me a gas tank blows up
that dont prove you split a atom
cletushowell
Beings your cussing ben your actualy right but
you have to think totaly backwards
the kite and key is not harnesing energy
is giving it to the water in air
its essentialy radiating earth but radiation
is realy removing energy which is why you sun
burn then blister first the radiation
burns your skin then the burnt skin attracts water
the kite and key was not taking energy
from the sky to the earth it was taking
energy from earth to the sky
haarp is the same its just wrong
there antennss are way to low
the energy comes from earth
to the capacitors then the capscitors
when i reversed the frequency of earth
on aug 14 bascicaly cut the connection of the grounding
rod by essential being no ground sending or discharging
all the caps to the space in reverse pretty complicated
essentialy that crosed the atmosphere because there was not enough
water to absorb it and sent it to the sun
which caused the solar flares and shut down soho
or however that thing is and haarp on
same days
cletushowell
I dont understand daves device or maybee I do
better then anyone the answer is the reverse
of the hutchesion crystal instid of injecting frequency
to lift the ice cream you polorise the ice cream
from the middle its reverse so your not pushing
it your pulling it but when you pull it just right
the polarity becomes the plasma feild
now if your inside that feild or on top of it
then its telepaticaly controlled
whe because you eliminated the
hutchesion crystal the external power source
so sending the frequency and
created the ice cream polarity to
receive and send its own
im not on the team im young and you guys are ahead of me
but I have the answers how you build it
determines what it does
Hope
Clet pls create your own topic,  and if you reversed the earths polarity on AUG 14th  then the magnetic containment fields across the earth would have been disturbed even disrupted.  So I doubt you did this, Chicago is still here.  The anti matter created and stored there is still there.  You need to see a doctor or get a vacation.  Please create your own topic...... stop leeching attention off this one.    If we are interested in your discussion we will comment and view it.
Hope
Update on our efforts to date,  the pipe pieces all cut and slit.  To widen the slit to 19 mm we drove a wood splitting maul into the slit forcing it open.   This method bent the pipe unevenly.  The sides touch but not as they could if they were uniform.    The ring hasn't "locked" even with repeated attempts.   But one interesting effect has been to repell my friend who worked hard on this device  (not good).  The pipe we used is VERY hard and maybe the problem.    At one point I did have a effect on a swinging magnet, it settled down from a swing to a spin which took along time to stop.  I wonder if anyone has wound the copper coil around the diameter of the ring and energized it "locked"   will it interact with another ring then?  Many times the thought of 90 degree angles of chain links must be a key to stacking magnetic charges. Does anyone get this feeling also?   Ed Leeds.. was very thrifty, if chain was able to do it...  well he had plenty of it.  Does anyone have 2 PMH idenitical made to try a 90 degree experiment with?
