Can some explain how to tune oscilation from tesla 369 earthquake 2 power
Started by cletushowell, August 17, 2010, 11:55:20 AM
cletushowell
Basicaly i already did the moray valve the
tesla earth quake but im stuck on tuning
it self oscilates to whatever its around
but the problem is moray tuned his now mine peaks the metter
when i remove it or touch it just right
so if it was tuned to the right frequency
the it will be unlimited power instid of earth quakes
now if you say shit before you research
your going to piss me off i already have the data from the quakes
marina islands and there still going so
aug 13 i started testing it and been going ever since
even though i took it down i did not know .210mv
was the exact time tesla calculated to go thru earth
when i saw that i checked and yes
6.36.66.9 7.2 and over 30 so far
so i need help adjusting the oscilations
heres the math and videos
sorry the goverment took down the
good one watch them you see
ill try to post again
We all have over unity just no one
understand what tesla did he fucked
jp morgan when jp morgan cut his funding
he spent the rest of his life not developing
the best motors the ion propulsion
tesla turbins but the 369
power grid that turne the united states into
a super battery charged with 1000
times the energy we used over the last 100
years he seperated the frequency of air and earth
with 3 prong 6 coild nine goes to the ground
at 1000 times the voltage so we now have a giant battery
the goverment cant discharge
with coils of 8 the energy is magnified forward
used then recycles to the first coil the frequency matches
so its a continual energy builder it has to go forward
ill do the math again
3691888888888
ok so your taking the 369 out first
1234567910 but thats odd number
your polarity cannot go back to
369 ever with out taking say 90/10
= 9 an 10 so the nine can go back but the ten
goes to the 8 side the shorter and more powerfull
circle look the energy wave in the air
is not 0 its 200,000 but it cancels so fast essentialy
the speed of light it apears 0 so you have to seperate
the square waves by manipulating the power between the wave to
magnify forward and the circle that back but dont cross the axis
of 1 the seventh day god rested it cannot go back
only forward.
88=16=7 but 16 cannot go into
369 or 1-7 and seven is 1 and 7
its the 7 bend the one coil
so it has to go to 8
888 24 cannot go to 369 or 1-7
24 coil and 8 coil is not made yet
8888 32 = 5 32 coil is not made and when it does
after ten these start to self oscilate
back to the 8888888 side never to the 1-7 bends
or 369 coils
so its seperating the power
now you just get the energy going it will always go
but i need help getting the peak tuned
i crossed the 7 day with 1 coil.
This one coil busted marco rodins math
because 3691 anything after that is even number
3+6+9= 18+1 19+ 3=22=4
so the power is no longer circling
9 back to 3 and6 but the 1 circles all the power
back to 8 which is all numbers
88=16=7
      24=6
       32=5
       40=4
        48=12=3 but it cannot reduce to a odd
                   So it goes back to 4 and 8
         56 11 2
         64=10=1
          72 9
          80= 8 so now all your numbers
After this anything you use in this coils of 8
is never wasted it recycles thru the 8 coils always
infact i seperated the 369 to but till i get to use that no one does
heres the videos the gov took down the
math demonstration vid
http://www.youtube.com/watch?v=mzQVpsMllrc&feature=youtube_gdata
http://www.youtube.com/watch?v=mDYCHXt1JBs&feature=youtube_gdata
http://www.youtube.com/watch?v=GhRIGv0hGJs&feature=youtube_gdata
Check out this video on YouTube:
http://www.youtube.com/watch?v=jrNMMry4T4c&feature=youtube_gdata
The Observer
Cletus,
This is how it's done...
Wink 368 times while jumping Tesla's final test wire to the beginning of the Sheep's Wool multi Coil  Segment.
On the 369th wink you must twist a Diode with a Large Transistor during the charging phase of the Transformer.
The last step involves melting a Resistor over your OU setup while sticking a 1.2 V Rechargeable NiMh Battery into your Rear cap-Ass-itor.
The result will be a bonified tuned oscillation from a 2 power 369 Earthquake Receiver. (like the one in Basement)
Best Regards,
                        The Observer
The Observer
Cletus,
On the 369th wink you must twist a small Germanium Diode with a Large Transistor during the charging phase of the Transformer.
The last step involves melting a 17k Resistor over your OU setup while sticking a 1.2 V Rechargeable NiMh Battery into your Rear cap-Ass-itor.
The result will be a bonified tuned oscillation from a 2 power 369 Earthquake Receiver. (like the one in my Basement)
Best Regards,
                        The Observer
Low-Q
You forgot the missing link between the apes and the humans - the birds. They could not fly but was great at driving camels through the North Pole. These birds must be the link between Teslas last wool wire transfer function and the ground wire, in order to keep the 369 feathers in place. The last 8 digits divided on 12345910 equals the amount of OU you need in order to cook a 5kg chicken in only 2 seconds.
This is the only way to tune the oscillation Tesla hybrid earthquake wheel... If not, the equator would cross the south and the north pole. Then all the ice would melt down....
cletushowell
Well that interesting please do email me
the diagram and ill send you the code to make 369
10 times the power but still seem complicated to me
i did figuge out 3 fingures on each side
makes 6 on probe
one side to each temple makes 2 sides of brain
wait about 10 seconds the brain becomes 1
now thats pretty weird shit and then 26 guage
sheet metal gives me 26 volts so
im going to get a feeler gauge
see if i can just tune it thru the guage
of steel make it easy but im still interested in your circuit
as im not using no caps no batterys no diodes
just changing frequency
