do you like this topic?
 no, it is BS
sm0ky2
Just to kind of show everyone where im going with this on my next build.basically i have Two stock-pipes, one is 1/2", and other is 1"
center-split, and then im cutting them down into 1-inch segments.
The goal is to have a large ring, with a ring of smaller tubes inside. outer tubes, slot facing outwards like Dave's, the inner ring will have the slots facing inwards.
So far i have the inner ring cut, and a few pieces of the outer ring. just need to cut a few more pieces, then file everything down smooth. and sand them down on the parts where they touch.  Here's some photos so show the process.
Dave was cutting his pipes in half, then bending them back into a round shape. What i found was that Center-Splitting the pipe, keeps it in a round shape, then the most bending you have to do is just a 'widening' of the gap, if they are too close together.
cletushowell
Hope i dont think im much help
maybeee I am but work with me a lot and
ill figure it out I dont have a scop and never used
one but doesnt mean i dont hace a general undestanding
of whats going on in fact i think i could possible draw the lines
witg no scope but thats would be interesting
possible maybee.
Any ways ill tru to put in what i know
if the wave bounces 3 3 3 3
it alws stays .0021 mv
on its own hooked to earth given
my earh battery was perfect and the
now no mater how many 3 you have your voltage is
.0021 so i thought tesla magnification
if 3 wave is not added to the 6
the wave is not increasing
so instid of 3 3 3  i changed the
coils to 3 6 9 now the wave can
expand or add to its self as it goes
now from my math it should have squared
the power magnification not doubled
it but it didnt double it did square but
not like I calculated it times 1000
i hope im putting these right it went
.210 mv and was stuck but still
.210 is 3 but a 1000 loops more
10 is 1 loop i proved this in my
making my brain one energy not possible
but i did 3 finged in a pyramid has three loops
on my perfect square wave with these spirals through
it it will make 3 loops on one hand
3 3 on otherhand 6
to the two temples a 2 the two sides of the body
and wait the waves oscilate the brain
till it becomes one jumped the gap in the brain some how
dont ask me why it was just so interesting how the loops matched
the metter i was just kinda playing around
i did do a video on my youtube demostrating that
so the 369 is only 1000 times the energy
because i went 12 15 18. 21
no increase at all after the 9
always .210 i was stuck on this a few days
aug 13 fri 13 14 15 or
so i dont rememver exactly when but i know
every time i was testing that thing
it was just mv but i got so frustrated
i stoped after three days or so and read
the guys web stuf who was helping on explaining the documents on
teslas earthquake i found two things
the .210 tesla calculated to go around the world
i said holy shit i looked up eartg quakes and shure
enough marina islands 6.3. 6.6 6.9
teslas 369 and 666 it hit exactly on grid line 12
the quakes landed on12 but came out earth
like a clock 3 oclock 6oclock 9 12  put me dead in the middle
but it has some effect on the power grid
i think the power grid here goes to
sandiego power plant im not shure
but i know it put the grand canyon
like perfect between the marina island
trench and another part of the ocean
so the power does not multiple in square
but by 10 .0021x10 x10x10 1000 times
but it does not matter how many volts input
its not inputing inoutputing to earth so even if your metter read
120 volts coming out .210 is going to earth
your funneling the frequency from air to earth
2.1 is actualy the exact center i prove this in my
attemp to lift this rock but am not posting those
because there kinda imbarasing
but the rock draws a perfect 2.1 amps
dont ask me why its not the small rock im my
antigravity stuff i just put out but
a big boulder i downsized
here is my understanding of things
you cross the9 with a 1 then you hit
88 sweet sixteen theres two energies
the north chases the south
in a circle but when you get the north
and south seperated like i got my rock making or producing the gas
i put shit load of salt on it the garnes to stone soup
i knoticed that the electrical tape slows the oxidization
down of the aluminum must be what ed referes to as rubber
and white powder im just going of question people as i dont have eds book
but when the north and south circle
there has to be a way to stop that circle
that directs the flow from the rock the positive to the
neutreul mine did get closer but did not lift the rock it shrank the
2-litter exatly half i knoticed and understood hutchesion
is doing now the wire and rock in my bottle were the nucleus of the bottle
they were fighting energies because one wire was on bottom one was on the top when the energy lined up instid of
the warp from point a to b its warped a and b
together by shrinking the box the 2-litter
so in terms hutchesions power supply is enough
to alter the nucleus to go from a to b
but the box has to be stronger then the material
which is why i beleive he lifts ice cream and max i saw was a 75 pound ball
that a box could easiely hold 75 pounds will not collapse a box
in fact im kinda wondering what amount of power could
implode a box from inside maybee this is why
the a frame his a frame had side braces
what im trying to say is the box has a unique charateristic
the would not change with specific gravity
if you pull evenly on all parts of a box from the inside
i dont beleive any amount of energy can break or collapse it
as long as there equal this is a very interesting
question anyways im off subject
if all material has e and f energies
you imput enough e it will eventualy
become a e and warp to f
but this is where your power really comes
in once to f it only takes one f to send it clear back to e and one e to send it clear back to f its no longer the amount of energy
originaly input but just one so if you have 10,000
attoms of e and f and it takes a lot of energy to make those
all e once there all e it will go between e and f
with the change of only one the ballance
by inputing freqiency hutchesion is overiding the e
making it all e and go to f but some how
hes not doing it perfect hes interfering with the atomic structurcture
itself the electrons and protons
anyways i wrap this up by saying
moray used a antenna and rock
and water
ed used water a rock and a generator
possible radio antenna stuf on wall
hutchesion used radio waves
all used a box
tesla is only one who defies all this
logic but I have not understood or study teasla
antigravity
the joe cell uses water and antigravity
I really confused on which way to go
hutchesion is facinating i dont see no free power
I think if i had his help I coukd do miricles
tesla utilized the power very effeciently
moray and ed I beleive are the free power
well tesla has free power but cannot be harnessed
the unlimited coils i did its not controlled
im missing something tesla did to controll
it the tubes the caps not shure probly a combination
theres one link to all of it this i know
sm0ky2
Teslas "anti-gravity" was not the same. it only works in 'ionizable air'. He discovered that at high enough potentials he can cause a distortion in air, similar to water-pressure.
the outside air pushes on the field, and the field pushes on the air. By distorting this field, he can cause motive-force.
Expanding the field on one side, and condensing it on the other provides a force in one direction.
Some people have come close, creating small "electrified platforms" and whatnot, that fly a foot or two off the ground.
but they're ony dealing with about 1MV,  whereas Tesla was known to play with 7 or 8, which, in AIR that changes everything around you.. not to mention all kinds of crazy sparks if you dont control it.
cletushowell
What i beleive is the weights and measures of life is the 8
the ballance the
56,000/9/6/3=1234567910
144,000/9/6/3= the missing8
so if you can send 1 8 back and forth
you dont need much energy at all its the perfect
ballance naturaly so you dont need to remove all the numbers
to make say a 2 go to a 3
you can just make all numbers go to 8
or from 8 how im not shure
cletushowell
Ya i see like edds rock with invisible air bubbles arouund them i think that may be my problem the energy is not going back to the bottom
but side of the rock then instid of pulling it im
the plasma flow the plasma circles
around the side where it getting the energy
im going try to test again my dad
was being a jerk again my lifes pretty hard
right now but till we break free energy
our whole generation is going to continue to be slaves
i remember riding my gocart for days on 50 cents
not no more kids dont even get go carts
or the fun to be able to ride them there lucky to get food
on table or keep lights on its really bad here
people will work all day for a pack of cigaretes
two three incomes cant support a house
anymore not in california im trying keep my head up and pray
we have a breakthrough in energy soon.
