FUELLESS CAR PROTOTYPE by ISMAEL MOTOR
Started by luishan, September 08, 2010, 11:50:07 PM
tagor
Quote from: ramset on February 22, 2011, 10:38:28 AM
Stefan
Do you have a phone  number or address for Ismael?
I have a friend in the Phillipines I would like to give it to.
Thanks
Chet
http://www.ismaelwater.com/contact.php
mscoffman
This guy is making a bad mistake by having it tested installed in a vehicle.
The primary important questions for a power supply are:
a) Does it work?, b) Is it safe for life around it?, c) Does interfere with
Radio frequencies?
The important secondary question of utility is: d) Does it operationally interfere
with copies itself?
Irrelevant questions are but those that are going to be ask because it is in a
vehicle are:
e) Does have a high horsepower slew rate?, f) Can it operate at extended power for
long hours?, g) Can it survive 100Kmiles on the road?, h) Is it safe in a 20 kph. collision?
Now the government panel can either not force the answer to some very important
questions,  or else look like idiots for approving something that is not at all adequately
designed for a vehicle.  Which will it be? Don’t worry though, a Billionaire can still
make money while having this idea thoroughly emplaced on a shelf.
Here is the thing; I think the a person who engages in lack of honesty and
information hiding even with "denyability" should be expected to economically
sell out. Once again the experimenting public gets an enticing summary but
with no details, the billionaire gets to make a profit, the inventor make claims
of inventing applicable technology that really isn't. And nothing really changes.
:S:MarkSCoffman
ramset
Tagor
Sweet!!
Thanks ,I'll make sure my freind gets this!
Chet
Thanks Grandma
hartiberlin
Yes, I also think Aviso should not concentrate on cars,
bust just show an overunity power supply.
Okay, it can also be used for cars, but this
will mostly wake up the wrong people probably.
Did you all hear the new interview with Sterling Allan ?
See:
http://pesn.com/2011/02/21/9501769_How_Aviso_extracts_energy_from_surroundings_to_power_his_EV/
and here is the interview:
http://www.mevio.com/episode/270096/fen.110221
So, it was a bit hard to understand for me as the phone line had some hum
and the accent was a bit hard to understand.
But what I gathered from the interview was the following:
He uses low impedance coils to discharge caps probably charged up with high voltage.
This way he creates very big oscillations and the oscillations probably have a high Q factor
as there is not much resistance in his LC dicharge circuits, so he has big oscllation amplitudes.
As he is also using low impedance ( low ohmic resistance) coils, he also can switch
the current very fast. He is working in the 700 Mhz to 1.2 GHz range....
So this is a frequency range, where you need a lot of experience and also need expensive
m
measurement equipment to be able to see waveforms on a scope for instance, so
it is not really easy to working with such high frequencies.
Also it seems he is then creating a carrier frequency from this discharge ringing
and this seems to convert environmental heat energy from the surroundings
of the coil into electrical energy.
Well, as this is already a very low infared frequency range so to speak,
it might be possible that he just taps into heat energy and cools it down this way.
So probably his coil cools down during this process and converts the heat to electrical energy.
His "special transistor" is just an array of cheap MOSFET transistors to replace expensice IGBT devices.
So if he blows up a few MOSFETs it is cheaper to replace 8 x 1 US$ MOSFETS than buying 1 x IGBT at 250 US$.
But how he is using them at 700 Mhz to 1.2 Ghz is a puzzle to me...
Are there 1 US$ MOSFETs that can switch this fast ???
Maybe if you did understand it better than me, please add your comments what you heard...
Many thanks also to Sterling  who did this interview.
Regards, Stefan.
hakware
@hartiberlin No there no 1.00 mosfets which can be driven to the 700Mhz range.
You can gang the mosfets up to increase the power capability as you well know, but you also have to drive them pretty hard as the gate capacitance become much larger and harder to cause a hard short.
as far as the 700Mhz, IMHO I dont know if that is really going on or if its more of a realistic frequency like AM broadcast mixing or possibly something of a lower frequency. The coil in his video's is far too large for 700Mhz to resonate in any matter.
as far as heat conversion he claims that he cant run it too much because the heating will burn it up. So lets not get ahead of ourselves on how this thing converts/extracts energy yet.
If I understand him correctly, What he is doing is exactly the same process IE, "secret sauce" used in the VTA, Marks coil, Cooler and quite a few other EM devices we have seen over the years.
Kent
