Possible overunity generator device
Started by magnetman12003, October 24, 2010, 05:45:08 PM
synchro1
I'm currently running the 2" on two 1/4" O.D. 1/8 I.D 1" long nylon bushings side to side with a 1/16" brass axel. It might help to use a 1/16" plastic rod inside the nylon sleeves to reduce contact surface. I tried tiny 1/4" precision ceramic boca bearings, but just smashed one in a collision with my 2" sphere. I kicked them apart like working out of a tight boot. The plastic rod sounds great. Thanks alot for the tip. The 2" magnet clocked out around 8k with the expensive ceramic bearings, and down around 3k with the nylon skid sleeves. The plastic rod sounds like it should measure in well, somewhere in between. The walled ceramic is $70. Good luck on your power measurements. I have achieved close to unity, or greater, spinning the giant 2" neo with a secondary wrap and feed back loop. This was coupled with a strong Bemf Bedini charge. I believe strongly that together, the combined output has to be >1.
DeepCut
Hi synchro, how is it all going with you ?
Gary.
synchro1
@DeepCut,
Good! Thnaks. Have you seen any of my Spiral Knot videos?
http://www.youtube.com/user/zebok3
DeepCut
Hi synchro,
i'm just watching the 'spiral trials' video, can you explain to me what is going on please, it's not clear from the video.
Thanks,
Gary.
synchro1
This loopback to source coupling gets this setup to act like a Flywheel Battery.
