Thanks to ALL for your help!!
Gearturbine - Atypical Thermodynamic Technology Submission
Started by gearturbine, September 20, 2010, 07:38:57 PM
What do you think about this project?
Turbines
0 (0%)
Motor Engine
0 (0%)
Total Members Voted: 0
gearturbine
http://gearturbine.260mb.com
YouTube Video; Atypical New * GEARTURBINE / Retrodynamic = DextroRPM VS LevoInFlow + Ying Yang Thrust Way Type - Non Waste Looses
http://www.youtube.com/watch?v=0cPo9Lf44TE
GEARTURBINE -Atypical Combustion Turbine Engine, -State of the Art, -New Thermodynamic Technology, -With Retrodynamic "Dextrogiro vs Levogiro" Effect, is when the inflow direction moves is against [VS] of the circular rotary dynamic, When the inflow have more velocity the rotor have more RPM / because push the single turbine with the planetary gear, (an a example is like to move the head to the side of the strike hit) / RPM Rotor Move VS Inflow Conduits Way /ACTION VS REACTION / Front to Front / Velocity vs Velocity, making in a simple way a very strong concept of power thrust, a unique technical quality. -Wide cylindrical shape dynamic mass (continue Inertia cinetic positive tendens motion / all the motor weight is goin with the power thrust direction), -Non Waste, parasitic losses form-function engine system for; cooling, lubrication & combustion; -Lubrication & Combustion inside a conduit radial position, out way direction, activated by centrifugal force Fueled Injected, -Cooling in & out; In by Thermomix flow & Out by air Thermo transference, activated by the dynamic rotary move, -Increase the first compression by going of reduction of one big circumference fan blades going to, -2two very long distance captive compression inflow propulsion conduits (like a digestive system) (long interaction) in perfect equilibrium well balanced start were end like a snake bite his own tale, -Inside active rotor with 4 pairs of retrodynamic turbos (complete regeneration power system), -Mechanical direct "Planetary Gear" power thrust like a Ying Yang (very strong torque) (friendly loose friction) 2two small gears in polar position inside a bigger shell gear, wide out the rotor circumference were have much more lever power thrust, lower RPM in a simple way solution, to make possible for a some innovative work application (cars/land). -3 Stages of inflow turbo compression before the combustion. -3 points united of power thrust; 1- Rocket Flames, 2-Planetary Gear & 3-Exhaust Propulsion, all in one system. -2two continuous circular moving inside combustion (rocket flames) like two dragons trying to bite the tail of the opposite other. -Hybrid flow system different kind of aerolasticity thermoplastic inflow propulsion types; single, action & reaction turbines applied in one same system, -Military benefits, No blade erosion by sand & very low heat target profile. -Power thrust by barr (tube); air sea land & generation application, -A pretender of very high % porcent efficient power plant engine. -Patent; Dic 1991 IMPI Mexico #197187
baboyes
The new lead-dog
‘Well, what did I say? Buck’ s a real fighter,all right,’ said Francois the next morning when he discovered that Spitz had disappeared and that Buck was covered in blood.
World of Warcraft power leveling,
‘Spitz fought like a wolf,’World of Warcraft power leveling said Perrault, as he looked at the bites all over Buck.‘And Buck fought like ten wolves,’ answered Francois.‘And we'll travel faster now. No more Spitz, no more trouble.’Francois started to harness the dogs. He needed a new lead-dog, and decided that Sol-leks was the best dog that he had.But Buck jumped at Sol-leks and took his place.
last chaos gold,
‘Look at Buck!’last chaos gold said Francois, laughing.‘He's killed Spitz, and now he wants to be lead-dog. Go away, Buck!’
He pulled Buck away and tried to harness Sol-leks again.Sol-leks was unhappy too. He was frightened of Buck, and when Francois turned his back, Buck took Sol-leks’ place again. Now Francois was angry.
‘I'll show you!’ he cried, and went to get a heavy club from the sledge.
replica sunglasses,
Buck remembered the man in the red coat, and moved away.replica sunglasses This time, when Sol-leks was harnessed as lead-dog,Buck did not try to move in. He kept a few metres away and circled around Francois carefully. But when Francois called him to his old place in front of Dave, Buck refused. He had won his fight with Spitz and he wanted to be lead-dog.
aoc power leveling,
For an hour the two men tried to harness him.aoc power leveling Buck did not run away, but he did not let them catch him. Finally,Francois sat down, and Perrault looked at his watch.It was getting late.The two men looked at one another and smiled Francois walked up to Sol-leks, took off his harness, led him back and harnessed him in his old place.Then he called Buck.All the other dogs were harnessed and the only empty place was now the one at the front But Buck did not move.‘Put down the club,’ said Perrault.
Final Fantasy XI GIL,
Francois dropped the club,Final Fantasy XI GIL and immediately Buck came up to the front of the team.Francois harnessed him ,and in a minute the sledge was moving.
Buck was an excellent leader. He moved and thought quick-ly and led the other dogs well. A new leader made no differ-ence to Dave and Sol-leks; they continued to pull hard .But the other dogs had had an easy life when Spitz was leading.They were surprised when Buck made them work hard and punished them for their mistakes Pike, the second dog,was usually lazy; but by the end of the first day he was pulling harder than he had ever pulled in his life. The first night in camp Buck fought Joe, another difficult dog, and after that there were no more problems with him. The team started to pull together, and to move faster and faster.
aion kinah,
‘I've never seen a dog like Buck!’aion kinah cried Francois,‘Never!He's worth a thousand dollars .What do you think,Perrault?’
