Parallel Path Magnet Motor
Started by scianto, September 08, 2010, 02:50:32 AM
scianto
Here is and example of how parallel path magnet motor can be run on unidirectional impulses. I never before saw it functioning like that, because normally it has to be powered by impulses of alternating direction.
Here is my new toy.
http://www.youtube.com/user/scienculo?feature=mhum#p/a/u/0/_Ii6_mKO92Y
Low-Q
Quote from: scianto on September 08, 2010, 02:50:32 AM
I am experimenting with PPMMs. They are build according to PPMT patented by J. Flynn.
Some of the tests are on my channel:
http://www.youtube.com/scienculo
Any suggestions, co-operation proposals etc. ?
Maybejovich you should speakowitch Englichova please? Nice machine you got there anyways :)
scianto
This example shows, as far as I understand the oscilloscope traces, that parallel path magnet motor can be run and function very well, when it is powered with only unidirectional impulses. So, no transistor H bridge or other circuit producing alternating direction current impulses are needed, as I have thought till now.
http://www.youtube.com/watch?v=RxhJlKuZgfA
In this example you can see, that 50% of the cycle the motor winding are pulsed and the other 50% of the cycle they generate current. What is most important here is, that the generating current is powering the motor, so it created the other 50% of the cycle running the motor.
Theoretically it means that half of the power is needed to run the motor compared with circuits running it with alternating current impulses.
Note it down and use it with other motors. Now we know that DC motors, pulse motors and even 3 phase induction motors can be run using this kind of powering.
Now you can call it tuning and saving as much as possible but still run motors at that give same amount of power on shaft.
scianto
Practical implementation.
Here is an example of a small parallel path magnet motor turning a bicycle wheel, that I did yesterday.
http://www.youtube.com/watch?v=gYzfF7aPacY
scianto
I am using this circuit to drive parallel path magnet motors, also the one build in my bicycle:
http://www.overunity.com/index.php?topic=10387
Please, try it with your motor, tell me how it works.
