Can some explain how to tune oscilation from tesla 369 earthquake 2 power
Started by cletushowell, August 17, 2010, 11:55:20 AM
cletushowell
Im on my phone  so punctuation
is a pain everything goes thru gov
first then it either post or i get a death threat
back i try to by pass these gutless jackass by
switching computers and places to down load
look the spiral at 36 volts has to do with the plug its tied into
it has a metal conduit with 58 spirals
minus my 8 8 8 coils so the 888
counts down
88=7
888= 6
but consecutive spirals go up some how after
that but you still need the 8 s
im going to try to swith it to a plug with bigger
spiral conduit
anyways i switched the dc power supply the voltage is the same
so theory says from one video i did dc goes in
ac comes out so if there a dc converter
you get volts ac if theres a ac converter you should
get dc put one one each side should be exactly parrale
in middle again at any voltage not just .210
cletushowell
So if its right should be able to duplicate it like this
the rod to earth with a metal sprial
conduit over the rod at the exact wind you want a dc
converter from the earth battery and then the negative to the square spiral
should give you exact voltage
cletushowell
Basically what im saying is the rod to earth
battery is the magnet the coils around the rod
equal the volts 1 wind per volt
so taking the power off the end is wrong
well not really you do need the end but it circles
back thru the coil around the earth rod
giving you contious voltage in my case my
so your not steping up the voltage with the circuit
the circuit is the voltage sorry doing my best
cletushowell
So got over 30 at between 52-54
i figured it out soon we have free power
ac to dc but i was at 5 volts dc
so could not figure out the oscilstions
well I did the black wire oscilates the dc
at 50-60 hz that oscilates the negative wire
times the dc volts 5x60 roughly. 30
volts ac
so i steped up my dc to a computer charger
18 volts should gave me roughly 108 volts
but it didnt it got stuck on the oscilation
of the 50-60 hz so how do i double those
oscilations to 120 hz then 1 volt will
give me 120 volts contious between ground
and neutral and goverment can kiss my ass
cletushowell
So bust your jokes now the rookie just scored a Goal
and so the fishes tail is the oscilation
making the energy of the fish magnify
by the vibration
of the fin
and the huming bird by the pulse of the wing
and the ant can lift 50 times its weight
due to vibration of the antennas.
