Overunity.com Archives
Energy from Natural Resources => Gravity powered devices => Topic started by: burnit0017 on June 11, 2016, 05:07:37 AM
Title: Gravity assisted power project- GRAM
Post by: burnit0017 on June 11, 2016, 05:07:37 AM
https://youtu.be/4Oj5fGAKXaE
Hi, I found the above human powered device on youtube. I am attempting to replace manual operation with a automated pendulum to tilt the table.
Short videos of the project.
https://youtu.be/sQqq6srUljU
https://youtu.be/mVWJ5Dnr8-c
https://youtu.be/iJujIiis5lg
https://youtu.be/Dl7goWuaEyc
Title: Re: Gravity assisted power project- GRAM
Post by: conradelektro on June 13, 2016, 02:35:22 AM
What will be your power source? (Ocean waves?)
In other words, what will drive the pendulum?
Greetings, Conrad
Post by: burnit0017 on June 13, 2016, 03:37:36 AM
https://docs.google.com/drawings/d/1jERgsxrV1yPyaIp4kEyS_R9s-T8iaWpnTcQ2DBFkHyw/edit?usp=sharing (https://docs.google.com/drawings/d/1jERgsxrV1yPyaIp4kEyS_R9s-T8iaWpnTcQ2DBFkHyw/edit?usp=sharing)
Hi, One stator of a the PMA will be used to charge a cap that will drive the electromagnets in repulsion mode. The real power source is gravity.
It sounds like a word game but it is not. Once the device is started, it is stuck in a continues loop. I should be testing in a few days.  Good or bad, I will post results. Thanks for showing interest.   No water required.
Post by: ramset on June 13, 2016, 07:19:59 AM
burnit0017
yes your vids do a good job of explaining you direction , a bold one it is.
harvesting energy from the gravity field .
intriguing concept , I noticed a little yellow and orange Teaser in you intro and now above a more detailed Pic .
what part does that play or is it another project, sorry if I missed that?
thanks for sharing your interesting build.
respectfully
Chet
Post by: burnit0017 on June 13, 2016, 08:40:30 AM
Hi, it is a multi stator permanent magnet alternator. I intentionally made the stators with a high internal resistance. It will produce a high voltage at low RPM. I will use a DC to DC step down converter  with a variable duty cycle to reduce (I squared R) loss at the stator. The only claim at this time is it not a overunity device. The configuration is easy to fabricate, so others may do their own testing. Cheers
Post by: burnit0017 on June 16, 2016, 02:54:47 PM
https://youtu.be/7OiU1ODOsSg (https://youtu.be/7OiU1ODOsSg)
Post by: burnit0017 on June 20, 2016, 09:56:15 AM
https://youtu.be/OELKDJZeBxY (https://youtu.be/OELKDJZeBxY)
Post by: burnit0017 on June 22, 2016, 06:46:17 PM
https://youtu.be/a2Gs6-AOLjQ
Post by: burnit0017 on June 23, 2016, 08:11:20 AM
https://youtu.be/5rPkBo5JCjA
nice project, it may giver others some ideas
Post by: burnit0017 on June 24, 2016, 06:24:34 PM
https://drive.google.com/file/d/0BwO5zSDThdxFRHJvb1dJYXNZd28/view?usp=sharing (https://drive.google.com/file/d/0BwO5zSDThdxFRHJvb1dJYXNZd28/view?usp=sharing)
Basic circuit to charge Cap and trigger E-Mag, using SPDT switch.  Working on gearbox for PMA. It should take a few days to complete.
Post by: burnit0017 on June 25, 2016, 08:05:12 AM
https://youtu.be/jKIWcJiJs04
Interesting option for 360 rotation, just for info
Post by: burnit0017 on June 25, 2016, 09:06:32 AM
https://youtu.be/o-HxcEx2CoU
Post by: ramset on June 25, 2016, 09:14:33 AM
burnit0017
your thread is a pleasure to read/view and could probably generate a half dozen others [so as to not sidetrack this one].
intuition is a funny thing ...it just keeps us moving forward !
thx
Chet K
Post by: burnit0017 on June 25, 2016, 11:14:06 AM
SWING5 video is a better idea. Applying Magnet and E-Mag configuration to drive the device. It should be self powered and using a DC to DC step down converter with a variable duty cycle when generating electricity will prevent system stall. One PMA will power the E-Mag and one PMA will be used to generate electricity. Still not OU, but it should work. A gravity powered pulse motor with zero operational cost, other than maintenance cost.
It will function like a wind turbine with no wind required.
Post by: burnit0017 on June 25, 2016, 01:58:01 PM
https://youtu.be/98YOi5gLjRE (https://youtu.be/98YOi5gLjRE)
Post by: burnit0017 on June 27, 2016, 06:02:00 AM
https://youtu.be/aaF1_AyZe-c
proceeding to fabricate swing5 and pulse motor configuration for a gravity assisted pulse motor, it should take a few weeks before the first test
the pulse motor can be made with a larger diameter
No laws of physics are violated and it should function like a wind turbine when generating electricity, output will always be less then 50% of the total power available at the output shaft.
Post by: burnit0017 on June 29, 2016, 06:52:37 AM
https://youtu.be/yi86QqqBNig
The electromagnet has limits adding two air cylinders with two moving weights may help. Using the swing 5 configuration just add another moving weight to the stationary weight side.  During rotation as one weight falls it will push the other weight toward the center.
Post by: ramset on June 29, 2016, 07:46:34 AM
Sir
What constitutes a "swing 5 configuration"..?  is it posted here already [above ] and I missed this or is it to be a new build completely?
respectfully
Chet K
Post by: burnit0017 on June 29, 2016, 08:02:29 AM
Hi, I am combining the above videos to form a gravity assisted pulse motor. Then I will using use the electronics from a wind turbine to generate electricity. This is a first attempt so plans may change. Thanks for showing interest.
Post by: burnit0017 on July 01, 2016, 05:56:52 PM
https://youtu.be/1AC1svbWS-0 (https://youtu.be/1AC1svbWS-0)
Post by: burnit0017 on July 02, 2016, 11:48:57 AM
https://youtu.be/4b8ZsFszE8I
good info
Post by: Kator01 on July 02, 2016, 07:52:27 PM
no, its not
she is repeating the old paradigma again and again : You cant get anything from ( of for) nothing...   the biggest lie brainwashed scientists spread in the media  in a very mindless way. They should know it better.
Qustion: what is the most miniscule nothing we know  so far ?
Can electrons be destroyed ?
Mike Waters - Breakthrough Energy and the basic physics of global recovery
https://www.youtube.com/watch?v=Fp1wPwszF9M (https://www.youtube.com/watch?v=Fp1wPwszF9M)
Best regards
Kator01
Post by: burnit0017 on July 02, 2016, 08:33:25 PM
Hi, fabricate a working proto-type and then test and post your results. I hope you succeed.
pulse motor with magnetic spring
https://youtu.be/ul_sjGy6GRM
Post by: burnit0017 on July 03, 2016, 10:33:35 AM
https://youtu.be/bI8Rh0xDI4I
Post by: burnit0017 on July 04, 2016, 07:38:30 PM
https://youtu.be/il32nuC6-Y8
I was getting better results without the belt.
Post by: burnit0017 on July 05, 2016, 06:39:32 AM
https://youtu.be/TJjekzJUp90
Post by: burnit0017 on July 05, 2016, 09:06:26 AM
https://youtu.be/BPPi8cVoEmg
Idea from other projects on YouTube.
Post by: burnit0017 on July 06, 2016, 07:39:55 AM
https://youtu.be/QPeIDnyDxvw
One way bearing installed at the flywheel, now the flywheel can function like a wind turbine. So the Betz's limit will apply to the flywheel.
Post by: burnit0017 on July 06, 2016, 12:55:00 PM
https://youtu.be/u5iuTwM5brI
just for info
Post by: burnit0017 on July 07, 2016, 08:25:56 AM
https://youtu.be/woVzF59FcsQ
Post by: burnit0017 on July 08, 2016, 04:13:00 AM
https://youtu.be/sR-nJRKoWhc
just for info, same concept as this project, I will be pulsing the input motor and generator output, small amount of electricity with mechanical advantage and gravity at to input to generate a larger amount of electricity at the output
Post by: burnit0017 on July 08, 2016, 11:59:11 AM
https://youtu.be/73C44sX-xLs
https://youtu.be/B3dLzZZ5jKQ
Combining the above ideas to complete the project, it should take a few weeks.
Post by: burnit0017 on July 13, 2016, 10:22:09 AM
https://drive.google.com/file/d/0BwO5zSDThdxFdDBMVmdNMUdlRk0/view?usp=sharing
Correcting flaw in design, it should take a few weeks to fabricate.
Mounting Swing5 on glide swing so no load will ever be placed on the input drive motor.
Post by: CG2016 on July 13, 2016, 01:59:15 PM
After working on this stuff for 5 years I hope you are successful on something  soon , I'm getting a little long in the tooth holding my breath. Cheers
Post by: burnit0017 on July 13, 2016, 08:03:25 PM
Feel free to start your own project and post your results.
Post by: burnit0017 on July 14, 2016, 03:34:30 PM
https://youtu.be/kcmO9ubkdds
update
Post by: burnit0017 on July 14, 2016, 05:04:45 PM
http://peswiki.com/directory:mikhail-dmitriev-gravity-wheel
just for info
Post by: burnit0017 on July 15, 2016, 06:54:59 PM
https://youtu.be/cvjFX-hdVKY
glide swing complete
Post by: burnit0017 on July 17, 2016, 09:27:05 PM
https://youtu.be/2u0krL4SW6Q
Post by: burnit0017 on July 18, 2016, 02:45:22 PM
http://www.engineering.com/ElectronicsDesign/ElectronicsDesignArticles/ArticleID/11200/Electricity-from-Human-Power.aspx
http://www.rapidtables.com/convert/electric/Joule_to_Watt.htm
math for the power calculations
Post by: burnit0017 on July 20, 2016, 11:02:10 AM
https://youtu.be/VEhsIu4BuJA
Post by: burnit0017 on July 22, 2016, 05:49:09 PM
https://youtu.be/rpvVYtBlmX8
Post by: burnit0017 on July 27, 2016, 09:55:41 AM
https://youtu.be/JcBIN8juJ08
Post by: burnit0017 on August 06, 2016, 08:07:45 AM
https://youtu.be/Emi1xSHv6sM
Post by: burnit0017 on August 15, 2016, 06:07:22 AM
https://youtu.be/J4cTuCpNntU
Post by: Low-Q on August 30, 2016, 03:33:51 PM
All I can say is that you have a strong will, burnit0017 :-)
Aside from that, and not to be a party killer, but I might have experienced from several experiments that gravity and magnets can't provide energy...
If you really want to try something, that I failed in making, is this one:
https://youtu.be/LDRorMyxdO0 (https://youtu.be/LDRorMyxdO0)
If you for some reason can make a magnet that keeps its magnetic orientation while it is spinning around, this device will actually work.
The idea is that the inner rotor is a magnetic south pole at the circumference, and north pole in the center. The outer rotor is magnetized through its diameter so south is on one side and north on the other side - even if it is spinning around.
IF you can achieve this, you have a magnet motor with 20% excess energy.
Let me explain:
In this construction, both outer and inner rotor has the same torque, but the inner rotor spins 20% faster than the outer rotor due to the 5/4 gear ratio. This is proven by simulations only. That means the energy of the inner rotor must be higher. As you know that torque multiplied with RPM is energy.
The problem:
How can I get a permanent magnet keep its magnetic orientation in the same direction while it is spinning? When that problem is solved, you got yourself an over unity device.
You cannot magnetize the outer rotor with external magnets. That will cause the outer rotor to increase the torque to 20% more than the inner rotor. So it will not work.
Now you can start figure things out to make it work :-)
Post by: burnit0017 on August 31, 2016, 02:16:09 PM
https://youtu.be/8RKKecCTds4
Post by: Low-Q on September 01, 2016, 07:53:57 AM
Quote from: burnit0017 on August 31, 2016, 02:16:09 PM
https://youtu.be/8RKKecCTds4 (https://youtu.be/8RKKecCTds4)
I must say you really put lots of good work into your projects. I'm impressed. Hope it works as you want it to :-)
Post by: burnit0017 on September 02, 2016, 05:36:15 PM
https://youtu.be/0cClk0KGBLA
Thanks, I have a small CNC router.
Post by: burnit0017 on September 03, 2016, 10:36:20 PM
https://youtu.be/I0MdmaIZrkU
posting just for info, nice pendulum configuration, I will give it a try
Post by: burnit0017 on September 08, 2016, 03:40:07 PM
https://youtu.be/uIxIjTMn960
Post by: Low-Q on September 09, 2016, 12:40:10 AM
Quote from: burnit0017 on September 08, 2016, 03:40:07 PM
https://youtu.be/uIxIjTMn960 (https://youtu.be/uIxIjTMn960)
Phun has a bug. I have experienced unexpected things with phun myself.
I made an unbalanced wheel, and springs attached a little distance from the hub, but 90° offset - one horizontal and one vertical. The wheel accelerated in one direction, and did not want to rotate the other direction.
The "ballbearing" in the center of the chapes does not keep itself in place under stress. This will make false computing of the forces involved in you model, because Phun use the actual location of the mass for computing, and overlook that the bearing isn't fixed to one place.
The experiment is easy to replicate in Phun.
Vidar
Post by: burnit0017 on September 10, 2016, 04:41:58 PM
Hi, thanks for info.I had to order some parts. I should have more to show in a few weeks. Thanks again. Cheers
Post by: burnit0017 on September 14, 2016, 07:25:53 PM
https://youtu.be/_lm6vGdGpik
Post by: Low-Q on September 15, 2016, 05:22:35 PM
This is an awesome build, burnit :)
Have you kept going for so long that the plants starts growing on you project? Looks like it in the background there :D
Keep going, and keep us posted. Most of all, have fun while building regardless of the outcome. Thanks for sharing!
Vidar
Post by: FreeEnergy on September 15, 2016, 10:18:59 PM
burnit0017 if you have time please consider... see attachment file.
Post by: burnit0017 on September 15, 2016, 10:59:04 PM
Hi, I had poor results when I built that project. Has anyone had good results??
Post by: FreeEnergy on September 15, 2016, 11:28:33 PM
really? any videos?
Post by: burnit0017 on September 16, 2016, 01:20:19 AM
Hi, they are on my youtube home channel page.
https://www.youtube.com/user/GoVertical17/videos
Post by: FreeEnergy on September 16, 2016, 01:53:16 AM
Apparently these guys got a working model according to tv news channels.. Someone please translate.
https://www.youtube.com/watch?v=gMk-1ouP-gg
https://www.youtube.com/watch?v=xqEqjZl3ZOg
Post by: burnit0017 on September 16, 2016, 06:30:41 AM
Hi, is there a reason you are not building, testing, and posting results for your proposed configuration?
Post by: Low-Q on September 16, 2016, 10:26:55 AM
Quote from: burnit0017 on September 15, 2016, 10:59:04 PM
Speaking for myself, I have not got any positive results yet. I try to make things work without violate laws of thermodynamics. If you succeed in doing that one day, no one can say your'e a fraud ;D  (Well if you claim you're violating anything, people will not believe...that's what I meant ;) )
I run simulations first, and then, if I cannot understand why the concept does not work, I build it. This far, I haven't built so many. I have a project going on now. A small sized project. I have no expectations other than it will most probably not work.
However, I think it's fun to put things together - no matter what it is.
You learn more from practical experiments than any other way of educating yourself. That's why I'm doing this :-)
Vidar
Post by: burnit0017 on September 17, 2016, 04:34:15 PM
https://youtu.be/4BlPGEn3Ouw
Post by: burnit0017 on September 19, 2016, 10:08:58 AM
https://youtu.be/5mu5awHjeNQ
Post by: burnit0017 on September 19, 2016, 02:03:32 PM
Hi, thanks for posting.
Post by: conradelektro on September 19, 2016, 04:47:46 PM
Quote from: webby1 on September 19, 2016, 11:04:40 AM
Here is a simple method I use to take an oscillating input and convert it into a single direction rotating output.
In 700 if you look at the top left part of the picture you see the input arm connected to the first input shaft,, then to the right of that first input shaft\gear\one way bearing is the second input shaft with its own gear\one way bearing and then to the right of that is the output shaft with its own gear\one way bearing.
In this setup I am using levers to connect the two input shafts,, but sprockets and chain work as well so that you are not limited on the angle of rotation per input cycle.
I used a one way bearing on the output so that the output flywheel would keep spinning without  the input system moving,, in other words if the input slowed down it did not slow the output down with it.
I like that setup, specially because the fly wheel can run away.
May be one should mention that the ratchet bearing (or one way bearing) in the middle should block in the opposite direction in comparison to the the first and third ratchet bearing.
Greetings, Conrad
Post by: burnit0017 on September 21, 2016, 11:57:31 PM
https://youtu.be/rtcsLgCZybo
it looks like I have to rework my pendulums, I have the chain drive on the wrong pendulum
Post by: burnit0017 on September 25, 2016, 07:46:39 PM
https://youtu.be/_LTMU1zuhlk
New configuration, previous attempts failed.
Post by: burnit0017 on September 28, 2016, 09:57:57 AM
https://youtu.be/7TAb8eIcgsA
Post by: burnit0017 on September 29, 2016, 07:10:39 PM
https://youtu.be/zT30XMlhKW0
Post by: burnit0017 on October 01, 2016, 08:59:29 AM
https://youtu.be/jQ9w4btlLzg
Post by: burnit0017 on October 01, 2016, 08:27:49 PM
https://youtu.be/B0gfFnu_C4M
increased fall weight to 10 pounds, proceeding to fabricate swing5 rotor
Post by: burnit0017 on October 04, 2016, 05:01:15 PM
https://youtu.be/9NABSmLgMUc
new motor mount
Post by: burnit0017 on October 06, 2016, 09:11:32 PM
https://youtu.be/VUJXHzKPRUs
Post by: burnit0017 on October 08, 2016, 08:21:07 AM
https://youtu.be/Cn5f8VWt7IE
Post by: burnit0017 on October 09, 2016, 01:24:01 PM
http://www.algodoo.com/download/
https://youtu.be/N2M3ZTNiVgY
Post by: burnit0017 on October 09, 2016, 05:08:02 PM
https://youtu.be/-MthI6dZssQ
Post by: burnit0017 on October 11, 2016, 09:46:55 AM
Last configuration failed.
New configuration attempt.
https://youtu.be/S3MokDKLgH8
Post by: FreeEnergy on October 11, 2016, 06:36:17 PM
Can you post the file as well please?
Thank you.
Post by: burnit0017 on October 11, 2016, 08:58:48 PM
Hi, the lever  is 8 feet, the fall weight is 10 pounds rotating on 1 foot crank.
Post by: burnit0017 on October 16, 2016, 11:05:40 AM
https://youtu.be/YWdlyuVDJu4
nice, possible up grade 8)
Post by: Low-Q on October 17, 2016, 08:58:46 AM
Quote from: burnit0017 on October 16, 2016, 11:05:40 AM
An oscillator, or pendulum like this does not operate very much different from a rotary solution, because both principles are based on the very same sinusiodal fuction. At the moment you load the output coil, the magnet will feel resistance because the coil will resist induction when it is loaded. This resistance will add a delay on the pendulum that will drain the kinetic energy of it, so the pendulum will stop sooner than if it was not loaded. Using big heavy weights, will not make any othe difference than sustaining oscillation longer because higher weight at a given angular velocity has more kinetic energy than a light weight at the same angular velocity.
This kind of resistive electromechanism will apply to any form of generators that is loaded. A rotary solution will keep rotating as long there is no energy output, just like the pendulum will continue to oscillate as long there is no energy output, but both will be drained if you load them.
I can see that the bicycle frame is wobbling like a seesaw. If you take energy out of this seesaw, the very same happens. When you load it with resistance, you basicly are counterforcing the seesaw with a given delay that will cause the pendulum to stop. No free energy in this one.
Vidar
Post by: burnit0017 on October 17, 2016, 05:14:03 PM
Thanks for the info.
Post by: burnit0017 on October 17, 2016, 05:27:55 PM
https://youtu.be/Y1cKWIAFT0I
will the same happen
Post by: Low-Q on October 18, 2016, 01:38:30 AM
Quote from: burnit0017 on October 17, 2016, 05:27:55 PM
https://youtu.be/Y1cKWIAFT0I (https://youtu.be/Y1cKWIAFT0I)
The same will happen here if it wasn't for the energy input from the pneumatically piston.
The misconception is that a pendulum that is arranged like this will provide energy output with little or no energy input. However, the energy output is a direct consequence of the energy input.
It is both mathematically and practically provable, but the inventors often overlook this because of the construction principle plays mind tricks.
It's difficult, if not impossible, to observe the machine behavior in detail. The counterforce from the energy output is allways slightly ahead of the mechanical oscillation. This is harder to observe the less energy output there is.
However, it has been built water wells with hand powered pumps that is based on this principle. These pumps are more efficient because the loss in the human body is less when operating such a pump compared to the continuous external pressure directly on a pump lever. Try to press your hands hard together for a while. No work is done because the hands are stationary, but you consume lots of energy. The pendulum require a short burst of energy input that in turn does not require much energy from your body, but the energy input is not less than the energy required to pump the water.
Vidar
Post by: burnit0017 on October 18, 2016, 05:52:45 AM
Hi, thanks again. My project is a attempt to find a configuration that will combine a small amount of electricity with mechanical advantage and gravity at the input that will produce a max torque at the output shaft.  The output shaft will drive a PMA. I plan to use Buck converter with a variable duty cycle  at the output of the PMA. The electricity generated at the output will be less then 50% of the max torque of the output shaft.
I will post results when available.  Thanks again.
Post by: Low-Q on October 18, 2016, 11:19:40 AM
Just a tip for your project:
If you want to calculate energy, you must multiply torque with displacement. Torque is usually measured in punds pr feet or Newton per meter radius.
A buck converter is useful. These small devices increase voltage output on expense on current input. If you want to power a 10W load that runs on 20V @ 0.5 Ampére, and the input voltage is 10V, then the buck conveter will draw 1 Ampére from the input. So a buck converter does not increase energy output. The more expensive ones have an efficiency of approx 90-95%, which means for each watt output, it draws 1.05 - 1.1W at the input. Think of a inverted pulley with ropes. You must displace 1 meter of rope at 2kg force to lift a 1kg weight 2 meters up.
Good luck :-)
Vidar
Post by: burnit0017 on October 19, 2016, 10:20:12 AM
DC to DC step down converter = Buck converter
Post by: Low-Q on October 19, 2016, 03:06:08 PM
You can also buy them as DC to DC step UP converters. Amazingly how stable the output voltage is when you load them. I use such a converter to power my DIY aux head lights on my car. From the 12V car battery, this converter outputs 30V @ 3.2A, and if I hook off the load, the voltage is still 30V. I had to hook it directly on to the battery with a 10A fuse, and a relay, because the converter draws 9A from the battery, and the fuse in the car will blow if I power the converter directly from the head lights.
My LED aux lights are 2 x 5 LEDs at approx 10W each. Mine can deliver approx 160W max. Bought on DX.com.
Vidar
Post by: burnit0017 on October 22, 2016, 09:37:57 AM
https://youtu.be/uWsDc0oMrmI
proceeding to fabricate  Milkovic 2 stage oscillator  configuration
Post by: burnit0017 on October 22, 2016, 03:18:39 PM
https://youtu.be/lUm_nV3TRlQ
I will be adding a gear train at the output and use a buck converter at the PMA output.
Post by: burnit0017 on October 25, 2016, 09:05:02 AM
https://youtu.be/UXo6WvHRs_I
Post by: burnit0017 on October 25, 2016, 12:27:35 PM
Project on hold until Spring. :'(
Post by: ramset on October 26, 2016, 08:00:57 AM
is it the Chill in the air ? [an unheated shop can be most uncomfortable to work in the winter
Snow Bird heading south ?
your tenacity in this quest is inspiring.
Thanks for sharing your work !
Chet K
Post by: burnit0017 on October 26, 2016, 08:56:42 AM
Hi, after a summer of experimentation I found that the fewer moving parts the better, a large flywheel sucks a lot power from the system, and the two stage oscillator appears to be the best way to use a pendulum. I will purchase a hand warmer and try to continue when I can. Cheers
This is a small project I did a few years ago.
https://youtu.be/nfoDyKCA3xs  warm, it is a gravity device  :)
Post by: burnit0017 on October 27, 2016, 02:44:39 AM
https://youtu.be/3rc2R1LvN0s
just for info
Post by: CG2016 on October 27, 2016, 07:18:46 PM
Yep, it looked like it was getting out of hand.
Too many components. All that friction adds up.
Simple is better.
Post by: burnit0017 on October 27, 2016, 08:59:49 PM
https://youtu.be/Z3_DKdiN1w4
need 4 running in parallel, driving one output shaft to the gear train
Post by: burnit0017 on October 28, 2016, 02:56:52 PM
https://youtu.be/8mKR51wprG4
Post by: burnit0017 on October 30, 2016, 06:06:07 PM
https://youtu.be/hK-oZKDowj0
Post by: burnit0017 on November 02, 2016, 06:19:31 PM
https://youtu.be/rvLuAweY7BI
Post by: burnit0017 on November 05, 2016, 04:32:34 PM
https://youtu.be/DTAcUhDnDXc
Post by: burnit0017 on November 05, 2016, 05:30:36 PM
About 900 RPM's at the output.
Post by: burnit0017 on November 06, 2016, 10:32:22 AM
correction, the RPM is closer to 350 at the output
Post by: burnit0017 on November 14, 2016, 03:41:56 PM
https://youtu.be/7lu86mWzMeY
Post by: burnit0017 on November 15, 2016, 04:34:19 PM
https://youtu.be/G_t3AxOi6LM
Post by: citfta on November 16, 2016, 09:29:48 AM
I have been following your posts with a lot of interest.  I was sorry to see your post a few weeks ago that said you were on hold until spring.  Happy to see you were able to move indoors and continue your efforts.  It looks like you are making good progress.  Thanks for sharing your project.
Post by: burnit0017 on November 16, 2016, 09:49:21 AM
Hi, thanks. I am spending the winter fabricating the DC to DC step-down converter. This project is showing a lot of potential, I will continue working on it in the spring. Thanks again.
Post by: burnit0017 on April 01, 2017, 07:22:57 PM
https://youtu.be/ALutpnyeMm8
High voltage, low current. Next I have to add a bridge rectifier and a Buck converter.
Post by: burnit0017 on April 13, 2017, 07:22:02 PM
https://youtu.be/4u_QWesfYdA
Post by: shylo on April 14, 2017, 06:01:37 AM
Interesting, Could you use that 200 volts to spike the battery when it is between pulse times of the wiper motor?
If that's too high dump the cap before it gets there ,multiple dumps?
Thanks for sharing.
artv
Post by: burnit0017 on April 14, 2017, 06:34:36 AM
Hi, it seems possible but the project goal is to use a Buck converter to converter a high voltage with low current to a lower voltage with higher current. This will reduce the (I square R) loss at the stator when the duty cycle is set below 50% .
Post by: burnit0017 on April 15, 2017, 11:14:01 AM
https://youtu.be/V5Lw2DwEG8k
Post by: burnit0017 on April 15, 2017, 07:06:57 PM
The skyMAX PMA is a complete waste of cash. >:(
Post by: burnit0017 on April 15, 2017, 07:17:05 PM
Proceeding to fabricate Buck converter with a VOC of 400 volts.
variable trigger circuit for the Buck circuit
Post by: burnit0017 on April 17, 2017, 03:47:47 PM
P channel mosfet buck converter, I will post parts list after testing the circuit.
Post by: burnit0017 on May 08, 2017, 05:25:36 PM
https://youtu.be/MlEXvh00vtE
just a quick update
Post by: burnit0017 on May 10, 2017, 08:18:24 PM
https://youtu.be/4hmnA0A1J1Q
project update
Post by: burnit0017 on May 15, 2017, 10:40:12 PM
https://youtu.be/MX0CPECHeQk
Big swing5 needs some fine tuning.
Post by: burnit0017 on May 16, 2017, 09:00:04 PM
https://youtu.be/IOdulvy8M7A
working better
Post by: burnit0017 on May 21, 2017, 02:29:25 PM
https://youtu.be/THHGEgtjDFs
abandoned TSO for a pulse motor to drive the Swing5, will use stepdown gear train for increased torque
Post by: burnit0017 on May 21, 2017, 08:13:37 PM
https://youtu.be/8OISfRpDZSE
requires a better design of the electromagnet, suggestion welcome
Post by: burnit0017 on May 22, 2017, 01:20:37 PM
https://youtu.be/G_jt9YJnG5M
Reduced e-mag core end has improved RPM
Post by: antijon on May 22, 2017, 05:48:55 PM
Hey burnit, just curious but do you have a way to adjust the timing of the pulse? Looks like if you're in attraction mode you could pulse a little before the magnets are lined up, and maybe have better rpm. Reminds me of when I took the flywheel off a mower engine then tried to start it. The timing was so close the piston bucked back instead of crossing TDC, nearly pulling my arm off before the starter rope popped.
Anyway, timing is important in any machine.  ;D
Post by: burnit0017 on May 22, 2017, 06:26:48 PM
Hi, I am using the e-mag in repulsion. I can rotate the trigger cam to adjust the timing. I have to fabricate away to adjust the position of the repulsion magnet on the stator. Timing is tricky. Thanks for the help.  I may have to increase the trigger voltage. I am fabricating a new e-mag using 18 AWG wire on a 2 by 4 inch bobbin, not sure of the turn count but the coil resistance is about 50 ohms. Thanks again for the help.
Post by: burnit0017 on May 22, 2017, 08:02:58 PM
https://en.wikipedia.org/wiki/Litz_wire
Hi, has anyone tried multi strand wire to fabricate a e-mag? It looks like away to reduce the coil resistance.
Post by: antijon on May 24, 2017, 08:23:41 AM
I've never tried multistranded, but I would think there's a reason it's not normally used. But whether you use that or normal wire, you'd definitely benefit by wiring it in a bifilar arrangement. After all, Tesla invented the bifilar winding for electromagnets. You'd see a faster response when the switch closes and less arcing and sparking on the switch contacts.
Post by: burnit0017 on May 24, 2017, 10:01:31 AM
https://youtu.be/EMpry_2-580
https://youtu.be/SMHmLgXWR1U
Hi, I think the main problem is the large  air gap between the e-mag and the rotor mag. There is a limit to the size of e-mag I can fabricate. The design was becoming too complex with too many parts. I found two examples of a linear pulse motor that may work better for this project. Thanks for the help. I am starting the rebuild. Thanks again.
Post by: burnit0017 on May 24, 2017, 10:18:55 AM
https://youtu.be/7-P-D6JXSPk
The new project configuration will resemble a early motor design. I will use the swing5 configuration for the flywheel with two large linear pulse motors.
Post by: burnit0017 on May 24, 2017, 11:59:38 AM
https://youtu.be/OxuotFUWVGQ
It look like the moving coil design will have the best results.
Post by: burnit0017 on May 24, 2017, 02:43:53 PM
https://youtu.be/ZX1IDqHEDRw
Basic test.
Post by: burnit0017 on May 24, 2017, 06:41:08 PM
https://youtu.be/YsLnBcXIH4E
time for a safety lesson
Post by: burnit0017 on May 26, 2017, 02:40:21 AM
https://youtu.be/GALNX54jDL4
Another option, but will require a gear train reduction.
Post by: burnit0017 on May 26, 2017, 08:11:49 AM
I am thinking of using the failed pulse motor attempt rotor with two gap powered devices. The gap devices will be placed in a 180 degree configuration on the outside of the rotor and use a one to one gear set to drive the large swing5 rotor. All the parts are fabricated and I should be able to test soon.
Post by: burnit0017 on May 26, 2017, 09:28:00 AM
https://youtu.be/sxrJoGZy1to
just found this, looks like the solution
Post by: burnit0017 on May 26, 2017, 10:07:00 AM
https://youtu.be/y87ZWuoWV_o
if they measure the power at the output shaft and then compare it to the power being generated, not OU, still a great idea and should solve my project problem
Post by: burnit0017 on June 02, 2017, 06:23:33 PM
https://youtu.be/SUDzFv_hURA
Making progress. 1 to 9 gear train with PMA mounted.
Post by: Low-Q on June 06, 2017, 06:08:52 AM
Even if you haven't had success yet, I'm amazed about your skills and crafts. Keep it up. Its fun and inspiring to watch your videos :-)
Vidar
Post by: burnit0017 on June 06, 2017, 08:39:37 AM
hi, the project really needs a PMA with a high output at a low rpm. i will have to fabricate one.
Post by: Mem on June 11, 2017, 05:11:44 AM
Quote from: burnit0017 on May 22, 2017, 01:20:37 PM
https://youtu.be/G_jt9YJnG5M (https://youtu.be/G_jt9YJnG5M)
Couple of ideas that may help to fine tune the system and  give you more power on electromagnet.
1-you may want use magnetic rid switch to control the electromagnet via mosfet or a power transistor which will allow you to fine tune and get maximum propulsion power out of electromagnet. Similar to pulse dc motor operation.
2- Put your electromagnet into metal tube/pipe and close the back of the tube/pipe as well like round washer or metal plate, by doing so you will increase power of your electromagnet may times. Or else you lose most of the electromagnet force if you don't enclose the coil in a metal housing.  For example: Transformer would not operate without a metal core.
Mem.
Post by: burnit0017 on June 11, 2017, 08:56:48 AM
Hi, thanks for taking the time to post the suggestion.  I used that configuration on the first pulse motor I made. basic testing showed me that I can get better results using the GAP power or mostly permanent magnet motor configurations.  Thanks again
Post by: burnit0017 on June 11, 2017, 12:41:50 PM
https://youtu.be/5EcuuFbSwSg
dual coil, looks easier to fabricate
Post by: Mem on June 11, 2017, 01:25:15 PM
Quote from: burnit0017 on June 11, 2017, 12:41:50 PM
https://youtu.be/5EcuuFbSwSg (https://youtu.be/5EcuuFbSwSg)
Looking some of your videos it's quite impressive to see  amount of time and labor + $'s that you have invested in this R&D.
More power to you man!
I sure do lot's R&D in Hawaii but it's the fraction of what you do. Having a like minded buddy/friend definitely helps to discuss  these ideas.
Some day I hope to tackle this project. https://www.youtube.com/watch?v=3DKUFoWAuj0  the principle of modification of the generator is here in this drawing. I have no idea who make the drawing, but looks very good.
Post by: burnit0017 on June 15, 2017, 03:53:52 PM
https://youtu.be/UlGjr2VBxR0
linear pulse motor fabricated, please watch safety videos
Post by: gotoluc on June 15, 2017, 05:57:30 PM
Quote from: burnit0017 on June 15, 2017, 03:53:52 PM
https://youtu.be/UlGjr2VBxR0 (https://youtu.be/UlGjr2VBxR0)
Hi, I guess you're using my Mostly Magnet Motor design where the magnets on each ends of the center rod core are opposing each other N-N or S-S?
Looks good and wishing you all the best.
Luc
Post by: burnit0017 on June 15, 2017, 07:18:08 PM
Hi, yes I am combining your project with the swing 5 rotor.
I plan to use it to drive a multi- stator and multi- rotor PMA. I will use a Buck converter to reduce the (I squared R) loss at the stator. I will adjust the perimeters until it generates more electricity then it is  uses to operate.  Not OU. Thank you for posting your project.
Post by: gotoluc on June 16, 2017, 05:47:15 PM
Quote from: burnit0017 on June 15, 2017, 07:18:08 PM
https://youtu.be/SMHmLgXWR1U (https://youtu.be/SMHmLgXWR1U)
https://youtu.be/jKIWcJiJs04 (https://youtu.be/jKIWcJiJs04)
That's great!
I wish you success.
Are you aware of the further torque improvement the mostly magnet motor design can achieve without any more power input?
Did you see the Super build of it?
Luc
Post by: burnit0017 on June 16, 2017, 06:26:20 PM
Hi, I have been searching for the videos, can you please post the links.  Thank you for any help received.
Post by: gotoluc on June 16, 2017, 07:18:50 PM
Quote from: burnit0017 on June 16, 2017, 06:26:20 PM
I've copied the below from my original topic: http://overunity.com/8429/mostly-permanent-magnet-motor-with-minimal-input-power/msg420188/#msg420188 (http://overunity.com/8429/mostly-permanent-magnet-motor-with-minimal-input-power/msg420188/#msg420188)
It contains the essential details and developments.
Over five years ago I came up with a unique linear motor design where a coil moves on a steel core between two opposing permanent magnets.
The benefits I found in this design are:
1. The stronger the magnets and the more core surface area, the stronger the push or pull gram force is.
2. The design has no magnet cogging as the cores and magnets don't move.
3. The coils Inductance has next to no change as it moves since it never leaves the core.
4. If designed correctly the coils push or pull gram force is equal throughout the travel stroke.
5. Compared to a standard solenoid my design uses a fraction of the input power, so it can be continuously operated 24/7. A standard solenoid would catch on fire if it tried to continuously push or pull what my design can do.
6. My design offers huge travel distances compared to a standard solenoid.
7. It can be made to travel a 1/4 inch to 4 inches or more if needed while maintaining the same gram force throughout the stroke.
Here is a demo video of how my basic design works: https://www.youtube.com/watch?v=-eTQ49RcFKM (https://www.youtube.com/watch?v=-eTQ49RcFKM)
Here is a larger magnet version: https://www.youtube.com/watch?v=qa1dO8qWPQU (https://www.youtube.com/watch?v=qa1dO8qWPQU)
Here is a super build version: https://www.youtube.com/watch?v=f6pc-XNS9uo (https://www.youtube.com/watch?v=f6pc-XNS9uo)
All tests were done with the same digital scale which displays pull gram force in 5 gram increments.
Results of the tests in the same order as the videos above:
no.1 has   250 grams pull force with a continuous 1.2 watt input
no.2 has   500 grams pull force with a continuous 0.43 watt input
no.3 has 2500 grams pull force with a continuous 0.43 watt input
As you can see I'm demonstrating that the pull gram force can be increased by the force of the permanent magnet without increasing the input power. Note that test no.1 has 1.2 watt input and test no.2 has 0.43 watt input which is a 65% reduction in input power but still has double the gram pull force.
Test no.3 has 5 times the gram pull force of test no.2 using the same input power since the core and magnet surface area is 8 times wider.
So obviously not just the force of the magnet can play a part but more core and magnet surface area also increases the push or pull gram force.
This is what I've been trying to demonstrate in a nutshell. However, since this is the Overunity Forum people here are mostly interested in OU possibility rather then an innovation.
So to please everyone I did tests to see if the super build could have OU potential even though I knew it would not since the design also suffers of the generator effect as the coil moves in the permanent magnet field. Since it can only move at a certain speed because the coil generates power as it moves, it fights the input power which is coming in the same direction, so we cannot beat the laws of physics here.
Hope this helps
Luc
Post by: burnit0017 on June 16, 2017, 08:03:43 PM
Hi, yes it does help. Thank you.
Post by: burnit0017 on June 18, 2017, 03:16:13 PM
https://youtu.be/-Vi4w97YiqE
proceeding to fabricate large pendulum drive and I will use the MPMM to drive the the pendulum
Post by: burnit0017 on June 27, 2017, 08:04:53 PM
the pendulum was not working well for me. switched back to the swing5 rotor. I increase the stroke on the MPMM to 16 inches. At 12 volts dc it has low power. Suggestions welcome.
i can down size the swing5 rotor, or increase the magnet size and input voltage. I am aware of the inverse squared relationship for the magnet force and distance. suggestion welcome
https://youtu.be/SrYTTa9EPck
coil size is 2 by 4 inches, 18 awg @ 10 ohms
Post by: gotoluc on June 27, 2017, 09:32:27 PM
The MMM can be designed to travel efficiently at any distance if you have the money or supplies to build it correctly.
The length and height of your coil determines the maximum travel length and diameter of your center core.
For example:
A 6 inch long coil wound 1 inch thick can efficiently travel 6 inches in each direction on a 1 inch dia. core that is 12 inches long.
A 12 inch long coil wound 2 inch thick can efficiently travel 12 inches in each direction on a 2 inch dia. core that is 24 inches long.
If your coil is 4 inches long and you're trying to get it to travel 8 inches in each direction on a 16 inch long core then you reduce the MMM push/pull force by half.
So not efficient, no matter how many magnets you add.
If you follow the above example then you'll get the best results. And if you also include an outer core which takes advantage of both poles of the magnets like I have demonstrated in my videos, then you'll double the push/pull force with the same input power.
Obviously the stronger the magnets are and the more core and coil surface area there is the stronger the push/pull fore will be and without an increase in input power.
However, keep in mind that generator effect (CEMF) also increases with the above which I've also tested and confirmed in a video demo which confirms the MMM is an under unity device.
I would think it may be as efficient to use an off the shelf geared motor and attach a crank shaft if you're needing a back and forth linear motion.
Hope this helps
All the best in your experiments
Luc
Post by: burnit0017 on June 27, 2017, 11:11:39 PM
hi, thanks for the help. I ordered a few 3 by 3 inch neo's with 1000 pound pull force. It should get the project moving in the right direction. Thanks again for the help.
Post by: burnit0017 on June 28, 2017, 01:31:03 PM
https://youtu.be/HbVtXPegW_o
fabricating 4 MMM to drive two small pendulums.
Post by: burnit0017 on June 30, 2017, 10:53:01 AM
https://youtu.be/0t8yDnyOaQ8
Another SAFETY video.
Post by: burnit0017 on July 06, 2017, 10:57:53 AM
https://youtu.be/eLq94TdoqxE
posting just for info, it uses mechanical advantage, gravity, and the drive motor could be pulsed on and off
looks easier to fabricate, this could be the solution, the large magnets are scaring me
Post by: burnit0017 on July 09, 2017, 04:38:47 PM
http://www.magnet4less.com/product_info.php?products_id=982
Hi, I may have found a way to increase stroke length  of the MMM. additional magnet sets could be placed in the iron core, the coil could be pulsed every time it reaches a new set of magnets.
comments welcome
Post by: burnit0017 on July 12, 2017, 07:48:43 PM
https://youtu.be/fMaayTJK02U
quick update
Post by: burnit0017 on July 14, 2017, 02:57:42 PM
https://youtu.be/U_q28sfn-NM
hoping other builders will give it a try
Post by: burnit0017 on July 15, 2017, 04:57:45 PM
https://youtu.be/oUj9ZZ7FTrk
quick update
Post by: burnit0017 on July 15, 2017, 06:24:19 PM
https://youtu.be/FG6CsoWl3fo
started testing
Post by: burnit0017 on August 04, 2017, 01:29:21 PM
https://youtu.be/9bzQyEBcQrU
3 by 2 neo's
Post by: burnit0017 on August 23, 2017, 08:21:40 PM
https://youtu.be/l1sBfNw4VGQ
making progress
Post by: burnit0017 on August 24, 2017, 02:23:57 PM
https://youtu.be/i-vVyZ7LprE
proceeding to add rack and pinion, gear train, PMA and buck converter. All in good fun. Cheers
Post by: burnit0017 on August 31, 2017, 05:21:59 PM
https://youtu.be/q198VEMj8B0
increased centrifugal force
Post by: burnit0017 on September 04, 2017, 03:38:33 AM
https://youtu.be/OSPYNywpyoM
result of magnets on iron core
Post by: burnit0017 on September 10, 2017, 09:22:13 AM
http://www.kylesconverter.com/power/watts-to-foot--pounds--force-per-second
found a online calculator that maybe useful
Post by: burnit0017 on October 11, 2017, 09:35:23 AM
https://youtu.be/J9QafZ1QYkU
spring counter balance
Post by: burnit0017 on October 29, 2017, 12:05:16 PM
https://youtu.be/X5bzjs3ByBU
cap dump circuit should limit the bemf braking at the PMA
Post by: burnit0017 on November 06, 2017, 09:41:56 PM
https://youtu.be/X4osQhuqp4Y
manual test of PMA and cap dump circuit charging 12 volt battery
Post by: burnit0017 on November 26, 2017, 11:05:56 PM
https://youtu.be/euGYWZsLGRM
charging super cap bank, PWM reduces BEMF
Working on Atwood and pump jack configuration. the pump jack will act like pendulum using a seesaw to lift a weight then the pendulum will latch and wait for the weight to fall, then the cycle can repeat. Waiting for warmer weather. Happy holidays
Post by: burnit0017 on November 28, 2017, 06:30:41 PM
https://youtu.be/83g1XByKV0k
not sure how it works?????????????
Post by: burnit0017 on December 02, 2017, 04:56:05 PM
https://youtu.be/LGNtCVeEDj8
This looks interesting....Seems to have a counter weight.
Post by: sm0ky2 on December 06, 2017, 11:46:55 PM
Quote from: burnit0017 on November 28, 2017, 06:30:41 PM
https://youtu.be/83g1XByKV0k (https://youtu.be/83g1XByKV0k)
not sure how it works? ??? ??? ??? ???
Change in rotational torque by changing tension and path of the cable
It looks like a pneumatic door closer. When the large weight pulls
the cable tight it 'opens' the hydraulic cylinder, it then self closes,
pulling the cable back down, and the counter-weight resets the system.
Post by: citfta on January 21, 2018, 06:07:19 AM
Hi burnit0017,
Here is a link to some information about a project very similar to what you are doing.  Maybe it will give you some ideas.  Go to post number 984 of this thread:
http://www.energeticforum.com/renewable-energy/11933-open-discussion-projects-forum-33.html?posted=1#post307680
Take care,
Carroll
Post by: burnit0017 on January 21, 2018, 06:29:13 AM
Hi, nice work, it will take me some time to get through all the posting but it looks like I am taking the same approach. Thanks for posting. Cool. I am waiting for warmer weather to finish the project. I am using a low RPM high output PMA with a PWM cap dump circuit to charge a super capacitor bank. I just finished a large pulse motor to drive the spinning weight. Thanks again.
  https://youtu.be/UUZhyh39yP4
