Captret - Capacitor and Electret
Started by ibpointless2, October 19, 2010, 06:49:51 PM
Tito L. Oracion
Hi ibpointless and to all
i have a question?,  is the top metal of the capacitor differ to the one lead of the capacitor? if yes then its a galvanic battery effect wright?  8)
then never the less its a stubblefield  ;D
well, if that so then we can still develop it ok?  ;D
nievesoliveras
ibpointless2
Quote from: Tito L. Oracion on October 24, 2010, 09:09:07 PM
I'm sure they might be the same metal because a galvanic reaction needs a dielectric such as water and there is no dialectic. And I'm sure its not a stubblefield coil because it too needed a dialectic such as water to work and plus its not a coil, it seems to me to relate more with moray then stubblefield.
ibpointless2
Quote from: nievesoliveras on October 24, 2010, 09:19:30 PM
Is it this what you mean?
On the self charging capacitor and not the self charging Captret you un twist the - and the + and disconnect from the top after you have charge it with a 9 volt battery and then just use the - and the + and not the captret top part. aka just use it like a normal capacitor.
If you want to use the captret part which is just another capacitor you connect the - to the top or + to the top. to fully understand you must play with it.
ibpointless2
Quote from: Kator01 on October 24, 2010, 08:57:29 PM
Hi ibpointless2,
try using electrolytic capacitors with different voltage specifications. The higher the voltage-specification the less charge-losses. Use 100 and 400 V Caps. 400 Volt-Caps are used in flashlight-circuits. Take an old camera fromthe dump an remove this small circuit-board
Will there be a difference in the recharge-speed ?
Kator01
I know that the lower the farad on the capacitor the faster recharges.
I working my way to higher voltages so i can use it to power a pulse motor or radiantly recharge a battery. But more testing needs to be done.
