Relative Permittivity of Water
Started by Torana, October 14, 2010, 04:35:01 AM
wfchobby
Quote from: canufi on June 02, 2012, 04:58:09 PM
The point of using household power supply is to get a 120V generator running on hydrogen instead of gasoline, and also to get home heating systems working based on the steam resonator. This technology is not just for cars, it is for households too.
Anyone who tries to get a car running on hydrogen is wasting their time. Small 1HP or 2HP generators are much easier to get running. A car is very heavy and is very costly if it fails.  A 2HP generator is $200 or less (4 stroke) and is much easier to experiment with, and easier to get running than a car or truck.
Get rid of your ego problems first; get a generator running first - not a truck or car!
What kind of moron would try and get a 3500 pound vehicle running on hydrogen, when you can get an electrical generator for $200 at harbor freight or your nearest hardware store? Not only can you get a generator running on hydrogen, you can get many of them running so that if one fails you have many backups. IF your dune buggy fails, you're screwed! you only have one dune buggy. Having more than one dune buggy is costly and time consuming. Cars are complex. Generators are not complex. Stop wasting your time getting cars to run, do it in baby steps - the generator comes first!
The amount of idiots involved in Stan Meyer replication astounds me.
If you cannot get a 2HP generator running on hydrogen, then it is NOT worth spending time on a 3500 pound volkswagon car. You're wasting your time.
A 2HP generator produces electricity and it only does that. A car does a thousand things. You don't need a thousand things, all you need is electricity. A generator is much more efficient than a car. Forget cars and trucks, just get a damn generator working. Generators can produce 120V and 12V electricity for the cell to run in a closed loop. If a generator doesn't run in a closed loop, then stan's device is not over unity, and it is not extracting energy from another source - it's just 80 percent efficiency or 60 percent, or 90 percent.
well well canufi hows your generator project coming along.?
I havnt been here for a while, I must say ive enjoyed Torana's kiwi humour and well mannered replies to you canufi......now if only you have slowed down a bit and asked better questions i suggest you may have had a better response. :)
tell me canufi, why would you think I would spend my time and money on a 2hp generator to run on H when we both know the wattage output of such small generators is hardly worth the effort of such a small machine that wouldnt be very useful for the variety of applications one might intend.........?
ego? moi? . lol :) i think you should have yours in for a check up.
when you are able, how about a picture or two of your successful 120v board being applied as a operational piece to running your generator. For im curious to see how you may obtain 120v to supply the component you are building which obviously requires the power well before the generator could....start up. :)   portable generator? maybe or not.?  :)
have a pleasant day
cheers
Torana
personally I thought post # 139 was funny ,    ......apparently no.
I was expecting rave reviews but instead all I got was  a PM telling me to go touch myself!!
                                       "Such is life"   (n.kelly 1880)
Torana
I cant Nor wont recommend anyone exp with HV coils of a CRT screen or anything mains connected.
Ive put links on this thread for flybacks, its the quickest method of getting  HV DC .
FBT is a power L /disruptive discharge coil/ coupled L / LOPT .
On 1st stage the sec is open circuited and presents no opposition to pri.
the core and Air gap store energy.
that stored energy is released thru discharge stage.
**sec is forward bias while the pri open circuited.
**FBT are NOT based on winding ratios like AC transformers.
Torana
the pic is of a standard TV 230v board with no alteration , just removal from case and CRT screen then plugged into mains.
the arc is to chassis earth, min 30kv.
the input signal is saw tooth, the out put is 1/2 wave rect that **can be smoothed by a HV cap to chassis earth
input approx 125 x 125 = 15625 hz
FBT is the quickest way to learn about HV water bridging and polarisation and effects of HV DC with out soldering a thing.
EXP at your own risk!!
Torana
stans pat #4936961  -1990 ; 78.54 @20c 1 ATM  = correct
...24 AWG and 36 AWG  ...(Whoa!)
http://www.free-energy-info.co.uk/PatE1.pdf
stans pat #5149407  -1992 ; 78.54 @29 c 1 ATM = correct
....24 AWG  and 36 AWG ....(Whoa! x 2)
http://www.free-energy-info.co.uk/PatE4.pdf
seems the patent attourneys office descended into Buffoonery.....No BWG
