Aluminium Graphite Fuel Cell
Started by Poit, September 12, 2010, 10:54:11 PM
jeanna
Hi Pete.
I think you found your answer.
It was really close with the first one, but when it is so close but won't start and maybe should, I place a memory cap in parallel with the battery leads.
So, you would use the pos of the memory cap hooked to the carbon and the neg to the Al (or Zinc or Mg, for that matter).
I bought some of these caps from allelectronics a few years ago at $3.50USD. maybe they still have them.
But the nearby dump might have a motherboard that nobody has picked clean yet.
Mine are 5.5v and 1F. On the plant battery that produces only 6mA , this cap could take as long as 30 minutes to fill to the running voltage of the transistor. After that the light goes on.
My explanation of why this works is the cap fills to the on level then any tiny amount more than that and the circuit will turn on.
Some batteries like the TT Brown or Hutchinson  crystal cells that Ian made, or the first 3 weeks of my 'phyllis' plant battery made from magnesium stone only blinked.
The possibility exists too that the joule thief takes volts and amps for such a little amount of time that there is a squeek extra from each cycle.
In my 'phyllis' plant battery with the Mg stone, the flashing became steady after about 3 weeks!
It is still going steady after some months. It started on the 25th of March and here it is mid september and she is still a steady light.
I love these home made batteries.
In fact these can better define a good circuit design since the amperage is so limited.
Lots of talk, I hope you don't mind.
Maybe it can help.
jeanna
dllabarre
Quote from: Poit on September 13, 2010, 06:45:39 AM
I made another one, twice as big, works great with a jt and led now... is there another cheap form of graphite (or carbon)? I know that certain battery types have a carbon rod. Ive also heard that a black n decker replacement brush is good too... surely there are other "everyday" items out there that can be used in these fuel cells... any ideas?
pete
p.s thanks for your input thus far...
There are carbon welding rods that I get from the local welding supply company.
Some come copper coated but the copper peels/scrapes off real easy with a sharp knife. Mine are 3/8" in diameter.  Be careful.  They are fragile and can snap in 2 real easy.  Believe me I have several small pieces laying around  :-[
DonL
Poit
someone said in another thread that these "batteries" are not batteries they are generators, because they can't be recharged.... got me thinking..... screw all of this!!!!!!! im going to build lead acid batteries...... i mean.... why the hell not?? lead is free/cheap.... sulfuric acid is.. well, can't be that expensive right? you only need 30% any ways..... i just got home after a 13 hour shift at a cloak room - music festival with 20,000 people there :(.......... bed time
ResinRat2
I am no battery expert, so please take this as just something to think about.
12 volt lead-acid battery technology has developed over decades and decades. All commercial battery manufacturers have financed years and years in the design and materials research. They have been pushed by financial and market forces to give you the longest lasting, most reliable product they possibly can at the most reasonable cost they can. They also are driven by market safety forces as well. It is in their best interest to give you a safe, reliable product.
Now, keeping that in mind, do you really think it is worth the risk of dealing with building a lead-acid battery from scratch? The acid mixtures are hazardous both in fumes and in to the touch. Even commercial batteries have been known to explode. Hydrogen and oxygen gases generated need to be expelled or dealt with safely. What electrodes are the best? How do they hold up over time? What case design is best? What materials don't turn brittle when in contact with concentrated acid?
My point is that in our quest to "stick it to the man" we need to weigh the risks involved.
Now, maybe none of this is a problem for you. Maybe you are highly experienced and intelligent in this area?
Please keep these things in mind.
RR2
Poit
Quote from: ResinRat2 on September 18, 2010, 12:23:04 PM
RR2
If what you were saying were true, why is the cost for a 12 volt battery so darn expensive? The most expensive example I can give is for an on-site delivery of a 12 volt car battery if you have broken down in your car... $180..... $180!! for what? 20 - 30 cents worth of lead and $1 - $2 of sulfuric acid if that...... so im paying  $179 for the company to make such a battery? and for the guy to install it?
I would rather risk blowing my self up if I could save $$$$$$$$$
A well ventilated room with hundred of home made batteries is ideal for two reason:
1: save crap loads of $$$$
2: when the lead plates "worn" or dirty, one can clean and repair easily....
there are a LOT more benefits than down sides to building your own lead acid battery
