Howard Johnson's Magnetic Gate
Started by nightwynd, May 07, 2006, 10:12:23 AM
nightwynd
I'm sure this has been covered elsewhere, but i couldn't find it anywhere else...so here goes:
I found a research paper that should PROVE to the most ardent of disbelievers that a PMM SHOULD work in Howard Johnson's magnetic gate...read the following: http://www.cheniere.org/references/HJLabMemo1a.doc if you have troubles opening that link go through this one: http://freeenergynews.com/Directory/Howard_Johnson_Motor/TomBearden/ - scroll down to the research area and open the only link there...
Synopsis: Shows the mathematical progression of force through a magnetic gate - with a net power gain in the end :)
Need motivation? Read: http://www.lifeaftertheoilcrash.net/
Sincerely - nightwynd
acp
Interesting.  I tried this magnetic gate in Femm not so long ago with the result of exactly 0.
But there again Femm isn't real, but it doesn't fake results either!
In fact every magnetic gate I tried in Femm, with shielding, angled magnets, etc always equaled zero.
nightwynd
I'm wondering if programs like femm use all of the "conventional" models of "modern" physics...
It would be interesting to see a duplication of this project both in real life with a femm model right next to it...
Many believe that using magnets to create a motor is somehow tapping zero point energy - personally i think it's hogwash - all we're trying to do is create a motor that is in a perpetual state of in-balance...
You want a perpetual-state of in-balance ?
Then the only solution (earth gravity condition) is a liquid as work medium !
S
  dL
nightwynd
did i actually say in-balanced...wow, there's a typo for ya :P
i mean un-balanced, i think that makes a bit more sense...
I'm not sure i understand the liquid as work...are you meaning like a waterwheel type scenario?
Sorry if some of my statements come across as childish - i'm still trying to wrap my brain around some of the concepts here :D
