do you like this topic?
 no, it is BS
sm0ky2
@ Hope
The pyramids, before egypt was conqured, and them ramsacked..
had a layer of limestone,
and the tip was coated with Rose Quartz.
These were intentionally removed and destroyed.
Their design caused a natural charge-imbalance between the inside and the outside.  That grew in intensity during the daytime, and fluxuated with cosmological periods.
the inner dimensions focused this charge-field into the center chamber. Where the arc sat (there were at least three of them)
The arcs thmselves, were like a "square capacitor"
with one of its plates the inner diameter of the box, the other around it. It had a charging period where it would be placed into its cradle inside the pyramid. Before it was used in battle.
From what i have decyphered from ancient texts and the depictions illustrated in carvings from around the world, i believe this energy was a static-electric phenomenon.
"lightning in a box", of a magnitude that Tesla himself never dared to tamper with.
cletushowell
I got it to flim its like prodject rainbow if you know
what that is the philidelphia experiment produced a green type gas that green type gas is in my water where it cones from
i dont know im my cup antigravity i made the black rings too
tesla black rings dont ask me what they do
but i bent light havent lifted this rock and going to sleep on it i think
the outside layer if the rock is like a egg shell
it does not allow the fluid to go out
when i cut the last rock i notice it was more porus on inside
so maybey this rock will get a hack job
or maybee ill test with the little ones i cut last time in my cup
instid of big in my buckets making the energy a lot easier
thats a good idea well have a good night till tonaroe
tge world will have to wait on superman to
rest in the batcave and find the answers in the data down load
the sleep its in there somewhere im trying to make
of my failed day i dont take failure easy
oh you want to solar from lead plasma so te sokar cell can be better
im not giving you the uvc uva uvb
but sunblock is interesting
anyways na= gold ,mg=gold,al=onix,silicon,indigo
ya its been a bit since i did those so
i probly should made better notes the seven candles
3 finishes theuv abc=7
cletushowell
Na = lead
mg= gold
al=onix
silicon
lead-silcon better solar the great pyramid formula was the periodic table elements
rev 21 fuck i forgot
19 potasium
pure gold unto clear glass what is periodic table 18
rev 21:18 is it like argon i think i forgot well goodnight
the great pyramid just need the potasium and salt put back on top
better find my notes on the video
david lambright
some info about PMH and icing technique to see energy field around it...Hi all
@ Harvey
Yes what i mean is to install your camera on a tripod and than spin your device and let it winddown until stop.
Thank's for the pix. If i see correctly in the middle of your ice bloc you have a part which goes up (expansion)and just near a part which make a hole (contraction) ? is it right ?
@Sucahyo
How to check if it is orgone . Any idea ?
I will try to electrolise the meltdown water to see if it is better as the original tap water. And poor some in a plant. Who knows
@David
Yes bravo for your dad.
Yes good idea to try to put the pmh near a glass of water and freeze it
And thank's for your input.
And now some very interesting results.
pix 1 is the set up with orientation in my freezer. Notice that the pmh is put on a rubber about 12 mm above the bottom of container. The charge input is 12 volts one or 2 touch.
pix 2 is the view of the icing from the bottom (for easier representation i have flip the image to have the same view as pictured from above.
notice the red arrows show zones where the ice is very clear but not thick.
the blue one show zone of expension thickness.
very complex flux indeed.
pix 3 is the same but more contrasted and i have marked the relevant points.
pix 4 is a side view showing clearly the 2 small monts with the small valley.
pix 5 shows a top view during the meltingdown, and where you can see the more thick monts upper right
Awaiting your comments
good luck at all
Laurent
gravity-waves-found-pmh-setup-orientation.jpg  gravity-waves-found-pmh-upsidedown-less-contras.jpg  gravity-waves-found-pmh-upsidedown-view-1.jpg  gravity-waves-found-pmh-monts-valley.jpg  gravity-waves-found-pmh-melting-down.jpg
woopy
Hi all
I have seen that David transfered one of my post from EF to here.
but the pix have not been transfered so i enclose here under
on pix 3 and 5 i have also mentioned in green the 2 small montains.
in one or 2 hours my new icing experiment will be ready (it takes more than 12 hours to completely freeze ). This time it is the same set up but the PMH is disposed vertically wit the same orientation .
so perhaps i can get a better 3D image of the flux arroud the PMH.
OK thank's David for transferring
very exciting thread
and good luck at all
Laurent
