Overunity.com Archives
New theories about free energy systems => Theory of overunity and free energy => Topic started by: that_prophet on February 06, 2014, 09:19:10 PM
Title: GEM = God's Electricity Multiplier
Post by: that_prophet on February 06, 2014, 09:19:10 PM
GEM=God's Electricity Machine
Free energy is so simple,
That we have missed it.
In our looking for such complex ways to fight friction costs.
We have failed to look at simple geometry
How you can multiply your rotations with changing the size of pulleys
Please remember, with electricity, more rotations is more power
Free energy has been discovered = (this is a Gift from God)
- By a Born-Again pre-Trib Saint (pre-Trib began early 2012),
- Scriptural Proof we are allowed to know these doors/deadlines (Mat 24:33)
I call this free energy machine a GEM = (God s Electricity Multiplier)
This one_christian_warrior was shown this Miracle by the God of our Holy Bible
- from The God of the Bible = (Father +Jesus +Holy Spirit)
I believe this might be because I asked our Father for something to help others,
- + not for myself = ( though it does bring me great joy )
I have always wondered about how I could help my future Tribulation Saints
- So I asked for some way to help these Tribulation Saints be better
- - Able to survive easier, so they can make it past the Great Tribulation
- When they would have to survive our Canadian winters
- - off the power grid
He first showed me a Vision, of a ten-speed bicycle going up + down a hill
- Where if you drove up the hill in tenth gear, (few turns of the pedals)
- - Then back down in first gear
- - - You would do far less pedaling up the hill
- - - - Then pedal like crazy all of the way down
- - With electricity, more rotations equals more AC electricity (power)
Then, as a confirmation, that this came from Good Forces = Holy Spirit
- + not bad ones (fallen angels)
- - I found it described in Ezekiel 1:16,
- - - Where they were trying to describe the workings of a UFO:
- - - - Or chariot of fire (2Kings 2:11)
When you take a careful look at this technology
- It seems obvious (the more generators you add, the greater the multiplication factor)
- - You put power into a motor with a large pulley
- - - Which you only have to turn the one single turn (very little energy)
Then you take power out of the one to a hundred small pulleys with generators
- That you attach to the same belt
- - Each generator rotates tens to hundreds of times faster
- - - Each rotation gives you electricity (lots of energy)
- - - - It is truly that simple
I believe that it can't help but work
- Then why has this simple method of gaining free energy been hidden for so long
- - It is because Satan + his evil spirits are working hard hiding this
- - - How else do you explain this not being discovered earlier
- - - - Like, as soon as electricity had been discovered
- - - - - This is soooooooooo simple
- - - - - - Why has it been hidden
Well, it is hidden no longer. I have published for all to use freely
- at : http://free-energy.yolasite.com/
+ what I heard on the web
- - that if a person publishes something on the web
- - - and chooses not to patent it, like I have done
- - - - then it opens it up for all to use freely
- - - - - without having to pay any patent fees
I have this, and two other unique ideas given me by God that I have published
- On the web at this website http://beliefstoliveby.yolasite.com/
You use pulleys to multiply your rotations
And with electricity, more rotations is equal to more electricity
The massive multiplication of rotations is where we can gain the energy. The idea is to put power into the torque of rotating the large pulley of the DC drive motor, which is converted into massive amounts of rotations of the output generators, as we can connect tens if not hundreds of output generators through simply increasing the size of the belt that drives them to accommodate the increase in the number of small pulleys. The vast amount of multiplications of rotations gives you enough power to not only power itself, but cover any loss due to friction, and actually generate an excess of energy. The idea is, to use simple geometry(size change of diameters) to create an increase of rotations through massive circumferential differences. In effect, you are multiplying the power.
We don't need the air polluting effects of the combustion engine any more
We have self-generating electricity generators
That can be made to practically any size or voltage
So that we have the choice to have almost everything self powered
I know this will work, and I believe that this will change the world that we live in for the better. I proved that the idea works with my electric wheelchair experiment, but I have not been able to get a bicycle light generator to finish the prototype.(something I will be struggling to remedy for a while now) I also thought of using an electronics simulation software to not only prove that it works, but then we would have a video of how one actually works. I know, it`s so simple it seems too simple to work, and if it would work, then why wouldn't someone have thought it up earlier.
I know, it`s so simple it seems too stupid to work, and if it would work, then why wouldn't someone have thought it up earlier.
I figure that if you keep adding output generators to the belt
then you would eventually generate enough power
to make up for the power that you are putting into the drive motor
as well as any losses due to friction
until you add enough output generators
to have not only have a self powered machine
but you can get an excess of power as an output
= free energy output generator
Here are a few of the reasons for this system to work miracles
- The massive circumferential differences between a large drive rotor
o You put power into turning a motor only once-(lg)
§ When the power out generator(s) spin hundreds of times faster
· Each rotation gives you power to put back into the system
- Then you could add tens of these output generators
o All of these would be turning the many hundreds of times faster
- Them you could enlarge the drive motor pulley to the max
o As well as shrinking the size of the pulleys on the output generators
§ to make the multiplication factor even more
- So lets see, you are putting energy into the high torque motor with a large pulley
o And then through extreme size differences in pulleys
§ As well as the simple addition on 10`s if not 100`s of generators
· You get your many generators to spin many rotations
o That you are getting power out of
§ While your input motor only turns the once
· You have to make power
You need one DC motor as an input motor
Then you need at least one AC motor as a generator
This is one of the easiest way to multiply your input power
By adding additional output generators
on the same belt as your input DC motor with the one large pulley
Or, you could change size of the pulleys is another way to effect your multiplication
by shrinking diameter of output generator(s) pulley
or increasing diameter of DC input motor pulley
are other ways of increasing you multiplication
the drive motor and all of the generators could be any voltage
as long as they are of the same voltage
you might need to use voltage regulators
to keep this contraption running smoothly
Maybe this mechanism should be called an electricity multiplier
As you always need the initial amount of electrical power
To be multiplied into your gaining of free energy
Which can be initialized by giving the large pulley a turn by hand
this is a Miracle from God
yes, it does indeed work
using size change in diameters of pulleys
to multiply the rotations of your input motor
by the large change in circumferences of the pulleys
as in, the multiplication factor is due to
the tens if not hundreds of times the circumference changes
I just don't like the idea of somebody blowing up a battery
And maybe even catching fire
Now, most likely you will not be interested in this Spiritual part
But I discovered this by praying and asking the God of the Holy Bible
for a way to help us earthlings, the Tribulation Saints mostly
Especially during the 3.5 years of the Great Tribulation
Where they will need a way to survive our cold Canadian winters off the electricity grid
Don't believe in Satan or evil forces
Please explain why this simple idea
Of using change in size of pulleys to multiply electrical power
Has not been discovered all ready
to all Who are in the Family of Christ
this is for the tribulation saints
how else do they stay alive + hidden
in our cold Canadian winters
WARNING = the pre-Trib started on March 14th, 2012
http://doorschristmustpassthrough.yolasite.com/
joe lynch
one_christian_warrior@yahoo.ca
Diagrams of some uses for this technology are at:
Title: Re: GEM = God's Electricity Multiplier
Post by: that_prophet on February 06, 2014, 09:21:55 PM
And with electricity, more rotations is equal to more AC electricity
http://lie .yolasite.com/
joe lynch
( ok, I know that most will fall for satan's LIE, the religious belief of EVilsOLUTION )
Post by: that_prophet on February 06, 2014, 09:46:13 PM
IT IS TRUTH
From Jesus, the God of the Bible
Just think about it this way
You are only putting enough electricity into the drive motor
to turn the DC motor one revolution, (extremely minimal)
+ with then with the large size of the pulley
even the one rotation gives you lots of belt distance
Then there is the minimal circumference of your output pulleys
giving you the maximum rotations for each of your output generators,
- - (tens to maybe even hundreds of times of the drive motor)
- - - - < + we can have multiple output generators just by having a larger belt >
oh yah, did I mention that your easiest way to multiply your electricity
is to add as many output generators as you can fit, (or afford, lol)
YOU MUST GAIN,(nultiply) LOTS OF FREE ELECTRICITY
GIFTS GOD SHARED WITH THIS WARRIOR: to share with the world
I have these three ideas, that I strongly suspect was given me by God + I have published
- on the web at this website http://beliefstoliveby.yolasite.com
- - Along with a list of my beliefs
- - - And other things that God has shared with me
- - - - That I would like to share with the world
- - - - - WARNING = I AM is the Name of the God of our Holy Bible
everyone breaks the 3rd commandment
when we say "I am"
we are taking His name in vain
notice how movies + shows on TV use it often
why are all commercials using the "I am" now
Satan knows very well not to use it
Why do you think products are being sold by His Name
FIRST GIFT) –<in 88> next generation joystick (has 6 movements instead of 2)
(In a Vision which God shared me the week of my becoming Born Again)
- Detects motions in all three axis's
+ Detects rotation in all three axis's
- - plus there could be 6 more activating movements
- - - 2 for a small joystick for the thumb
- - - + 4 individual switches for each finger
that is 12 more motions detection
- equalling 24 in total
- - that is 12 times the regular 2
- - - of a normal joystick
- - - - I thought this was quite the Gift
(then He showed me this awesome virtual reality video gaming room)
SECOND GIFT) – <in early 00s> 3-D virtual reality games room
(In a Vision given to me sometime in the early 2000s)
- Where you are in an eight foot cube room
- - With videos projected on all four walls
- - - The ceiling + the floor
- You are held in the centre of the room by four cables
- - Which go from your belt to the four corners of the room
- - - Holding you in the centre of the room
- You are standing on a ball bearing mat with motion sensors
- - So that you can walk or run in place
- - - While to video moves by you on the screens
- You are wearing a skin tight suit with markings all over it
- - So that your body movements can be captured by the game
- - - Through sensors in the room
- - - - Then translated into game extra movements
- - - - - for fighting with your hands + feet
THIRD GIFT) – <about 2005> Free Energy
<<< these gifts are free to use by anybody = no patent fees >>>
Post by: Magluvin on February 06, 2014, 10:23:57 PM
Hey Prophet
Have you built one yet? ???
It takes a lot of input energy to turn a generator when its output is loaded, let alone 3 or 4 gens, and, let alone using a large pulley on the motor, with small pulleys on the gens, it multiplies the load to the motor, and less torque to the gens.
I believe in God, but this setup is a hard sell. ;)
Mags
Post by: TinselKoala on February 06, 2014, 11:05:45 PM
Not again!
This is the electric wheelchair guy, with yet another username.
Hey Prophet: You should talk to your God and ask him how he feels about people who make claims they cannot back up with data.
Post by: Neo-X on February 07, 2014, 12:41:31 AM
I saw ou moto-gen with 1 is to 1 speed ratio so this means speed ratio is notting to do with ou. I think the vibration of the moto-gen which makes it ou.  :-\
Post by: TinselKoala on February 07, 2014, 08:05:44 AM
Quote from: Neo-X on February 07, 2014, 12:41:31 AM
And I think it's bad measurements, or none at all, that "make" it OU.
Easy to determine which of us is right.... just produce the device you think is OU, and let's make some proper measurements together, with everybody agreeing what to measure, how to measure it, and what the measurements mean.
Post by: tinman on February 07, 2014, 08:12:41 AM
@ Prophet
You need to talk to Sterling Allan-he'll be hook ,line and sinker on this one.
And once you have one up and running,you could give it to Sterling to put on his house-along with the other 4 or 5 he was getting.
Post by: that_prophet on March 14, 2015, 04:02:25 AM
FREE ENERGY IS A GIFT TO ALL = the simplicity of electricity multipliers
From this simple guy, to the whole world. Please take this burdon off my hands..
COME ON GUYS + GALS
Let's get with the program
(Electricity Multiplication using simple geometry to multiply rotations)
(which is easily converted into the multiplication of AC electricity)
Why use oil products, which contaminates our atmosphere,
Or use nuclear fission, where you have to deal with radioactive material, and even worse, it tends to leave nuclear bomb-making by-products
THIS WORKS, and it is so logical, that anybody can see it simply MUST work
(Let's use this to not only restart our economies + help our environment)
(we should help redistribute this new found wealth, to the lower classes)
(that we can all give generously, helping the many fantastic charities out there)
FREE ENERGY IS SO SIMPLE THAT WE HAVE MISSED IT = (why?)
. . I cannot believe how much of a hold that scepticism has on our society,
and it amazes me that people won't believe in how simple free energy is.
They hold on to this imaginary torque problem, which does not truly exist.
Think about it this way, how easy is it to rotate a mini-electric motor,
with now-a-days electric engines; they are the easiest to turn over.
. . We only have to put a miniscule amount of DC electricity into this system
to rotate your input motor one single rotation. This drive motor rotates a 100 cm circumference pulley one single rotation, which only takes an extremely small amount of DC electricity. It practically takes nothing to turn over your motor the once,
More so voltage, with practically no current. You are surely gaining massive amounts of AC electricity here, like 100 units of AC electricity for every single rotation of your input DC drive motor. This is why I call this an electricity multiplier, 100 units of AC power, for I unit of DC electricity..
. . This minimal amount of DC electricity input uses simple geometry of pulley size change to multiply your number of rotations, or AC electricity. This is done by driving a large pulley attached to a belt, that connects to one or as many as you like, miniature output pulleys attached to AC motors. These motors only have one centimetre circumference pulleys connected to them. These extremely small output pulleys rotate 100 times, producing 100 units of AC electricity, for each pulley that you attach. If you only had 10 mini-pulleys connected, you would have 1000 units of AC electricity as an output, for every single rotation of your input motor, to be put through a full wave bridge rectifier + voltage regulator, and then back into your DC motor, which is only expending a small amount of DC electricity, to rotate your drive motor the one single revolution.
. . You might hear the idiotic argument about torque, but if you just think about our electric motors now days. They are the easiest to rotate, and take practically zero torque to turn over, so torque is in no way a problem. These AC motors/generators take so little effort to turn, that you could easily have tens, maybe even hundreds of them attached to your belt. that your Free Energy Machine = Electricity Multipliers, might be This would mean in the order of hundreds or thousands of power. As in, you only put in enough DC power to make the 100 centimetre circumference drive pulley turn one single rotation, which is an extremely small amount of electricity. You get out of this system 100 units of AC electricity, which is easily much more than enough to get the drive motor to only do one rotation. You now have yourself an AC electric generator, which will not only power itself, which takes only a couple of your 100 AC units of output, leaving the other 90-98 units of AC output to be for external use. Please remember that these few units of AC electricity, are taken from only one of your AC generator, of the ten or more mini-pulleys that you can easily attach to the same belt, strap, rope or even string in a pinch.
. . You are simply using pulleys to multiply rotations, which multiplies your AC electricity. A simple diagram and explanation of how simply this works is at this URL address; http://free-energy.yolasite.com/ which I published many years ago, meaning that there are no royalty fees to pay, as I chose to have this as a truly FREE ENERGY GENERATOR. This one rotation of a 100 cm circumference pulley, when run through a simple mechanism, with a belt, strap, rope or even a string in a pinch, is then connected to one or more mini-pulleys of one centimeter circumference. This simple mechanism gives you 100 units of AC electricity, for as many of these mini-pulleys you choose to attach. .
NOW PLEASE take this mechanism and run with it,,,,,,,,,,,
This could help STOP TERRORISM
by taking away their money that they get from all of the oil that we are buying
and only needing oil products for lubrication
I also believe that I have these two amazing gifts for all video game enthusiast
One is a next generation joystick at http://ultimatejoysticks.yolasite.com/
Two is a 3D virtual reality games room at http://ultimatevideogamecontrols.yolasite.com/
But one of the best parts of these gifts is the way that both of these gifts could be used in other ways, as equipment for the disabled, and tools for safe ways to do very dangerous jobs, from the safety of video rooms, set in most any place of safety.
For the ultimate Joe-stick, we could build them to measure whatever few movements that the disabled person could perform, and program it to do whatever movement that they would like to do, like typing or speech, or whatever movement that you would like to program into it. http://ultimatejoysticks.yolasite.com/
For the ultimate video game controller, we could have it simulating robots, that are in deep space, or any depth in the water, or in some extremely dangerous places, like at chemical spills, radioactive sites, or even sites of fires. http://ultimatevideogamecontrols.yolasite.com/
These are all free for all to use, as they have been published on the web
+ are without patent fees of any kind
Post by: Pirate88179 on March 14, 2015, 12:53:02 PM
Even a patented device is free to use for your own personal use.  You just can't manufacture and sell them.
Lenz law is going to make this not able to work.  (As Mags has mentioned)
Bill
Post by: that_prophet on March 26, 2015, 09:29:25 AM
Please,,, someone take up this worthy quest for free energy. I happen to be disabled, and cannot build this super simple electricity multiplier device. Nor have I been able to find a mixed signal electronic circuit simulator that I could run this free energy mechanism on. It runs on the simplest logic, and could be built with most any spare parts. The logic seems obvious to me, and I find it extremely hard to believe that others cannot see the simplicity of this devices workings.
You put a minimal of DC power into your drive motor, which has a pulley of 100cm circumference, which then uses a belt, strap, or rope to rotate one or many mini-pulleys of 1cm circumference. This one or many mini-pulleys has an AC motor attached, which returns you 100 units of AC electricity, for every mini-pulley that you have attached. How can this be any simpler, you are only putting in one unit of DC electricity, which returns you 100 units of AC electricity. Then all that you would have to do to start this electricity multiplier running, is start the big wheel rotating by hand, and this would continue running indefinitely, producing both AC + DC electricity. It only takes four diodes, or a full wave bridge rectifier to convert your 100 units of AC electricity, into a lot more DC electricity than you need to power your DC input motor for one revolution,(this is where you get your perpetual AC+DC power supply)
As for this mythical torque problem, there is none. Do you think that the torque would be so great, that you could not rotate the big pulley by hand? If you even rotated the big pulley a quarter turn, this would give you 25 units of AC electricity, plenty enough DC electricity to power your one single rotation of your DC drive motor. As for torque per revolution of the mini pulley, it would only be slightly more than 100th of the power needed to rotate your large pulley. This is a minimal of torque, and if you wanted to lessen by even more, then you could add additional mini-pulleys to the system.
This is so simple that it has to work. Come on you free energy fanatics out there, we could start an environmental avalanche of free energy technology products being produced. This would revive our economies, and through switching our automobiles alone, not to mention the fossil fuel we use to heat our homes + work places, we could start defeating our output of pollution.
Post by: MarkE on March 26, 2015, 09:45:30 AM
But it does not work for reasons that have been explained over and over.
Post by: that_prophet on March 26, 2015, 12:00:33 PM
all that it will take, is for one person to build this
don't you believe a person can turn the large pulley by hand
only a quarter turn will give you an output of 25 units of AC electricity
when run through a full wave bridge rectifier
this should be far more DC electricity than is needed to continue the DC motor running
this is a simple 100 power electricity multiplier
if you don't think this is enough juice to power your DC drive motor
then you could always add two or three more mini-pulleys to the system
Post by: that_prophet on March 26, 2015, 12:09:37 PM
this is a Gift from our Father,
are you telling me that no one will even try it out
this could change our world for the better
yet no man or woman will step up + accept it
is mankind so much of a handle to take 15 minuets to build this
((( I cannot, as I happen to be disabled, )))
((( else I would build one, in the 15 minuets it would take )))
Post by: MarkE on March 26, 2015, 01:33:21 PM
Quote from: that_prophet on March 26, 2015, 12:09:37 PM
is mankind so much of a coward,,,,
If you are so keen on this unworkable idea then pay someone to build it and find out what has been explained over and over:  It will not work as you expect.
Post by: that_prophet on March 26, 2015, 04:24:42 PM
Ok, let us lock at some simple logic,
If we added 10 mini-pulleys, then we would have a return of 1000 units of AC electricity,
For every rotation of the large drive pulley, and DC motor,
Which takes extremely small amounts of DC electricity to turn,
Mostly all voltage = pressure, + practically no current,(just a spark) = low wattage
And because you have 1000 units of AC electricity converting into DC electricity,
Which is going back into your full wave bridge rectifier, (massive amounts)
So each rotation of the AC motors/generators must be taking practically zero torque,
If you started the big wheel rotating by hand, just a 1/4 turn
that would produce 250 units of AC electricity, plenty to start this free energy machine running
(PLEASE, CAN SOMEONE FIND A FREE MIXED SIGNAL CIRCUIT SIMULATOR)
(that is easy to use + has pre-made motor circuits in it )
just look at the gaining of the power to go 20 feet up a very steep hill
every time I drove uphill fast,(large wheel) + then downhill slow,(mini-wheel)
at this website http://free-energy.yolasite.com/
Post by: Artoj on March 26, 2015, 06:01:16 PM
Here is my quick and cursory analysis, I hope this helps, regards Arto.
Post by: TinselKoala on March 26, 2015, 08:21:22 PM
@Artoj: A nice analysis, but you will never convince the OP that his system is futile. Please read the sections on his website where he describes his history and you will perhaps begin to understand why he cannot be convinced that this Idee Fixe is unworkable. He has been posting the exact same thing here in multiple threads for years and has seen many such analyses as yours, and no amount of reasoning and calculation, or even experimentation, can shake his faith.
Post by: vineet_kiran on March 28, 2015, 11:49:02 AM
Quote from: Artoj on March 26, 2015, 06:01:16 PM
Very nice analysis.  Sometimes back I had thought of using a fat (very thick belt) instead of normal belt.  I have shown the sketch in attachment.  Please let me know will it have any advantage.
Post by: Artoj on March 28, 2015, 05:19:16 PM
Hi Vineet
I will not normally analyze every thing that passes my purview, but I thought this might be interesting just to show a sightly different way of approaching a problem, even though to me it was very straight forward without any figures necessary. I deemed it another exercise for my personal learning and recreation. Please if anybody else has other problems that need some solutions, I would appreciate a paid hourly rate for each solution, these are not quick scribbles on napkins.
Thanks Regards Arto.
Post by: vineet_kiran on March 28, 2015, 08:32:43 PM
@Artoj
Thanks for the analysis  and sorry for wasting your time.
Reagrds,
Vineet.K.
Post by: Newton II on March 28, 2015, 09:58:22 PM
Why don't you use a normal belt and paste a very thick layer of sponge on it  so that power is not lost due to tensioning?
Post by: that_prophet on April 17, 2015, 03:22:24 PM
FREE ENERGY HAS BEEN FOUND
   Yes, that is correct, Free Energy has been discovered, this electricity multiplier mechanism is dirt simple, and extremely easy to build, with spare parts even. Building this type of free energy device is not only easy, but is simple also, costing practically nothing to produce. This is mainly because you are able to build this contraption with spare parts, and very few parts at that.
   This device is extremely easy to build, with only a few moving parts, such as at least two pulleys, one large pulley, one or many small pulleys, and a belt, strap, rope or even string in a pinch, to connect the two pulleys together. There are only two more moving parts here, a DC drive motor, and at least one AC output motor/generator. I say at least one, as you could have many more, as the more generators you have, the greater the multiplication factor of your electricity multiplier unit. You can also increase your multiplication factor by increasing the circumference of your drive pulley, or decreasing the circumference of the output pulleys.
   The workings of this miraculous mechanism are pretty straightforward, and can be described by using a multiplication factor of rotations, by merely changing the size of pulleys. You put an extremely small amount of DC electricity into the drive motor, which has a 100cm circumference and only needs to do one single revolution. This drive pulley is connected to at least one one-centimetre circumference mini-pulley that acts as an output device, giving us 100 units of AC electricity, per every output pulley that is connected.
   I suppose that you might be able to see how this could start adding up, giving you 100 units of AC electricity for every output mini-pulley that you attach to the system. If you only added 10 of these mini-pulleys, then you would gain 1000 units of AC electricity, for every single input revolution of the DC motor that you put into this free energy device, otherwise known as GEM = Geometric Electricity Multiplier
Post by: that_prophet on April 17, 2015, 03:23:05 PM
·   THIS DOES WORK !!!
It just takes you to look past the lie,
That evil forces are whispering in your ear,
It is pure logic, that pulleys multiply rotations,
+ with AC electricity, revolutions equal AC power,
Satan hides this super simple free energy technology,
By immediately bringing up torque needed to rotate pulley,
Letting you forget AC motors are a breeze to rotate,
You could easily have 10 – 100 of them rotating at once,
And when the drag of load attacks, it is minimized by 1/10th to 1/100th,
Because of it getting divided up, so it lessens it so severely, that it works
Please believe me, and my Lord + Savior, Jesus Christ,,,
God So Much Wants to Give us this Little Miracle Device,
+ He only ask for your faith,,,
Post by: SkyWatcher123 on April 17, 2015, 06:16:56 PM
Hi folks, Hi that prophet, well there is evidence to support what that prophet is saying.
Imagine an electric machine having no electrical input itself and which, when started on no load by a drive motor and brought up to speed (3250 rpm), thereafter runs steadily at that speed with the motor drawing a little extra input power with a time delay rate of about two minutes. The machine rotor has a mass of 800 gm and at that speed its kinetic energy together with that of the drive motor is no more than 15 joules, contrasting with the excess energy of 300 joules needed to satisfy the anomalous power surge [to spin up from rest]. Imagine further that when the motor, after running five minutes or more, is switched off and the machine is stopped, you can restart it in the same or opposite direction and find that it now has a memory in the sense that it will not now ask for that 300 joules of excess input. 30 joules will suffice provided that the time lapse between starting and restarting is no more than a minute or so. This is not a transient heating phenomenon. At all times the bearing housings feel cool and any heating in the drive motor would imply an increase of resistance and a build-up of power to a higher steady state condition. The experimental evidence is that there is something spinning of an ethereal nature coextensive with the machine rotor. That 'something' has an effective mass density 20 times that of the rotor, but it is something that can spin independently and take several minutes to decay, whereas the motor comes to rest in a few seconds. Two machines of different rotor size and composition reveal the phenomenon and tests indicate variations with time of day and compass orientation of the spin axis. One machine, the one incorporating weaker magnets, showed evidence of gaining strength magnetically, as the test were repeated over several days. I will soon be reporting in detail on these findings, after further work and evaluation of the implications. The phenomenon was something I should have been prepared for, having regard to my years of theorizing, but this discovery was unexpected as it has crept in loud and clear in a project aimed at testing a motor principle totally unrelated to 'vacuum spin'. It has appeared obtrusively and I do not yet know whether, in adapting to its presence, it can serve in improving machine performance or become detrimental."
peace love light
Post by: SkyWatcher123 on April 18, 2015, 04:13:48 AM
Hi folks, so it looks to me as though this ethereal anomaly is being left out of the equation, which may help to explain not just that prophet's results, but all these other results and there are more than what i just pointed out.
Anyone know a way to make a long homemade belt, I'll have to google it and see.
I have a motor and generator that would work, would just need to build a structure, a decent size heavy wheel, like the 5 foot diameter wooden wilson wheel maybe.
peace love light
Post by: that_prophet on April 22, 2015, 04:35:54 AM
it would work better if the drive motor was used to rotate the largest 5 foot diameter wheel,
then you only pay to rotate it once, and you get tens to hundreds of AC rotations
from the two AC generators
Post by: truesearch on April 22, 2015, 01:20:15 PM
@that_prophet:
I'm sorry but it appears like your "vision" is not very well connected with the created world that we exist in. Please try to read the following and give it some rational thought:
Let's take for this example one of King Solomon's chariot wheels (maybe at 5' for this example):
1. If you where able to put 2 of these chariot wheels together on a single axle it shouldn't be that terribly difficult to push them around on the flat plans of Jezreel. This is very comparable to your electric motor turning your wheel WITHOUT any AC generators attached (are you with me?). Nothing gained at this point.
2. Now, if you take this same 2-chariot-wheels-on-1-axle device and begin to push to up the road in the hill country of Gilead you will IMMEDIATELY notice that it is more difficult (and you will likely break out in a sweat) because you are exerting WORK to counter the GRAVITY. This is pretty much a dead-on comparison to attaching 1 AC generators to your 5 ft wheel driven by your electric motor because the motor must turn the 5' wheel which, in turn, is dragging along the generator which RESIST turning because it is PUSHING the electrical current being generated. Sort of like you pushing those chariot wheels up-hill.
3. Finally, if you take that chariot-wheel device and drag it up Mt. Horeb you are going to stand out as a hero of old (especially if go like the driving of Jehu). Regardless, this is symbolic of you attaching 2 AC generators and expecting to get any electricity generated from them. That POWER-OUTPUT is the mechanical input being converted to ELECTRICAL. No more, no less. The GRAVITY that you would work against to go up-hill with your chariot-wheels is very much of a comparable drag as the AC generators.
sincerely,
truesearch
Post by: that_prophet on May 17, 2015, 08:35:53 PM
Quote from: SkyWatcher123 on April 18, 2015, 04:13:48 AM
peace love light
This was given to me by my Father God,
When I asked for a way to help the Tribulation Saints,
Be able to survive our Canadian winters off the power grid,
I hoped that this would be easy to build
By using spare parts from other objects with electric motors in them,
I thought that even a rope or string might do
These are being built by many that no very little about electricity,
+ I was amazed at how simple this was in it's workings,
I was also hoping that this being sooooooooo simple,
Might help prove the fight between good + evil,
Helping people come to the knowledge of,,,
+ salvation by Jesus, my Lord + Saviour
As I believe that I should be gone in the pre-Trib Rapture,
But I knew they could not be using fires to heat, light + cook,
As this would easily give their positions away to the future Tribulation authorities,
By the light at night, smoke by day, and heat signature from satellites,
So this told me that free energy MUST be a reality,
+ I wished+prayed that He would share it with me now, before the Tribulation,
so that many free energy items would be around
for the Tribulation Saints to get their hands on soon
because half of the population will survive the Tribulation,
and many will be Saints,,,,,,,,,,,,,,,,,,,,,
Free Energy http://free-energy.yolasite.com/
is so ridiculously simple, that I hope it will shame you into doing something about the evil influence in our society that is deceiving our children, (http://decimationofthisevolutionfairytale.yolasite.com/ ). You only have to put a spark of DC electricity into this system, while it can return 1000's of units of AC electricity. You do this by connecting a 1000cm circumference pulley to a DC motor, attach a belt to this pulley, and then run this belt through ten one centimetre circumference pulleys. Then you rotate this large pulley by hand, only one time. This would only take a spark of DC electricity, as you are only rotating it the once. This spark of DC electricity, one rotation of the motor, will give you a return of 10,000 units of AC electricity. Now, try and tell me that this 10,000 units of AC electricity does not have the voltage,(electrical pressure) to have the torque to rotate your DC motor one single time.
Post by: Pirate88179 on May 17, 2015, 08:51:41 PM
This has been reported to the Administrator as Spam.
Bill
Post by: pomodoro on May 18, 2015, 01:42:40 AM
LAST NIGHT GOD TOLD ME HE IS GETTING ANGRY WITH YOU. HE TOLD ME TO TELL YOU TO STOP THESE POSTS, OF FACE DAMNATION.
So please keep posting this shit , cause you deserve to rot in hell you dick muncher.
Quote from: that_prophet on May 17, 2015, 08:35:53 PM
Free Energy http://free-energy.yolasite.com/ (http://free-energy.yolasite.com/)
is so ridiculously simple, that I hope it will shame you into doing something about the evil influence in our society that is deceiving our children, (http://decimationofthisevolutionfairytale.yolasite.com/ (http://decimationofthisevolutionfairytale.yolasite.com/) ). You only have to put a spark of DC electricity into this system, while it can return 1000's of units of AC electricity. You do this by connecting a 1000cm circumference pulley to a DC motor, attach a belt to this pulley, and then run this belt through ten one centimetre circumference pulleys. Then you rotate this large pulley by hand, only one time. This would only take a spark of DC electricity, as you are only rotating it the once. This spark of DC electricity, one rotation of the motor, will give you a return of 10,000 units of AC electricity. Now, try and tell me that this 10,000 units of AC electricity does not have the voltage,(electrical pressure) to have the torque to rotate your DC motor one single time.
Post by: Dave45 on May 18, 2015, 08:14:59 AM
If you believe it will work then give it a shot
There are pmg's and pma's out there that reduce cogging but still put out a good amount of current.
http://store.mwands.com/permanent-magnet-alternators-pma/pmg/
I believe it was a man by the name of Campbell that did what you are proposing.
Give it a shot if nothing else it will be a learning experience.
found it here is one of his vids https://www.youtube.com/watch?v=fgk0HfXhU9M
You'll have to build it yourself these guys on this forum will help but they wont build it for you.
Most of the people here are good folks and very knowledgeable about electronics but believe it cant be done so build it and they will come  ;D
Post by: Dave45 on May 18, 2015, 09:12:24 PM
https://www.youtube.com/watch?v=FmXBebQzMyQ
Post by: Dave45 on May 20, 2015, 08:04:29 PM
Comon now, it can be done, you know it can, you can feel it, your just not looking in the right place. lol
Here's something to think about
You want to access a large amount of energy
We live on a huge magnet so that would be the most obvious place to look right.
We have billions of magnetic field lines entering one pole and exiting the other
How do those field lines run together, are they arranged in such a way that a consistent pattern is achieved.
Can we see that pattern in nature.  ;)
Thats for the bee's lol
So if you build a coil arrangment to match that pattern can you access that huge amount of energy.
Post by: that_prophet on July 22, 2015, 05:37:24 PM
Are you trying to tell me that if you put just a spark of DC electricity,
Into rotating a DC motor one single time,
With a 100cm circumference pulley attached,
With a belt on it that is big enough to encompass the 100cm pulley,
As well as 10 1cm circumference pulleys,
With AC motors-generators attached,
That the 10X100 = 1000 units of AC power,
When put through a full wave bridge rectifier,
Does not have the voltage to more than rotate your DC motor once
That is one spark of DC electricity in,
That gives you 1000 sparks of AC electricity out
Post by: that_prophet on July 22, 2015, 05:38:43 PM
Post by: that_prophet on July 22, 2015, 05:46:40 PM
As well as 10 X 1cm circumference pulleys,
Post by: that_prophet on July 13, 2016, 06:39:21 PM
I was thinking that this is so simplistic, that I was hoping that all of the evil spirits in this vast universe, could not find a way to poke holes in it. But I guess that those enemy forces still have a key word, torque, that strikes doubt in our unbelieving souls. How can I put this any clearer, these AC generators are just being used to wind up massive voltage. All of these many AC generators together, doing their massive rotating, only need to generate one single spark of current, (practically none). That is because the input for your DC drive motor, connected to the large 1000cm circumference pulley, only needs to be a single spark of current. That is because you only need to rotate this large pulley once, and it will give you a return of 1000cm of moving belt.
Then, when you run this 1000cm of moving belt through one to ten mini-pulleys, having only one centimetre circumference, this will translate into 1000 to 10 000 cycles of AC electricity. There is no more discussion needed, with only one spark of DC input, you are using the mechanical abilities of pulleys, to gain a return of 1000 to 10 000 units, (sparks) of AC electricity. This shows a clear multiplication of electricity, which means that you do not have to pay for it to be generated by fossil fuels, or the heat off nuclear fission. In essence, you are using this technology to multiply already generated electricity, there by gaining free energy.
Post by: Mem on July 14, 2016, 03:12:43 AM
Hey Bro!
Are you a some kind of false prophet and you put these post's here to misguide people?
Or, are you a true prophet? If so:  TRUTH REQUIRES EVIDENCE.  put your words where your mouth is and demonstrate to the world what you are talking about.
If you think you hear god's guidance and direction, why not ask your god to show you how you can build this machine so you can demonstrate working self powered generator to prove your authenticity.
Can you do this? If you can't do it you may belong to self appointed prophets that are many of them out there. That worship lesser gods...
Post by: seychelles on July 14, 2016, 05:49:44 AM
he sounds a bit like EM JUNKIE..Just joshing em...
Post by: that_prophet on September 17, 2016, 06:25:04 AM
free energy is done using pulleys
It uses the simplicity of it not taking 100 times as much force turning a 100cm circumference pulley, as it does turning a 1cm circumference pulley, yet you get 100 times more LENGTH OF MOVING BELT to work with. If you run the 100cm of belt by any # of 1cm circumference pulleys, you would gain the # of mini-pulleys times the multiple of 100 units of AC electricity.
THAT IS WHY I CALL THIS AN AC ELECTRICITY MULTIPLIER
Post by: that_prophet on September 21, 2016, 12:02:07 PM
HERE IS A LITTLE OF WHAT DRIVES ME,,, TO ENDURE YOUR HARASSING COMMENTS
Atomic structure proves that there must be a God. How else could All things, including dirt, be made of atoms. Atomic structure is so supremely complex, that man, with his superior brain power still cannot explain how it was formed, + we know that it could never have been formed in any explosion, like in the big bang theory.
Most all humanity feels that spiritual lives are not reality + this solid world around us is reality. This life that we call reality, we now know is only a simulation, practically nothing of substance, all air + minute particles,(which we keep finding is made of smaller parts) + massive energy=atomic structure. (energy that is in extremely complex settings)=settings that we humans are still trying to figure out = (where they came from, how they were formed in the first place, what they are made of, what is their purpose, how long will they last)
ALL OF WHICH POINTS TO A SUPER INTELLIGENT CREATOR
ALL SCIENTISTS VIEW GOD'S HANDIWORK DAY IN + OUT
Everything we see + touch, is made up of varying layers of complex organization = life, organic tissues, inorganic materials, chemicals, atomic structures
If EVil_sOLUTION were truth, then why is there only about 6000 years worth of space dust on our moon=God's Creation hour glass. What happened to the billions of years worth of space dust, which would have been many meters of dust, instead of the mere millimeters that we see on the moon landings.(if you take the amount that falls to the moon every year, and divide it into the amount that is there, you get closer to 6000 years worth, than billions of years=these amounts are known-just look them up) Why is it that all mutation are cancerous, and none are beneficial.
ALL MANKIND,,, YOU HAVE LESS THAN 3 YEARS
TO BECOME BORN AGAIN + ESCAPE,,,
OR GO THROUGH THE 3.5 YEARS OF FAKE PEACE
+ 3.5 YEARS OF GOD'S WRATH
WHERE GOD SENDS SATAN + ALL OF HIS FALLEN ANGELS TO OUR EARTH
THEN HE SEND 7 SEALS + 7 TRUMPETS + 7 VIALS OF JUDGEMENTS ON THIS EARTH
Post by: that_prophet on September 22, 2016, 05:50:03 PM
The full explanation of GEM=(God's Electricity Machine)
I truly do not understand the mass misunderstanding here, can't you see that evil forces are at work, keeping you from believing this Gracious Gift of God's. This was easily understood by everybody that I told this to, and they agreed that it was so obvious, that it just had to work. I will try to explain it in the same way, that I explained it to them.
            I started off by telling them that I had a large 100cm circumference pulley, and that it was connected to a DC motor. Then I told them that it only took one single spark of DC current, to rotate that large 100cm circumference pulley one full time. This would give you 100cm of moving belt, which you could then run past 1 to 10 mini-pulleys of 1cm circumference. This would give you an output of 100 to 1000 units of AC electricity, which you would run through some full wave bridge rectifiers,(4 diodes): one for each AC generator that you are using. This way you would get a lot more DC current than you would need to power your DC motor for one rotation.
           Now, try and tell me that you could not get the one spark of DC current, that you needed for your input drive motor, out of the 1000 units of AC electricity that you get as an output. Thus, you have a set of AC+DC motors/generators that run continuously, that you should be able to tap power off of, and the greater the # of mini-pulleys with AC generators attached, they greater the amount of current you should be able to coax out of you leads off of your full wave bridge rectifiers.
This was given to me for the Tribulation Saints, (I ask my ABBA Father)
+ I don't think that they will have money to buy all of these items.
When this is meant to be super simple + easy to build out of odd spare parts.
All that you need is a DC motor + an AC generator of the same voltage.
One large wheel/pulley, (like a bicycle rim) + at least one mini-pulley/wheel, (a thread role)
And a few full wave bridge rectifiers = (only 4 diodes each)
The hard part is when you would have to rig up a way to connect your motor + generators to your pulleys, (glue or threading of some sort,,, you cannot weld or bronze them, unless you found a way to disassemble them or heat sinks, to keep from frying your winding's)
Myself, I cannot believe how much of a hold that Satan has on our society, to be able to hide this super simplistic free energy technology + keep it hidden for so long. A ten speed bicycle should show us how simple this technology is. To only need to have the voltage=(electrical pressure) to rotate a 100cm circumference pulley one single time, and this giving you 100cm of moving belt. Then you run this 100cm length of belt past 10 min-pulleys of 1cm circumference, would give you an output of 1000 units of AC electricity,,, if you attached AC generators to these mini-pulleys.
THAT'S ONLY ONE SPARK OF DC IN, GIVING 1000 CYCLES AC ELECTRICITY OUT
How can you not gain a multiple of AC electricity
My type of free energy works on the simplistic reasoning of a 100cm circumference pulley only has to rotate once,(only costing one spark of current) to give you 100cm of moving belt. If you then run this 100cm of moving belt past 10 of the 1cm circumference pulleys, with AC generators attached, you would gain a multiple of 1000 units of AC electricity,,, all from one spark of DC current. With this kind of multiplication of AC cycles of electricity, wouldn't you have to gain, (multiply) your total energy output.
Yes, it is hard to fight against Satan + his evil spiritual forces, especially when this technology is so obviously logical. It only takes one spark of DC electricity to turn the motor over once + if you attach a 100cm circumference pulley to it, you would gain 100cm of moving belt. Then you run this moving belt through 10 mini=pulleys of 1cm circumference, with AC generators attached. This GEM= (Geographical Electricity Multiplier) would generate you 1000 units of AC electricity. Now,,, try and tell me that you cannot generate one spark of DC electricity, with an output of 1000 cycles of AC electricity. This is so dam simple, that it should prove to humanity that there is indeed a POWERFUL SPIRITUAL WARFARE going on over this technology.  http://free-energy.yolasite.com/
            This GEM mechanism works on the simplest of methods, by using variable sized pulleys, (simple mechanics) you can multiply your # of rotations, and with AC electricity more rotations means more AC cycles of electricity. Rotating one large 100cm circumference pulley on a DC motor only costs you one spark of current. Then, with the 100cm of moving belt that you get off this large pulley, you run this past 1 to 10 min-pulleys of 1cm circumference, giving you 100 to 1000 units of AC electricity, if you attach AC generators to your mini-pulleys.
            This AC electricity that you are generating with your mini-pulleys, only has to generate massive voltage, with practically zero current, as you only need one spark of DC current to have this a self powering mechanism. So, these AC generators cause practically zero torque, as torque comes from generating power = P=I*V, + since your current only needs to be one spark, practically zero, zero times massive voltage still equals zero. This massive voltage is what you need to crank over your DC motor the once, having the large 100cm circumference pulley attached.
            Of course there is one very simple missing part to this mechanism, it needs a full wave bridge rectifier,(4 diodes) to convert your AC output back into a DC input for your drive motor. Now, don't you think that 1000 units of AC electricity, would have the voltage to crank over your DC drive motor the one single time that it needs.
I have a person that has built three different models of these simplistic mechanisms, and says that they work great. But he has heard the horror stories about people who build free energy machines suddenly disappearing, and he does not want his name given out.
Post by: lancaIV on September 22, 2016, 06:11:23 PM
You wrote that this autor with this book has been your "key",let the forum decide that your view
is also their key or your behaviour only " a (bal)last" ,a kind of satanic=bad mis-/a-buse !
https://www.youtube.com/watch?v=LQPHgS7Cjv0 (https://www.youtube.com/watch?v=LQPHgS7Cjv0)
But you know that this bible(book of books) is not original,it is only a translated personal view from the
translator,often based by the Luther-bible,Wartburg/Germany.
An original bible is inexistant,"bible" is an archive of many pergaments roles by many mouth-2-mouth (hi-)stories.
And late: "GOD/DIOS/GOTT/DEUS was/is/will never be "MADE IN USA" or "MADE IN CANADA"
Copyright: Mesopotamien (Irak,Turkey,Syria,Lebanon,Israel)
What do you know really about the history,your or my ,what we have in common and what differ us ? You,your name Joe Lynch as delivered by your site are living in America,this continent from Alaska to Cape Horn baptizised honoring Americo Vespucci,italian carthograph.
You came from Halifax,Canada : Canada ,Labrador names given by Portuguese,in their language.
The life philosophy,the names,the languages, in the USA and Canada are often based by european-
mediterran fundaments and fundamentals-these often imported to Europe from the Asian hemisphere.
You write about many GODs,this is not right,physically, one "creation system" with many names in many languages and religions.
You can enter the www.epo.org (http://www.epo.org) site,you will see that many inventors soon before you ( or I) was borned by your mother(I by my mother) did invented and patented=publicated concepts based by pulleys/wheels motor/generator and so on !
Simple solutions but commercial not of interest. Simple truth. :)
                                              the truth: the priority date
            your "peers" are stealing the work honor of others,not fine,not to say satanic
Post by: that_prophet on September 24, 2016, 01:48:54 AM
AWE, COME ON PEOPLE, WE MUST SHAKE OFF SATAN'S ILLUSION.
This technology is the most super simplistic in its workings
You only have to gain the voltage=(electrical pressure) to rotate your DC motor the once,
If you attach a large 100cm circumference pulley to this DC motor,
This would gain you an output of 100cm of moving belt
+ if you ran this 100cm of moving belt through 10 mini-pulleys of 1cm circumference
You would gain a return of 10X100=1000 units of AC electricity
All for the input cost of one spark of DC current
Your AC generators run free, causing no torque, as they are just winding up massive voltage,
Which just happens to be exactly what you need, to crank over your drive motor
Massive voltage =(electrical pressure) to be able to crank over your one large pulley + many small pulleys
Quote from: pomodoro on May 18, 2015, 01:42:40 AM
Post by: lancaIV on September 24, 2016, 02:43:15 AM
                                     thats_prophet,are you a "hat" ? A "peer"  member ? This mean 'phet' !
                                      DO YOU REALLY HAS AS PROPERTY  7 SEALS DEGREE/GRADUATION ?
Edit: my "Père of the peers" told me that I did a fault,I please you for " VOUS pardon moi,Joe ?",
        not "thats_prophet" but correct : "that_ prophet"
                pater:Latin,Singular  père:French,Singular Vater:German,Singular   Father:Englisch(Ex-anglo-saxonic),Singular
                written,spelled and spoken
Post by: massive on September 24, 2016, 03:13:18 AM
a high speed DC dremel will stall easily even though it has a cutting blade , the force applied to the perimeter of a small cutting blade will stop it and the brushes burn ..... done it .
a wheel chair has large wheels at the back so the person has sufficient leverage ......if those wheels were swapped for smaller wheels it would strain the person out in no time .
an electric wheel chair has small wheels so there isnt so much strain on the electric motor ......if the wheels were larger the motor would suffer .
a church group needs to make the pulley generator , after all its the church that gets the money , tax free too
Post by: that_prophet on September 24, 2016, 05:06:43 PM
Quote from: massive on September 24, 2016, 03:13:18 AM
       I agree, and that was what I thought was the best idea at first,,, then I found out how deep the spiritual warfare really was. It was so deep that ministers could not even see through it, and they did not believe in His GEM of a Gift,,, no, not one, out of around 5-10. But then I should not have thought that strange, as they also never agreed with my telling mankind that we were continuously breaking the 3rd Commandment, every time we use "I am" to describe ourselves,,, nor did they take me serious when I told them that the Door was going to shut on His 1st Arrival in the clouds, in less than 3 years. The last generation was about to end in Jan 15, 2019, so the 7 year peace treaty MUST be signed by or before 2019.04
     Now, back to the AC electricity multiplier. So I figured I had claimed ownership by publishing it on the web @  http://free-energy.yolasite.com/ in 2000 or 2001 + now nobody else could patent it, so I would let it stand as truly free energy, without even patent fees. THEN OBAMA CHANGE THE PATENT RULES, but still nobody could see through the powerful evil spiritual warfare covering this technology up. So, it is still not being used,,, GRRRR,,,
Post by: that_prophet on September 24, 2016, 05:49:49 PM
Quote from: Magluvin on February 06, 2014, 10:23:57 PM
Hey Prophet
NO, I happen to be disabled, with shaky hands
I also happen to be poor, on CPP Disability funds
so I cannot even afford to hire someone to build it for me
[/quote]
Mags
[/quote]
there is no torque problem, as these generators are just winding up massive voltage,,,
as you only need to generate one spark of current, to have this GEM of a mechanism self powering
Post by: that_prophet on September 24, 2016, 06:11:14 PM
Quote from: TinselKoala on February 06, 2014, 11:05:45 PM
Not again!
how about gaining the 20-30 feet up a very steep hill, every time I drove up the hill fast, + then back down the hill slow. I gain the 20-30 feet every time that I repeated the test, 3 times = gaining a total of 60-90 feet up a ver steep hill
Post by: that_prophet on September 24, 2016, 06:26:54 PM
Quote from: tinman on February 07, 2014, 08:12:41 AM
@ Prophet
OK, who is Sterling Allan, do you mean that he might actually build one for me,,,
AWESOME, how do I get in contact with him?
Post by: that_prophet on September 24, 2016, 06:43:34 PM
Quote from: Pirate88179 on March 14, 2015, 12:53:02 PM
Bill
Lenz law sounds like something electronic, when this works om simple pulley mechanics = 100cm circumference pulley only turns once + this gives you 100 turns times the # of 1cm circumference pulleys that you attach. If you attach AC generators to each of these 1cm mini-pulleys, you would gain 100 units of AC electricity, for every 1cm pulley that you attach. This could be massive amounts of free AC electricity, if you added 10's of these mini-pulleys
Post by: lancaIV on September 24, 2016, 06:57:01 PM
Here is a possibility to get a step closer to your wish :
http://jbpowersystems.weebly.com/index.html (http://jbpowersystems.weebly.com/index.html)
http://jbpowersystems.weebly.com/the-energy-multiplier-system.html (http://jbpowersystems.weebly.com/the-energy-multiplier-system.html)
how ?
with a call
! but not with "Jerry" because he died (RIP) some time back !
speak about this demonstration modell/prototype for a greater audience demonstration
http://jbpowersystems.weebly.com/uploads/7/9/0/1/7901462/7608379.jpg?228 (http://jbpowersystems.weebly.com/uploads/7/9/0/1/7901462/7608379.jpg?228)
https://www.google.com/patents/US7709970
https://www.google.com/patents/US8541894 (https://www.google.com/patents/US8541894)
Post by: that_prophet on September 24, 2016, 07:02:21 PM
Quote from: MarkE on March 26, 2015, 09:45:30 AM
what reasons,,, you are not talking about the same laws that this runs on,,, electrical laws or thermodynamics do not apply here. This is simple pulley mechanics = 100cm circumference pulley turns only once + this 100cm of belt coming off it can turn 1 to 10 1cm circumference pulleys 100 rotations each. So, if you use 10 mini pulleys, you would gain a multiple of 10 X 100 = 1000 units of AC electricity,,, all from the one single spark of DC current, that drives you 100cm circumference pulley
Post by: that_prophet on September 24, 2016, 07:17:25 PM
Quote from: MarkE on March 26, 2015, 01:33:21 PM
Sorry, but I don't have the money to hire people to build this for me.
BUT,,, SIMPLE PULLEY MECHANICS HAS ONE LARGE 100cm CIRCUMFERENCE PULLEY TURNING ONCE, WHICH ONLY COSTS ONE SPARK OF DC CURRENT, CONNECTED TO A BELT THAT DRIVES 10 OF THE 1cm MIN-PULLEYS TO ROTATE 100 TIMES EACH + IF YOU ATTACH AC GENERATORS TO THESE MINI-PULLEYS = YOU WOULD GAIN 10 X 100 = 1000 UNITS OF AC ELECTRICITY = ALL FOR ONE SPARK OF DC CURRENT.
Post by: lancaIV on September 24, 2016, 07:30:35 PM
Quote from: that_prophet on September 24, 2016, 06:26:54 PM
I do not think so that he has the right resources around :
https://www.google.pt/search?client=opera&q=sterling+allan+jail&sourceid=opera&ie=UTF-8&oe=UTF-8 (https://www.google.pt/search?client=opera&q=sterling+allan+jail&sourceid=opera&ie=UTF-8&oe=UTF-8)
with some moral distance:
contact to  Jerry Blevins (R:I:P:)family/relatives:
Email: jbpowersystems@gmail.com[/font][/size]P: 540-335-0228[/size]
Post by: lancaIV on September 25, 2016, 03:30:12 AM
Quote from: that_prophet on September 24, 2016, 05:06:43 PM
     Now, back to the AC electricity multiplier. So I figured I had claimed ownership by publishing it on the web @  http://free-energy.yolasite.com/ (http://free-energy.yolasite.com/) in 2000 or 2001 + now nobody else could patent it, so I would let it stand as truly free energy, without even patent fees. THEN OBAMA CHANGE THE PATENT RULES, but still nobody could see through the powerful evil spiritual warfare covering this technology up. So, it is still not being used,,, GRRRR,,,
        10 COMMANDMENTS and the me,MYSELF and I
        i and I                       ordinary singular  and SINGULAR MAJESTATIS
        we and WE               ordinary singular  and PLURALIS MAJESTATIS
        in YOUR language are the 10 COMMANDMENTS enclosed
                                                     Immanuel Kant 11 COMMANDMENT=VOKATIV IMPERRATIV=COMMAND
        use it  "I believe in God" 8)  EXERZITIEN
                                                     EXERZITIEN: https://en.wikipedia.org/wiki/Retreat_(spiritual)
        cum aspiration: conspiration spira~spirit
        body language,MIND LANGUAGE :SOUL=2in1 UNITY
                                                              https://www.youtube.com/watch?v=ux3u31SAeEM (https://www.youtube.com/watch?v=ux3u31SAeEM)
        release your SELF
        let HIM flow
To be attended and to correct errors in the conversation syntax : "Good Morning,Joe !"  and "Good bye,Joe ! "
p.s.: "Sorry,Pardon=Excuse me,please !" for my overruling ;)  Nobody is perfect ! Nomind sometimes ! I believe so !
        Probably insane,this MIND !
Post by: Paul-R on September 25, 2016, 10:55:30 AM
Quote from: that_prophet on February 06, 2014, 09:19:10 PM
- Scriptural Proof we are allowed to know these doors/deadlines (Mat 24:33)
I am more impressed by Mat 27.5 and Luke 10.1.
"He went and hanged himself" .... "Go ye and do likewise"
Post by: lancaIV on September 25, 2016, 11:48:27 AM
Basic school ,Speyer am Rhein/Germany ,Maetthaeus/"Matthew": words exposed as life "motto"
                     Erst denken ,dann sprechen  ::)   (today: erst denken,dann reden)
https://encrypted-tbn1.gstatic.com/images?q=tbn:ANd9GcRRy2Wb58bvKFxIYiTD4ENfUOjx3nJuuTjhkHsfIJflWIu6g-Ht3A (https://encrypted-tbn1.gstatic.com/images?q=tbn:ANd9GcRRy2Wb58bvKFxIYiTD4ENfUOjx3nJuuTjhkHsfIJflWIu6g-Ht3A)
                          tribu,tribut,tribunal
                     denken ~ to think criticare/critizise
nomen:         Think Thing/Ding/Tribunal    lawn/law judgement
                           judge  ad-vocate angeliis(+) diaboliis(-)
omen:               thinken,to execute ,to decide
place:          death penal,Gerichtsbaum,Tribe-Tree:
                                        often the Oak=Eiche (life duration ! 1000 years oak)
        f.e. Guernica Gau-Tree
                          or  Dingelstaett/Eichsfeld
https://upload.wikimedia.org/wikipedia/commons/thumb/b/b4/Wappen_Dingelstaedt.png/139px-Wappen_Dingelstaedt.png (https://upload.wikimedia.org/wikipedia/commons/thumb/b/b4/Wappen_Dingelstaedt.png/139px-Wappen_Dingelstaedt.png)
                    sprechen   to speak,to speech to spreach
nomen       Speaker ,Speakers corner(Hyde Parc/London/GB)
                              and the"Henker,the death executor"
               judge,advocate and executor in personal union,lets do it :
                       ;D "He went and hanged himself" ;D
https://www.alasiesta.com/images/product_images/info_images/haengematte-caribena.jpg (https://www.alasiesta.com/images/product_images/info_images/haengematte-caribena.jpg)
         Religion is not a weapon,but sometimes be abused like a
erst denken,dann "sprechen": by mouth,body,or written letter or e-letter/mail
Post by: that_prophet on October 16, 2016, 01:37:41 PM
Quote from: that_prophet on September 24, 2016, 06:43:34 PM
+ this gives you 100 turns, X,(times) the # of 1cm circumference pulleys that you attach.
if you added 10's of these mini-pulleys then you would gain 1000's of units of AC electricity,
all done with one spark of DC current, (practically zero)
that_prophet - Re: use pulleys to multiply total # of rotations = AC electricity
Quote from: citfta on October 14, 2016, 01:05:13 PM
I don't understand how you can be so dense.  You have had numerous people tell you that your idea will not work.  That is because we actually have experience working with motors and generators.
REPLY BY ME
I don't understand how mankind be so dense, to not see that this use of pulleys does not involve torque, but simple multiplication of rotations = multiplication of AC electricity. The AC generators are just winding up massive voltage, to turn over your DC motor, only the once, + no current, as you only need one spark to have this self powering.
Now try and tell me that you would not be able to get one spark of DC output,
when you have 1000's of units of AC electricity to work with
Post by: that_prophet on October 16, 2016, 02:11:07 PM
Quote from: that_prophet on September 24, 2016, 07:02:21 PM
REPLY BY ME
Post by: citfta on October 16, 2016, 04:56:49 PM
Your device is useless!
Post by: sm0ky2 on October 17, 2016, 02:35:20 AM
When a generator is under load
i.e. - charging batteries or powering a device
Increased rpm = increased torque required
To turn the generator
If you gear it to a ratio of 100 to 1, you will
Require 100x's the torque to turn the smaller
Gear/pulley/lever/etc.
If this is an impulse from a dc motor,
This directly related to current draw and an
Increase of input power.
Qumogens are like gremlins, don't get them wet.....
Post by: that_prophet on February 08, 2017, 06:14:38 AM
Re: GEM=(Geometrical Electricity Multiplication)
« Reply #61 on: Today at 01:09:57 PM »
by that_prophet@yahoo.ca
= joe Lynch
Just one of His Creations
Using pulley mechanics to multiply AC electricity
I was hoping that I could enrage many deceived people,
--- once they saw just how super simple this idea is, that these evil spirits are desperately hiding
--- --- but I have not yet been able to break this solid hold that they have on the masses
--- --- --- until now,,,
How can you not be multiplying AC electricity, when you pay for only one rotation of a DC motor,
--- with a 100 cm circumference pulley attached. (costing higher Voltage + 1 spark of current)
--- --- to crank it over once, gaining 100 cm of moving belt
--- --- --- and then getting back 1000's of units/cycles of AC electricity
--- --- --- --- by running your 100 cm of moving belt past 10 mini-pulleys of 1 cm circumference
--- --- --- --- --- thereby multiplying your rotations to 10X100=1000
--- --- --- --- --- --- ( HOW CAN YOU GO WRONG )
(WHAT I CAN'T BELIEVE, IS HOW GREAT A HOLD THAT EVIL FORCES HAVE ON MAN)
--- to hide this super simple method of multiplying our AC electricity
--- --- from His ministers even
--- --- --- as I have tried to get 3 or more churches to patent this,,,
--- --- --- --- WITH NO TAKERS,,,
(CRAZY,,, considering that once this is discovered to be real, every government in this world)
(will pass laws, mandating that this tech is used + not oil burning engines,,, which funds terrorist)
1 rotation of a 100 cm circumference pulley will give you 100 rotations for as many of the # of
1 cm circumference pulleys attached + with adding simple generators to these 1 cm mini-pulleys,
you can be multiplying your # of AC cycles/units of electricity
---  All through what seemingly legally breaks the laws of thermodynamics
--- ---  by using simple pulley mechanics, that we learn in grade school
--- --- --- to actually multiply our AC electricity - (instead of paying for oil to generate it)
YES, through pulley mechanics, you can trade one revolution of a 100 cm circumference pulley,
--- into 100 rotations of a 1 cm circumference pulley, (for every 1 cm mini-pulley you add to belt)
--- --- so if added 10 mini-pulleys, you would get a return of 10X100=1000 cycles of AC electricity
THAT'S ONE ROTATION OF A DC MOTOR BEING MULTIPLIED
--- INTO 100 ROTATIONS OF AN AC GENERATOR
It's as simple as using the laws of pulley mechanics to multiply our AC electricity, by paying for one rotation of a 100 cm circumference pulley, and gaining a return of 100 units/cycles of AC electricity.
WHY CAN YOU NOT SEE THE BASIC SIMPLICITY OF,
THIS USE OF PULLEYS TO MULTIPLY AC ELECTRICITY.
This is a way of seemingly legally breaking the laws of thermodynamics
By using simple pulley mechanics to multiply your rotations = AC electricity
remember, I have already had one man build 3 different models,,,
but he is worried about the rumors of people disappearing,
I mean those who had actually built working models
the Book that I put all of my faith in is the Word of God
+ if you want to see how the Holy Bible can prove itself God inspired
you should read a novel  called "Armageddon" by a Canadian author named Grant Jeffrey
which proved to me that the KJV Holly Bible was truly Written by God
He did this by systematically going through fulfilled Bible Prophecies,
and showed how they were fulfilled right down to the exact day
+ Who else but God, could consistently predict the future
it was one of the rules with God, the one about how He gave a second chance to Israel
after 10 times the original duration
As in, when you take 10 times the original duration, of the prophecy about when Jesus would enter Jerusalem, you get a second chance for Israel. I don't know about you, but I happen to be quite the skeptic, and thought that maybe the reasons that these prophecies worked out so perfect, was that they were written or changed after they were fulfilled. But this one about Jesus entering Jerusalem on the exact day, + when you take 10 times the original duration, of the time between when it was prophesized + when it was fulfilled, you get may 14th 1948, when the nation of Israel was reborn. http://www.grantjeffrey.com/pdf/JeffBIBLE-EzekVision2.pdf
<<< EVil-sOLUTION >>> (isn't it amazing what is revealed by the il-s of life)
THIS IS GOD'S GIFT TO THE SOON COMING TRIBULATION SAINTS
Because the Door will close on this Prophecy being fulfilled on Jan 15th , 2019
http://doorschristmustpassthrough.yolasite.com/, http://2020-vision.yolasite.com/
These are the rules God has set before us
http://beliefstoliveby.yolasite.com/
possible timing for TRIBULATION SAINTS
http://possibletimingfortribulation.yolasite.com/
UFOs + GHOSTS do exist, there are just not who they pretend to be
http://aliensandghosts.yolasite.com/
It was how God predicted, to the exact day,,, May 14th, 1948
the day that Israel would get their second chance + become a nation again
Written in the Holy Bible way back in Ezekiel's day
This convinced me that the Holy Bible spoke Truth
About Jesus Christ paying for our Salvation
+ Jesus being the only Door for us to enter Heaven
Becoming a part of God's Family
Title: Re: GEM = God's Electricity Multiplier
Post by: that_prophet on May 05, 2017, 06:20:05 PM
 Free energy in UFO motor, described  in the Bible
+ multiplying AC electricity with multiples of both size and #'s of pulleys
= https://free-energy.yolasite.com/
- this is so super simple,
that we should be ashamed of allowing satan
+ his fellow evil spirits, to have kept it hidden
for so long = ever since Ezekiel 1:16
- "a wheel in the middle of a wheel",
where it was the first simplistic described how a UFO motor worked in the Holy Bible,.
You only pay one small bit of DC current
to rotate 100 cm circumference pulley one single time,,,,
+ through running the 100 cm of moving belt,
(which came off the circumference of pulley)
+ running it by 10 of the mini- 1cm circumference pulleys
+ attaching AC generators to each pulley,
you can multiply your AC electricity to 10X100=1000 cycles of AC electricity
,,,,,,,,,,,,,,,,,,,,,,,, all for the cost of one spark of DC current
=(just enough to rotate your DC motor one single time)  .  .  .   .  .  .  .  .  .  .  .  .  .  .  .  .  .  .   .  .  .  .
<<< NOW TRY + TELL ME THAT YOU CANNOT GET ENOUGH VOLTAGE FROM THESE 1000 CYCLES OF AC ELECTRICITY,,, + ONLY THE ONE SPARK OF CURRENT, THAT IT TAKES TO ROTATE YOUR DC MOTOR ONE SINGLE TIME >>>
(I hope this makes you realize reality, + how powerful spiritual warfare is going on all around you every day)
YES,,, GOD IS REALITY,,, + HE IS COMING BACK BEFORE 2019.04=Door –(in air for all born-again who are looking for His Coming)
although we are warned that "of that day and hour knoweth no man"-Mat 24:36,
we are also told that we can "know that it is near, even at the doors"-Mat 24:33
Just think of it this way, you are only putting in one small bit of DC current,
Enough to crank over your DC motor once, with a 100 cm circumference pulley attached,
+ through simple pre-school  pulley mechanics, of running this 100 cm of moving belt,
that comes off the one rotation of your 100 cm circumference pulley,
Past 10 mini-pulleys of 1 cm circumference, with free running AC motors/generators attached,
+ you will get 10 X 100 = 1000 cycles of AC electricity.
All for the cost of DC current to rotate your DC motor one single time = only one spark
http://my2020vision.yolasite.com/
http://evotutionfairytale.yolasite.com/
Post by: ramset on May 05, 2017, 07:10:59 PM
Joe
Is everything OK ?
Just making sure !! [Seeing a bunch of threads pop up...
respectfully
Chet K
Post by: AlienGrey on May 06, 2017, 08:58:42 AM
Quote from: ramset on May 05, 2017, 07:10:59 PM
Joe
Is everything OK ?
respectfully
Chet K
yeah the word 'GOD' is short for 'Godre'el' (pronunciation) spelling 'Gadre'el' is Satan's real name! if you're a satanist, worship 'it' but please don't 'bring' incorrect translations here! and try tricking us into worshiping some false evil demonic entity, many thanks but no thanks!
Pease put it on Facebook ........... Not here!
AG
Post by: pomodoro on May 06, 2017, 10:16:06 AM
Yep, Jehova is his real name, just ask the witnesses. How about we we ignore these posts from this guy  so they quickly move down. He was told not to post any more than one thread at a time. I dont know how he sleeps at night,  sharing secrets like this publicly , I'd be shitting in my pants because the men in black and others know where he lives.
Post by: AlienGrey on May 06, 2017, 12:29:02 PM
Realy ? look up 'Jehovah' it describes a real eval trouble making 'thing' better to leave it alone rather than digging a bigger hole!
AG
Post by: that_prophet on June 07, 2017, 06:27:17 PM
What is AC electricity, + how is it made, out of rotations of a coil of wire through a magnetic field right, + a set of varying sized pulleys, can be easily used to multiply the total # of rotations. This is one free energy technology that we all will need and love = no cost, fuel or exhaust. So,,, why haven't we figured this simple little bit of technology. Can you believe the power of evil spirits, to be able to dumb down a whole population of humans
TIME IS SHORT = the Pre-Trib Rapture + the infamous 7 year peace treaty with Israel MUST START before the Door closes on 2019.04 - http://doorschristmustpassthrough.yolasite.com/ . (Christ must return)
We were given the best Gift from God, (other than Jesus) right here in Atlantic Canada + just before the infamous 7 years Peace Treaty, + 2nd half  as being the (Great Tribulation) where most all of the fallen angels, and Nephilum = angel offspring with women will be sent to the earth. This is not only the ones that are still alive, but also the spirits of all that have died. This could be massive amounts of evil spirits, considering that this includes the ones from before the flood.
Post by: citfta on June 08, 2017, 09:21:56 AM
A clear example of insanity is someone that keeps doing the same thing over and over expecting a different result to happen.
Joe, why can't you understand that no one on this forum is interested in your continuous posting of the same thing over and over again.  Please find somewhere else to post your spam.  It is getting very tiresome here.
Post by: that_prophet on June 11, 2017, 02:57:12 PM
EVil-sOLUTION - free energy can be found in a UFO motor description in Ezekiel 1:16
TIME IS SHORT = the Pre-Trib Rapture + the infamous 7 year peace treaty with Israel MUST START before the Door closes on 2019.04-"know that it is near, even at the doors" Mat 24:33   http://doorschristmustpassthrough.yolasite.com/ . DOOR = (Christ must return before date) We were given the best Gift from God, (other than Jesus) right here in Atlantic Canada + just before the infamous 7 years Peace Treaty, + 2nd half as being the (Great Tribulation) where most all of the fallen angels, and Nephilum = angel offspring with women will be sent to the earth. This is not only the ones that are still alive, but also the spirits of all that have died. This could be massive amounts of evil spirits, considering that this includes the ones from before the flood.
What is AC electricity, + how is it made, out of rotations of a coil of wire through a magnetic field right, + a set of varying sized pulleys, can be easily used to multiply the total # of rotations. This is one free energy technology that we all will need and love = no cost, fuel or exhaust. So,,, why haven't we figured this simple little bit of technology. Can you believe the power of evil spirits, to be able to dumb down a whole population of humans. Think this may be a reason to find God http://beliefstoliveby.yolasite.com/
Do you want to hear how super simple this technology is,
Where you only pay to crank over one time, the DC motor + one 100 cm circumference pulley,
Then you use the 100 cm of moving belt off this large pulley circumference ,
+  run it past 10 mini-pulleys of only one centimeter circumferences,
All that you have to do is add AC generators to these 10 mini-pulleys,
Giving you a free return of 10X100=1000 cycles of AC electricity.
That's one small pulse of DC current as an input, returning you 1000 cycles of AC electricity,
You are using the dirt simple laws of pulley mechanics to multiply rotations,
+ since AC electricity is generated by simple rotations
Believe it or not, you are using this pulley mechanics, to freely multiply your AC electricity
+ you could easily multiply your AC cycles of electricity
IT IS TRULLY THAT SIMPLE..................................
You are using simple Pulley mechanics to multiply AC electricity cycles
And don't you believe that torque is a problem,
You have 10 X 100 = 1000 cycles of AC electricity,
To make up the one spark of DC current that you need,
That this DC drive motor needs to be cranked over the one time,
Giving you the 100 cm of moving belt = off 100 cm circumference,
This motor – generator power system is self powering,
It can do this by creating massively more electrical power from your many # of AC cycles,
That you can produce from your many AC generators, attached to many of these mini-pulleys,
Which are so easy to rotate, because it does not take 100 times more power to rotate a large pulley,
Yet this large pulley gives you 100 cm of moving belt off one single rotation,
Which by passing by 10 mini-pulleys with AC generators, can produce 10X100=1000 cycles of AC electricity, thereby multiplying your total amount of cycles of AC electricity,
By only needing a miniscule amount of DC current to rotate only once,
+ producing as many thousands of cycles of AC electricity, as you added the # of mini-pulleys,
With AC generators attached
CAN YOU BELIEVE HOW SIMPLE THIS TRULY IS
+ how powerful this spiritual warfare must be,
to be able to hide this super simple AC multiplier from us gullible humans..............
We can use pulley mechanics to freely multiply rotations,
Thereby we are using pulley mechanics to multiply cycles of AC electricity
I don't know about you, but I was amazed at how simple this preschool way of using pulleys to multiply your # of rotations, thereby multiplying AC electricity by using this simple pulley technology. And can you believe the power of evil forces, to be able to hide this super simple way of using pulleys to multiply the total # of rotations, or AC electricity. For how long,,,,,,,,,,,,,,,,,,,,
Think about this, for how long have they been able to hide this free AC multiplying technology,,,,
The thing is, that there is the most powerful spiritual warfare going on about this simple free energy technology, and evil forces will immediately start confronting you as soon as you start looking into this. I can be sure that evil forces will whisper in your ear, many ways that this cannot possibly work. For why should evil spirits want us to be able to stop buying oil, from nations that in one way or another tend to promote terrorist, and their careless destructive ways. I believe that God gave me this technology back in the early 2000's when He first gave me a Vision of a 10 speed bicycle going uphill in 10th gear, and then back downhill in 1st. This is very significant where AC electricity is concerned, where you may need massive voltage, to crank over the pedals on the way up, but it costs way less current, as the motor runs for only a few rotation. Then when you run the bicycle down the hill in 1st gear, you would be winding over your AC generators massive amounts of time. Please remember that AC electricity is generate through rotations of a coil of wire through a magnetic field, and the more rotations means more AC electricity.
here is one of the forums that my GEM pulley free energy
(here is a picture that shows basic idea of this GEM tech)
(but the small pulleys should be much smaller + 1-3 not 4)
Come on Canadians,,,
Come on Nova Scotia,,,
This is where this GEM-(Geometrical Electricity Multiplier) technology of free energy for the End Times was 1st started. Let's get out there and start taking advantage of it, by not only building GEM units to power all of our electric tools, toys + gadgets, but we could be starting companies that have electric appliances, utensils, devices, tools, toys, + gadgets with these GEM perpetual power supplies built into them, (let's start letting electricity generate itself) + on our labels we could even proudly say "FIGHTING TERRORISM + FIGHTING POLLUTION"
COME ON,,, ALL OF YOU BACK YARD MECHANICS,,,
Get some AC + DC motors together of the same voltage, and start building these GEM free energy power supplies,, + not only for 1.5, 3, 6 + 9 volt batteries, but household 120, + 12 volt, for powering these new electric cars. Let's throw the oil companies the bird, + maybe even make money with them, by throwing any excess power from these perpetually running energy generators that we have the time, + small amount of money to purchase parts to build. Think of it as not only keeping money in your pocket, but you are keeping money from the countries that fund terrorist. This is not to mention the experimenting that we could be doing with the anti-gravity + speeds approaching light speed. Now I know that there are many out there like me, that would enjoy knowing how one type of this motor was powering a UFO in the Bible, in Ezekiel 1:16.
Although we are warned "but of that day and hour knoweth no man"(Mat 24:36), we are also assured that we can "know that it is near, even at the doors", (Mat 24:33) Where the door closes on the Prophecy when it can no longer be fulfilled. My name is Joe, and I now live at a nursing home in Nova Scotia, and if you can find me an electronic simulator that I can use, I will show you how this free energy technology can and will work for man, instead of man having to work for energy. In any case, please let me show you how all of the barriers can be overcome, instead of taking Satan's words for it, when he or the billions of evil spirits throw excuses at you, for why this will never work. My email is one_christian_warrior@yahoo.ca
http://fire-starter.yolasite.com/
This pulley technology works,,,
Here are a few of ideas that others have,
Knowing or not knowing that it is based on the same GEM technology
but just watch + learn THESE DO INDEED WORK
GEM technology is true free energy, except for that former President,
That switched the patent law to be more accessible to others
+ In theirs it only has one mini-pulley, + not 3 or 10 like in mine
https://www.youtube.com/watch?v=IjN1refTtHg
https://www.youtube.com/watch?v=A1ZGOgcZp_g
https://www.youtube.com/watch?v=RD2GrpBIMXc&t
+ you can be sure that more people will come out with their own GEM tech
mankind will hopefully move quickly with this new found pulley technology
where in no time, people will be starting up factories to add this free energy tech
to all electronics + electric mechanisms + yes, even automobiles,,,,,,,,,,,,,,,,,,
can you imagine cars that don't cost any fuel to travel, any amount of distance you want
+ think of how the cost of everything will go down, with no fuel costs to transport stuff,,,,,,,,
Post by: that_prophet on June 11, 2017, 03:07:27 PM
PLEASE DON'T FORGET, THIS FREE ENERGY MECHANISM WAS FOUND POWERING A UFO
in Ezekiel 1:16, so we need to experiment with this tech, + see how it can be used in levitation
Quote from: webby1 on October 17, 2016, 07:47:42 AM
http://overunity.com/16707/use-pulleys-to-multiply-total-of-rotations-ac-electricity/msg491963/#msg491963
But of course you will not build it,, what will be your next excuse?
Post by: profitis on June 22, 2017, 02:37:45 PM
"spiri"
Let it be known that a vicious curse shall befall anyone who uses that cross as a knife pta pta
Post by: that_prophet on August 26, 2017, 11:33:43 AM
TIME IS SHORT = the Pre-Trib Rapture + the infamous 7 year Peace Treaty with Israel MUST START before this 1ST DOOR closes on 2019.04 = Jan 14th http://my2020vision.yolasite.com/ - "know that it is near, even at the doors",(Mat 24:33) http://doorschristmustpassthrough.yolasite.com/.
Free Energy + perpetual motion can be easily produced using pulleys, costing only the minuscule bit of power that it takes to rotate a DC motor with a large 100 cm circumference pulley one single time. You can gain or multiply massive amounts of AC electricity using mini-pulleys with AC generators. You are capable of doing this by running this long length of belt, (off the circumference of large pulley) past a few 1 cm circumference mini-pulleys, with AC generators attached. This GEM-(Geometrical Electricity Multiplier) device is gaining you 100 cycles of AC electricity, for every mini-pulley that you choose to attach to this sane belt. So, if you added 10 mini-pulleys, you could get a return of 1000=10X100 cycles of AC electricity, and all costing you only one mere spark of DC current. How could you not be multiplying AC electricity, when you are using simple pulley mechanics to trade one spark of DC current, for 100-1000 cycles of AC electricity-(duel sparks).
This super simple free energy technology: http://free-energy.yolasite.com/ works on the ability of combinations of pulleys being able to easily + freely multiply your total # of rotations. You can do this because of the fact that you don't have to expend 100 times more electricity to rotate a large 100 cm circumference pulley, than it takes to rotate a 1 cm circumference mini-pulley. Yet if you run the 100 cm of moving belt, that comes off the one rotation of a large 100 cm pulley, past any # of mini-pulleys of 1 cm, then you could gain a return of 100 rotations for every mini-pulley that you choose to attach to the same belt. (As for torque, it only comes from generating power, and power is voltage multiplied by current) + We only need to produce one single spark of DC current to make this a self-powering mechanism. So one spark of DC current, (which is practically nothing) multiplied by even massive voltage, would still equal practically zero power, which takes practically zero torque to rotate.
This multiplication of rotations could be extremely helpful, if you only added AC generators to these mini-pulleys, you could be multiplying the total cycles of AC electricity. This AC generator takes no torque to rotate, because although it would be winding up massive voltage, it does not need to be winding up practically any current-(1 mere spark) which is practically zero. Torque is only caused when you are generating power, and you are generating practically zero power, as power is equal to voltage times current. So, no matter how massive of voltage you are generating, it is multiplied by practically zero current, as we only need one spark of current, or practically zero. This works because zero times anything is still equal to zero, and practically zero works the same way.
What is AC electricity, + how is it made = it is made out of the easy rotations of coils of wire through a magnetic field of two oppositely positioned magnets right. Using pulley technology, we can easily + freely convert one rotation of a large 100 cm circumference pulley, into 100 rotations of as many 1 cm circumference mini-pulleys that we choose to attach to the same belt that comes off of your large pulley. So, if you added 10 mini-pulleys to this same belt, and added AC generators to each mini-pulley, you could gain you 1000 = 100X10 cycles of AC electricity.
All these cycles of AC electricity are from the single burst of DC electricity, which is the small amount of current that a DC motor takes to rotate one single time =(one mere spark). These cycles of AC electricity would cost practically zero torque to rotate, as torque is only caused when you are generating power, and you are not generating practically any power in this system. This is because although you may be winding up massive voltage,(electrical pressure) to keep this GEM mechanism running, you only need to generate one single spark of DC current, and P=IV, or power equals current multiplied by voltage.
So your total power output would be practically zero current multiplied by any amount of voltage, which would still be equal to practically zero power, taking practically zero torque. So, you could be easily + freely generating massive amounts of rotations of these mini-pulleys, which are generating you massive voltage, or the ability/potential to gain plenty of current, which will allow you to produce plenty of power. This is because the greater the voltage/pressure, the greater the ease that there is to generate more current. PLEASE,,, let me show you how ridiculous this mythical torque problem really is. Do you think that the 100 cycles of AC electricity would have a hard time producing the single spark of DC current, which is all that you need to crank over your DC motor once, with your 100 cm circumference pulley attached?
Mankind was given the best Gift from God, (other than Jesus) http://free-energy.yolasite.com/ right here in Atlantic Canada + just before the infamous 7 years Peace Treaty. This seven years of time, which the 2nd half of is the Great Tribulation, is when this GEM tech will be needed most. This will be the worst time for earth, where not only is there constant war, but most all of the evil fallen angels, and the Nephilum , will be sent to the earth. Nephilum are the offspring of fallen angels + human women, as angels are all male, because God only wanted there to be a set # of angels. This is not only the ones that are still alive, but also the spirits of all that have died. This could be massive amounts of evil spirits, considering that this includes the ones from before the flood. (How can we be billions of years old, when the moon will leave orbit within 10,000 years) + all orbiting bodies will have messed up orbits, because of this yearly amount of space debris adding mass.
This is free energy technology, which we all will need and love, as it has practically no cost to run, and there is no need for any fuel to be purchased. Nor would there be any exhaust to cause environmental or noise pollution. So,,, why haven't we figured this simple little bit of technology out long ago? Evil spirits are, and have been hiding this simple technology from mankind. These AC generators are extremely easy to rotate, because the only resistance torque,(other than the viscosity of the lubricant in the bearings) would come from a great need for current, which would practically never happen, especially when you are dealing with such small amounts of power as the example that I describe here.
I confirmed that this free energy technology, discovered in the early 2000's, was from God + not from evil forces, by finding it in a UFO motor description in Ezekiel 1:16. Thankfully, there are many ways that we can freely multiply the total # of rotations, like a set of varied sized pulleys, can be easily used to multiply the total # of rotations. Then, by simply adding an AC generator to your mini-pulley, you can convert your rotations into cycles of AC electricity.
This is one super simple GEM of an idea, and it is made from pre-school technology, so why was this not out long ago. Can you believe the power that evil spirits have, to be able to dumb down a whole population of humans + for so long. I still have problems getting people to believe that there is no torque problem. Think that this may actually be a good enough reason for you to find out if GOD IS REAL = http://beliefstoliveby.yolasite.com/ + if HE IS RETURNING SOON = http://my2020vision.yolasite.com/
Do you want to hear how truly super simple this technology is, Where you only pay to crank over the DC motor one time, with a 100 cm circumference pulley, Then you use the 100 cm of moving belt off this large pulley circumference, + run it past one or more mini-pulleys of only one centimeter circumferences, All that you have to do is add an AC generator to these mini-pulleys, giving you a free return of 100's of cycles of AC electricity. That's one small pulse of DC current as an input, returning you 100 cycles of AC electricity output, How can you not multiply your AC electricity, with this rotation multiplication technology
This is where this GEM-(Geometrical Electricity Multiplier) technology of free energy for the End Times was 1st started, (early 2000's when He first shared this with me). Let's get out there and start taking advantage of it, by not only building GEM units to power all of our electric tools, toys + gadgets, but we could be starting companies that have electric appliances, utensils, devices, tools, toys, + gadgets with these GEM perpetual power supplies built into them, (let's start letting electricity generate itself) + on our labels we could even proudly say "FIGHTING TERRORISM + FIGHTING POLLUTION"
Post by: that_prophet on August 26, 2017, 11:34:11 AM
PROOF OF CREATION + A YOUNG EARTH = (space dust) has mass + billions of years of dust would add up eventually + mess up the orbits of all planets + moons. We could measure the amount of dust on the moon, and divide the total by the amount of dust that is deposited every year, coming up with an age for the moon, and thereby finding out the age of our earth. Most of us have seen pictures of the moon landing, and realize that there is only a few centimeters, meaning that by the deposit of space dust, the moon has only been orbiting us for a few thousand years. Less than 10,000 year
COME ON,,, ALL OF YOU BACK YARD MECHANICS,,, Get some AC + DC motors together of the same voltage, and start building these GEM free energy power supplies,, + not only for 1.5, 3, 6, 9 + 12 volt batteries, but household 120 volt, + 12 volt, to powering these new electric cars. Let's throw the oil companies out of work, producing toxic smoke + maybe even make money with them, by throwing any excess power from these perpetually running energy generators that we have the time, + small amount of money to purchase parts to build. Think of it as not only keeping money in your pocket, but you are keeping money from the countries that either fund terrorist, or which are unknowingly funding them. This is not to mention the experimenting that we could be doing with the anti-gravity + speeds approaching light speed. Now I know that there are many out there like me, which would enjoy knowing how one type of this motor was powering a UFO in the Bible, in Ezekiel 1:16. http://aliensandghosts.yolasite.com/
Most people have heard that the "day + hour knoweth no man"-(Mat 24:36), but why does nobody mention the soon arriving doors that we are not only allowed to know, but in the original Greek, it is worded like a command = "know that it is near, even at the doors",,, + that 1st Door will close on 2019.04 + the last Door will close on 2025.94. So we are guaranteed that Jesus will set His foot on the Mount of Olives before the year 2026.
Did you ever wonder how you could know that it's near, if we can't know the day. Near to what then, maybe it's near to the door/deadline = "know that it is near, even at the doors" Mat 24:33. Doors are plural, because of the two appearances of Jesus, the first is in the clouds,(Rapture) http://rapturequestion.yolasite.com/ before the 7 year peace treaty is signed + then His second arrival is as His Foot touches earth, on the Mount of Olives. DOOR = (this is not the date of His Arrival, which we are warned that nobody can know, but this is the date that Christ must return before) A day that the Tribulation Saints will not only know, but they will probably being counting down the days until. = (He Returns when the 7 year peace treaty ends)
EVil-sOLUTION = isn't it amazing what Truth can be revealed, when the "il-s" of life are included. http://decimationofthisevolutionfairytale.yolasite.com/
I can give you a free to run, perpetual power supply = http://free-energy.yolasite.com/ This GEM mechanism can do this because of how AC electricity is created by rotations. as in the more rotations the greater amount of AC electricity, and pulleys can be used to multiply rotations. So, you are using pulley mechanics to multiply your total amount of AC electricity, by trading one rotation of a large 100 cm circumference pulley, into 100 rotations of as many 1 cm circumference pulleys as you choose to add to the same belt. If you add AC generators to these mini-pulleys then you could be multiplying AC electricity. If you added 4 of these mini-pulleys with AC generators attached, you would gain 400 cycles of AC electricity, and all for the single burst of DC current, the minute amount of current that a DC motor takes to rotate one single time.
These mini-pulleys would be easy to rotate, as the only resistance that they would generate, would be caused by any power that they were generating. These mini-pulleys would only be winding up massive voltages, because the only current needed to rotate your large 100 cm pulley on a DC motor, is one simple spark, or short burst, the amount to rotate your large pulley only one single time. Torque is only caused when you are generating power, and power is generated by current multiplied by voltage. Since we only need one single spark of current, (practically zero) the total amount of power being generated would still be practically zero, costing practically zero torque.
This was given to mankind before the first door closes = http://my2020vision.yolasite.com/
Especially for the soon coming Tribulation Saints http://doorschristmustpassthrough.yolasite.com/
Sorry if it offends you, that I add a little bit of Biblical stuff in my explanations, but when I came up with this super simple idea, it was just after asking God for a way to help the Tribulation Saints. Just think about how super simple this AC electricity multiplier truly is, and how the voices in your head tell you that it cannot work. When how much more simple can it be, then to only pay for the one rotation of a large 100 cm pulley, when you can get a return of 100 cycle of AC electricity, for every 1 cm mini-pulley that you attach to the same belt, (with AC generators attached). Yes that's an input of one single spark of DC current, returning you 100 cycles of AC electricity for every mini-pulley that you attach to the same belt. If you only added 4 mini-pulleys, you would get a return of 40 cycles of AC electricity. Please remember, that there is a most powerful spiritual warfare going on over this GEM technology.
There is a most powerful spiritual warfare going on over this GEM technology. Can you believe the problems that I have had, getting this super simple way of using pulleys to multiply the total amount of AC cycles of electricity? I think that it's totally ridiculous, when you truly take a close look at it. Pulleys can be used to multiply the # of rotations, and AC electricity is made of rotations of a coil through a magnetic field. It should be dirt simple, as you are using pulleys to multiply your total # of rotations, and AC electricity is made of rotations, so you are effectively multiplying AC electricity. .
Post by: that_prophet on August 26, 2017, 11:50:21 AM
Post by: that_prophet on August 26, 2017, 11:52:29 AM
