Ive wondered about powering a ship from the ocean.
Started by stevensrd1, September 24, 2010, 08:12:45 PM
stevensrd1
If you stick two electrodes in salt water you get electricity. I wonder if there is a way to get that salt water pumped into the side of a ship,,then into enough containers with electrodes and get enough power that way to run it. I imagined maybe electrodes on the outside of the hull of a ship but then that might pollute the water with metals, so then I thought of the first part.
iquant
What about capturing Hydraulic pressure directly from the waves?
Relatively simple device...  Dual action hydraulic pumps mounted on both sides of your boat each with a 15' arm with a buoy.  Lower in water when you want pressure.. raise it out the way when you don't.
You should get 3000 - 10000 PSI pressure on each roll...
Use the pressure to turn a prop or generator, desalinate water, as a ship stabilizer etc.
Mungo
I've been actively working to build one of these (see my post under salt water batteries).  I'm trying to calculate how many and how large a set of cells would be needed using copper/zinc electrodes and sea water at about a 30ppt salt concentration to power light marine electronics, some led lighting, and a 5 hp 12volt motor.  Would love some input.
Mungo
This link is to a 1954 article about an inventor who was working on this.  Haven't been able to trace what happened to him, the models, or the concepts.
http://blog.modernmechanix.com/boat-runs-on-sea-water/
Mungo
actually I've just done a first test on some of the seawater battery systems we've been messing with.  There's a discussion on said over at http://www.overunity.com/13671/large-salt-water-battery-ideas-and-questions/msg367679/#msg367679 on this board, and I'd love electric boating types to come over and give some feedback.
