small tesla project
Started by salty58, August 18, 2010, 10:58:51 AM
salty58
i am making attempting to make a tesla using two disposable trigger transformers wired together which are then connected to a cockroft walton circuit my problem is how do i wire the trigger transformers togther .can i just connect the two outputs together and connect it to cwm circuit
Trastos
Quote from: salty58 on August 18, 2010, 10:58:51 AM
Please, define "tesla", and post the diagram, i'm sure that we can help you.
This circuit is a voltage multiplier, be carefull with this. You need specify if is Simple Wave or Double.
salty58
it is a stgc circuit i am trying to make using 2 camera flash boards with the outputs of the trigger transformers going to a voltage mutiplier circuit .just not sure how to connect the transformer  outputs together not sure but i think it will be a simple wave
saw a similar by johnny davro on the net
nievesoliveras
Trastos
Quote from: salty58 on August 18, 2010, 03:12:17 PM
why two?
i think that, if is a simple wave, you can connect the output of flash camera in the input of your voltage multiplier, because the multiplier input is AC current , you have to look what are the correct terminals on your flash camera.
forgiveness, is better documented nievesoliveras, and more faster ;)
