Possible overunity generator device
Started by magnetman12003, October 24, 2010, 05:45:08 PM
casman1969
Just catching up but this post has me extremely interested. Enough so that I may just sport for that 2" diametric magnetized NEO. Have everything else.
Keep up the good work and I'll be checking in from time to time.
DeepCut
gyulasun
Quote from: synchro1 on December 04, 2010, 03:12:55 PM
@Cassman196,
Thats called Lenz Drag. Adding output coils just divides the available current. You need to reposition the coils.  You'll need to find out how far away the three need to be to allow for suficient R.P.M. Once that's established, you will notice that you can disconnect two of the output coils and reposition the sole remaining one in closer enough to equal the Lenz drag of the three. At that point only one output coil is needed to generate the same power as three combined.
Hi synchro1,
It is very interesting setup you are mentioning. Could you show a photo on it or at least a drawing if it is not top secret?  :)  Reducing Lenz drag has always interested me, albeit have had no success so far.
Thanks,  Gyula
synchro1
@Gyula,
I'll try and post a diagram. In the mean time it's not too difficult to imagine two upright doughnut shaped coils face to face with a neo sphere in bwtween. One coil bifilar, the other output looped back to source. There's only two variables for positioning; The distance between the coils and the relative distance of the sphere to one or the other. The power coil accelerates the spinner, the output slows it down. Look at the Spiral Knot trials video on my youtube channel. you'll see me spinning a 1" sphere right in the center of a Spiral output coil in resonance at peak efficiency R.P.M.'s. The rotor is at very high speed around 50K. inside a pvc coupling. The power consumption without the feedback loop is much greater. The trade off's pretty cleanly balanced this way. The wrap around coils offer nearly the same basic relationship as Bedini's window motor. I believe it's capable of even greater efficiency because it's bearingless; The higher R.P.M.'s tightens the pulse width and helps conserve on input.
http://www.youtube.com/user/zebok3
