Copper Zinc Tap Water Fuel Cell
Started by Poit, September 16, 2010, 02:38:26 AM
b_rads
Can someone please explain this to me.  Using the batteries shown in www.overunity.com/index.php?topic=9752.10 I tried the following experiment.  I connected a 12v Lawn & Garden battery as shown in the picture below.  Logic tells me I should expect the water batteries to gain a little boost and the L&G battery to drain.  When I first connected the L&G to water batteries the Voltage read 9.97 and the Amps with meter set on 10A at 0.09.  One hour later the meter read 10.23Volts and 0.09Amps.  Two hours after starting the meter reads 10.37Volts, and Ten hours after beginning the meter reads 10.31Volts.  I failed to get a standing voltage of the L&G battery prior to starting the experiment however, two hours after disconnecting the setup the L&G battery reads 10.71Volts.  The water batteries started out at 1.64V and the amperage was negligible.  When disconnected, the water batteries read 1.85Volts and with the meter on 20mv it reads 2.12.  The next time I try this experiment I will get the standing voltage of the L&G battery before starting.
If someone knows what is going on here â€" could they explain it to me?
WilbyInebriated
Quote from: b_rads on February 10, 2011, 04:02:56 PM
so actual voltage of the l&g 12v is unknown and you were using it to charge a bank of 3 copper/zinc cells that were approx. 1.6v each making a bank of approx. 5v?  and no diode used between the l&g 12v and the 5v bank?
b_rads
@wilby
The 3 cells were connected to increase the voltage for a combined voltage of 1.64 and you are correct, there was no diode.
b_rads
Oops - I failed to mention, I changed the configuration to:
Pos L&G to POS batt1 to Pos batt2 to Pos batt3
Neg L&G to Neg batt3 to Neg batt2 to Neg batt1
WilbyInebriated
Quote from: b_rads on February 10, 2011, 04:18:47 PM
@wilby
ah my misunderstanding. i thought each cell was 1.64v
yeah, seems strange. i have no explanation with the available data, sorry.
