The actual secret of Free Energy is given as the power of "Vril' which is caused by two rotating magnetic field's interaction. This is what my Father, the real Hitler used to have German Astronauts travel to the Moon and discover cities and life there in the 30's. He used Vril saucers. Vril can be produced by a series of 2 electromechanical disks in a homopolar like, full flux design, or it can be produced by rotating two magnetic fields with field coils in a toriod using a solid state methodology. i have attached a drawing of a successful vrillian free energy circuit which i tested today. Please don't take this lecture i am giving you too lightly, since i have 6 Phd's and 4 Nobel Prizes under alias names and no other human on this earth has ever had more than one Prize per person.
@ Bowser03 - Thank you for shareing , I have over the years studyied the working of the humabui and vril. in your diagram is the flat coil energy out put in simple terms. the three coils that control the azmuth and movement is another story. the hemvolt coil I was wondering what presents does it all thought, I belive it is to protect the power controls and the person flying the vessel. the sphere is a collector for overload of the whole system as i see it. if at all possable could you give a parts list on your diagram to start expiereminting. It would seem that the ring is bifiller synortal arc wound in the virl as to have no magnetic field present. Your drawing seems quit stright forward so it look slike simple parts are needed to build this circut. Mike
@bowser03
Quotei have attached a drawing of a successful vrillian free energy circuit which i tested today.
I don't see an attachment. Please post schem again. Thanks.
~D
I belive he removed it ...oh well tahts life ... (EDIT ) warning do not google vrillian free energy ..I did and sent me to a scan site !!!!!
please see attached diagram
Hi Bowser03,
I just returned from a Swiss energy conference and an elderly German man was there who said he worked with the VRIL project and also worked with Hans Kolar.
He did not have anything to do with Haunebu. His description of the VRIL device was a propeller on top pulling air down and exiting over "bars" of uranimum and cadmium(? used as moderator?) .
This heated the air extremely hot and it was with this the saucer lifted off and disappeared within seconds. Basically hot-air propulsion. The crew of 3 laid horizontal on their stomachs; one pilot and two prisoners because the radiation level was quite high.
This is in strong contrast with rotating fields.
Referring specifically to your image, I have taken the liberty to redraw it and save in GIF format. Notice that opposing magnetic fields do not work with only 3 coils, 4 will be necessary for proper magnetic orientation.
The inconsistency is shown in red color. Would you please be so kind and explain? I personally am a fan of quadrature, but not 120 degrees. I see quadrature many places in Nature, but have never seen Nature using 120 degrees. Perhaps someone can open my eyes and point out where Nature uses 120 degrees. Tesla's first AC generators used 4 coils in phase quadrature.
The self-oscillating nature of your circuit is what I call a rat race because it resembles a rat running in a circle, chasing its tail. As I see it, your circuit depends on differences of inductance, resistance, transistor beta, etc in order to cause one of the rat race transistor to conduct slightly before the others. Whichever transistor is first to conduct starts the oscillation.
Back in July 2007, I published rat race circuits using ICs that could be clocked at very high speeds and also indicated that they could be used to generate counter-rotating fields.
In contrast to transistor circuits, my IC rat race has very fast transitions in the low nanoseconds and at can have pulse widths of 10ns or less.
http://www.overunity.com/index.php?topic=2582.msg38506#msg38506
http://www.overunity.com/index.php?topic=2582.msg41927#msg41927
When you say you have successfully tested this VRILian free energy circuit, please advise exactly how and in which manner you extracted the excess energy.
I see no methods to do this in your present circuit.
Sincerely, Earl
Quote from: bowser03 on October 28, 2007, 08:19:17 PM
...Seikes forced feedback amplifier configuration...
...with Metaglas toroid...
In basic configuration called transistorized coil because it consists of one inter(chopped)ruped winding.
Naudin has a setup on his site.
Due to full resonance a positive current and a negative current is flowing in the winding.
It's basicly a closed loop.
Never tested this.
A 3 phase generator-amplifier in self resonance with a slightly frequency shift due to drift of the transistors.
Some (also Prof. Seike) are interpreting the drift as an energy+ of gravitational energy.
Driven conventionally with dc...Output is conventionally 3 Phase (120?).
Nieper and Seike used it to drive an exotic material disc (or ring? bacause it was called Nieper-Ring) which is believed to loose weight.
An verry interesting simple schematic which is also used at low frequ. to dimm tree bulbs etc.
Best wishes
Kark
This power cell is the equivalent of an Orgone Battery when it is connectede to a 6 V lantern battery. I am using 2N2222 transistors right now in the circuit but will later replace them with higher power microwave transistors. The interesting part about the cell is that there is no voltage drop across the battery and for all purposes there should be at least 4 volts dropped, or 2/3 of the voltage because of the coil short circuit. This proves that even under full flux vectors the circuit is drawing a negative load and therefore negative entropy like an Orgone Cell. I will plan to use this cell to power a remote Joe Cell I have under stage I.
well .. i was able to search but .. ahumm .. http://groups.google.kg/group/alt.alien.research/browse_thread/thread/fbc79cb8fb27201c ... wiiiierd to say the least
btw .. how is related to the TPU?
devilzangel
Hi bowser03,
Could you please post some photos of the circuit you have tested, with the detail on the coils, their winding and inter-connection?
Thanks.
@bowser0
I stumbled upon this vid today.
Is this what your're talking about?? How do they get it to levitate?
http://www.youtube.com/watch?v=IAfnK7-4Mpc
That is a brilliant video.
So it is just the rotating field it's self. That doesn't surprise me too much. Everything in the universe rotates. In martial arts rotation is used to some surprising effect. Even rotation of more 'spiritual' influence has some interesting effects.
Edit: also associated with that is direction of rotation.
Great video but I am not sure it levitate, its more like a Gyro, but its probably something near to what saucer version use with some difference to levitate
I think this device looks more like this one:
Go to 12:30
http://video.google.ca/videoplay?docid=-3874568473252816241&q=UFO+lockheed&total=23&start=0&num=10&so=0&type=search&plindex=0
Wow yaz. Nice find.
Just curious if anyone has taken a look a Stan Deyo's documents:
http://www.americanantigravity.com/documents/Stan-Deyo-Antigravity-2005.pdf (http://www.americanantigravity.com/documents/Stan-Deyo-Antigravity-2005.pdf)
http://www.standeyo.com/070822.C2C/HOT.html (http://www.standeyo.com/070822.C2C/HOT.html)
There is a video with him getting into this in a little more detail called 'Ancient of Days 3' 'Free Energy and the Technology of the New World Order' dated in the year of 2005.
There seems to be some similarities.
Something may be gained by looking at acerzw's thread on the Rodin Theory & Coils:
http://www.overunity.com/index.php/topic,3529.0/topicseen.html (http://www.overunity.com/index.php/topic,3529.0/topicseen.html)
Although I have done my share of replications I don't normally post anything. I really have not had anything positive to offer. If I ever do succeed I will definitely post the results and kit information as I believe protection in this field is counter productive. This is just my humble observations. That said, I am not criticizing anyone who tries to protect their hard earned findings.
Here is an image of a styrofoam ring coated with about ten layers of magnetic paint:
(https://overunityarchives.com/proxy.php?request=http%3A%2F%2Fwww.phonecotech.com%2FOverU%2FCopperWoundToroidal.jpg&hash=c21dd5c82c0a9b41f54eb01869f6cb1108794ee3)
The coils are 1/4 inch wide and 0.020 inch thick copper. I put this together some time ago and have been to chicken to do anything with it.
My thought was to connect either a pair of H-Bridge drivers or MOSFETs to the coils connected to some PWM ports off of a microcontroller. I am aware that the frequency would have to be quite high with a low duty since the currents with this arrangement could be very high.
I was also thinking maybe using braided solder wick for the coils might be more effective.
Pretty doubtful this thing will ever amount to much but I figure even the slightest weight reduction would be a success.
My hat is off to all participants of overunity.com (good, bad, and ugly) as all of you are a great! In the mean time I'll keep lurking.
Thanks and take care.
nap
The Nordic People have a connection with the Aryans, and I am an Aryan, having counterclockwise DNA from my father and mother who are currently living in Argentina. My father is the Son of Jesus Christ, his only son. I gave my book The Return of The Elders to Petersen, as an alias, to publish. In the book it talks about the Propulsion System and Power Generation System of the Elders of the Church of Jesus Christ, whom I met in the Mojave Desert in the early 80's. I performed prayer, Falun Dafa and Meditation aboard their craft, which had a paradisiacal appearance inside.
Their craft uses two counterrotating copper disks amidst circuitry of gold, silver and copper. They use nonferrous materials for their craft. i will attach two schematics, the first of the generator mode,and the second of the propulsion system housing.
here is the second drawing of what would be the propulsion system.
G'day bowser,
Quote from: bowser03 on November 01, 2007, 03:51:46 PM
Perhaps a silly question, but how many fathers do you have??
Hans von Lieven
Around the 80's, IBM Inventor and Scientist, Marcel J. Vogel found out that spinning water counterclockwise around his Vogel Crystals produced a wild, forceful antigravity forcefield. Here is a drawing which I channelled for a Yogic Flying and Teleportation (through the use of a wormhole) device called a Hoxcis PriSceptre. If anyone has the money to build it and teleport over to where I am on 3015 Oxford Rd, Atlanta, GA 30349, to visit me and thank me for the invention which I channelled from the Universe, please contact Rumi Da over at http://www.vogelcrystals.net and arrange for him to have Drew and Gil to make 2 Large 13 sided Vogel Crystals for the Hoxcis PriSceptre project. It should cost aroud $2000 to $2200.
<removed>
G'day all,
Just received in my personal mail entitled "My Fathers":
Quote from: bowser03 on November 01, 2007, 05:33:15 PM
Great Grandfather - Jehovah
Grandfather - Jesus
Father - Charles Solomon (the real Shinichi Seike and Adolf Hitler and Werner Von Braun)
Nice ancestry :-)
Hans von Lieven
<removed>
<removed>
Good to know that if his father is the son of Jesus, His father must have at least 2000 years! I hope he have good health assurance :)
G'day acer,
His mother cannot be the Virgin Mary, can you imagine Adolf Hitler having *** with a Jew?? Besides, then she would not be a virgin any longer.
Hans von Lieven
Wow! That was slightly entertaining.
There is a fine line between genius and madness.
Would someone remind me to NEVER use the word 'spiritual' on the net again.
I don't know but word that seems to be a lightning rod for crazy.
Back to the TPU.
<removed>
<removed>
Quote from: acerzw on November 01, 2007, 08:16:05 PM
@hans
you have a point, I am curious as to how his father managed to appear in pictures standing next to himself after all Werner von Braun hung out with Hitler a few times!
Acerzw
Multiple personalities mate, like father like son :-)
Hans von Lieven
@acerzw
net, spiritual, naughty
Got it.
<removed>
<removed>
<removed>
@acerzw
Quote from: acerzw on November 01, 2007, 08:37:00 PM
yep, NSN always!
Sorry, you lost me somewhere.
<removed>
Proof of Reverse Entropy (power in circuit runs up instead of down and charges the battery as time moves forward instead of the reverse) of Vril Black Sun Circuit Eternal Power Supply: it is now the third day after continuous running with the Joe Cell as the load of this full flux circuit and the battery still registers +6VDC. That is proof enough since the full flux was fully loading the battery with the 6 coils on the metglass toroid.
I will take a photograph of this circuit tomorrow for your your perusal.
All of my ancestral line is both blond and blue eyed, with golden tan skin like the Venusians, who are also an Aryan Colony. There is a slight metallic hint to the golden skin color. Also there is a metallic hint in the hair. My father used Chemistry techniques to color me Afro-American Indian to be in the Bowser Family, first in human flight, not the Wright Brothers. Mary is not the real biological mother of Jesus, but Mary Magdalene is a Aryan. Mary the Virgin birthed Jesus but her DNA was clockwise not counterclockkwise which is incompatible to Aryan DNA.
I have ridden in many extraterrestrial SpaceCraft, Mr. Angry Scientist, including the craft of Jesus my Grandfather. So if you can't handle the fire, then get out of the kitchen. You sound like you need a Psychotherapist with all of your unstable words. I perhaps can help you, since I have a degree in Psychiatry as well as NeuroSurgery (performed successful brain surgery by age 17). 20mg to 40mg of Risperdal followed by 250mg of Depakote at morning and at night would work wonderfully on you. Lets not forget GeoDon, which may help you out further.
You should be looking at my 4 Nobel Prizes I have attained, although you earth people have not earned more than one per person. In addition, what should that tell you, that I have indeed invented that which has made the 21st century, the century that it is, for example, my creation of MicroSoft, Apple and Intel, Unix, Linux, the transistor, the microchip, Windows Operating System. The Neutron Bomb, the Kryton, the Multiple Reentry Vehicle. HAARP, those are all my inventions, including the MERV, Cruise Missle, MX Missle.
The 8080 chip was first seen by me on Jesus Christ's SpaceCraft. So was the Unix Operating System with the mind reader based upon random numbers.
Lets not forget the touch tone for AT&T, beep, beep, beep.
And if you look really closely you can see my name as the co-inventor on all of these....now where the hell are my royalties?
I have another invention, which is a Clean Energy Tool which I call the Buddha Resistor, which is an intelligent Psychotronic Load which should do amazing things to whatever current passes through it is modified by the resistances which make up the compound resistor. This includes making batteries recharge, money magnets and other things, like meditation and blessing circuits and transuniversal tapping circuits. It uses the name of God in all the Universes, the Large (Elyown), the Middle (Elyown) and the small (El) coded into the resistances as numbers for letters, for example E would be the fifth letter of the alphabet, or 50 ohms is selected and so forth.
I have not tested this circuit yet, or built it, but will build it soon because I want to make some money with it using a coil to magnetize the currency with the name of God in multiple dimensions.
I have posted the schematic of the resistor here.
Vril is the divine name for God, therefore even if we do not use counterrotating magnetic field initially, if we call upon the name of God we will end up with them. I have attached my divine name toroid schematic, a prototype of which I have just built a few minutes ago just to see what would happen. I have also attached the photograph of the working toroid which is presently modifying the field characteristics of a mini Vogel Crystal, giving it the maximum magnetic field flux and electret's field.
The Quran warns that the nonbelievers would have the lesser intelligence. You were warned. Hellfire is awaiting you and I have visited there before. I drove the trucki bomb in the Beirut Bombing of the Marine Embassy. I also pressed the detonation switch.
Since the Vril Circuit is running off the battery and producing enough power to recharge it for 3 days I have posted here a self-running version of the circuit using super capacitors. Jolly Ho! I plan to get this circuit version running in a week or two.
Attached is the proposed self-running circuit, which should put out 415W at 47A and 600V. We will see soon. I am not using super caps on this circuit.
Quote from: bowser03 on November 04, 2007, 01:26:42 AM
G'day all,
I didn't know that Edward Bulwer-Lytton invented and named God. He certainly invented the term Vril and the story of the super race that went with it. If you have to have a fantasy Bowser, why not pick an original one instead of wallowing in this old rubbish.
Hans von Lieven
QuoteThe Coming Race (original title), also reprinted as Vril: The Power of the Coming Race, is a novel by Edward Bulwer-Lytton published in 1870. The novel is an early example of science fiction, sometimes cited as the first of this genre. However, many early readers believed that its account of a superior subterranean master race and the energy-form called Vril was accurate, to the extent that some theosophists accepted the book as truth. Furthermore, since 1960 there has been a conspiracy theory about a secret Vril-Society.
Source Wikipedia
Attached is a photo of the Vrillian Power Circuit in its weakest form (2N2222) with 6V lantern battery. The left transistorized torus is oscillating counterclockwise and the right is clockwise. The toroid at the back that is isolated with respect to the Vril circuit is the Divine Name Toroid which presently has a mini Vogel Crystal it is optimizing the magnetic field and programming of which makes it more affordable to buy noncertified Vogel Crystals off of other sites, say eBay, for example, instead of forking over $2,000 to LifeStream Associates (http://www.vogelcrystals.net). Kudos, Mom (my nonbiological Mother) for the photograph.
Dear Barry C. Bowser,
For someone who has 4 Nobel Prizes and 6 PhDs, I would think you would at least have a proper working laboratory.
What PhDs do you have, and what Nobel Prizes do you have? After all we would like to verify your credentials, if I can even call it that.
It appears you may be self medicating ::)
I am sure, if you are telling the truth, that you would have image documentation of your claims.
on a side note, http://groups.google.com/group/alt.culture.hawaii/browse_thread/thread/11257902e45399c3/7a40a594ac361ee5 , let me guess, thats you.
Did you forget how to make yourself believable? All you had to say here was you have a PhD in Electromagnetism from Caltech, and everyone here would have believed you and taken what you are saying about Vril technology seriously.
one thing though, I do get alot of Barry C. Bowser as "primary Examiner" for patent searches.
devilzangel
G'day Bowser
QuoteTo the People of Hawaii, Natives. I am the lost Cheiftan of the Tribe that Surfs the Most and will be returning as I said I would, I am the Big Kahuna.
The time I was in Hawaii at the age of 17 was great as I surfed
through the tunnels of water at least 3 times completely without
error. They named me the Chief but I said I had to return to my
family. So they told me they would expect my return to lead them
someday. That day is now. May that tribe name themselves on this
Newsgroup and remember the name Barry C. Bowser. And may they again
accept me as their Cheiftan.
This is the time of their enrichment. The New Powers of God will make
them wealthy beyond measure.
Are you sure Bowser that the natives of Hawaii want to be led by the son of Adolf Hitler??
Hans von Lieven
Thanks for the link devilzangel :-)
Quote from: devilzangel on November 04, 2007, 04:19:26 PM
devilzangel
As you can see here (http://www.patentstorm.us/examiners/Barry_C_Bowser-1583519.html) Barry C. Bowser was Assistant Examiner between 1994 and 1998.
QuotePrimary: Kenneth A Wieder
Assistant: Barry C Bowser
And this is Barry C. Bowser himself:
(https://overunityarchives.com/proxy.php?request=http%3A%2F%2Fimg223.imageshack.us%2Fimg223%2F9440%2Fimg0001zj2.th.jpg&hash=1c7d0ac77ce262654288e2b16cb40d41a645a44a) (http://img223.imageshack.us/my.php?image=img0001zj2.jpg)
"Even though I was a fit triathlete and the youngest person to be made an agent of the CIA (agent 777, the most perfect agent), now I am obese and am trying to work off the fat."
Once he allegedly worked on a Tesla Turbine and intended to "apply both Brown's Gas and Joe Cell gas to try to get over 400Hp from a 10" model for cars airplanes copters and motorcycles"(source) (http://www.phoenixnavigation.com/ptbc/memus1.htm)
Some more findings lead to the impression that Mr. Bowser must have lost his marbles....
http://groups.google.co.im/group/aus.invest/msg/f243ce5980ba84d2 (http://groups.google.co.im/group/aus.invest/msg/f243ce5980ba84d2)
http://groups.google.com/group/alt.culture.hawaii/browse_thread/thread/8c932045d172a27e/cc7fe9c5c692f99c (http://groups.google.com/group/alt.culture.hawaii/browse_thread/thread/8c932045d172a27e/cc7fe9c5c692f99c)
http://www.gobignetwork.com/profiles/barry-bowser.aspx (http://www.gobignetwork.com/profiles/barry-bowser.aspx)
http://dunedin.lug.net.nz/forums/showthread.php?t=189895&page=1 (http://dunedin.lug.net.nz/forums/showthread.php?t=189895&page=1)
http://forums.prosper.com/archive/index.php/t21990.html (http://forums.prosper.com/archive/index.php/t21990.html)
http://www.talkabouteducation.com/group/soc.genealogy.medieval/messages/162163.html (http://www.talkabouteducation.com/group/soc.genealogy.medieval/messages/162163.html)
His homepage does not show up any exculpatory signs either: http://www.geocities.com/brrybowser (http://www.geocities.com/brrybowser)
Instead of making jokes at Barry's expense simply ignore him or delete his account.
This man needs serious help.
Well, after reading all this crap, i think he need some help, lol
G'day all,
QuoteInstead of making jokes at Barry's expense simply ignore him or delete his account.
I agree with you Pontifex, this guy not only needs help he would appear to need careful monitoring. To illustrate my point two quotes from his web site:
QuoteI also have done my Hajj (Pilgrimmage) to Mecca.
I was the first person to strap on a body bomb and knew Osama bin Laden since the beginning.
and
QuoteI also drove the truck bomb into the Marine Encampment in Beirut killing 250 Armed Service Personnel and myself, and I went to Heaven and returned unscathed.
If this is really where this guy's head is at there is real reason for concern.
Hans von Lieven
I was curious to see how far/long this thread would go...
Just Map Quest the address he posted, it will tell you what you want to know.
At the age of 15 I was tortured to death in a Romanian Detention Center for merely passing out Bibles and talking to people about Jesus, my Grandfather. The person who tortured me to death mysteriously died before I died. God killed him. Anyway, concerning God, I have been to Heaven several times and seen the Throne of Glory. I have seen my Great Grandfather since I was 5 years old. The 24 Elders that sit around the throne all introduced themselves to me. That is also where I got my Nobel Prize concerning Fractals when I was discussing them with Buckminster Fuller at his Dymaxion Home. He was enthralled with the thought that God had fractal floor tiles in his mansion and let the people at IBM know so I could get another alias name Prize.
I need no help except money, and even I have solved that problem by now. I give help. Give and it shall be given to you. . .
I also created Hewlett-Packard, selecting the two boys out from their college class. Stephen Hawking knows me too, we had a good conversation when I was in California. The Quran states that you should not be respected as a hujman being unless you believe in one Central God, some of you out there, the naysayers are such. Not even worthy of the computer that they are typing out their inane responses on. But it is the beleivers that I am trying to get to, may the Sun of God shine on their faces and Cherish them.
a question for you
do you have an explanation on the tpu with all your knowalage?? or even have a good idea on a simple working unit??
this should be simple for some one with 4 nobel prizes lol!!!!
ist
Quote from: bowser03 on November 06, 2007, 02:38:18 PM
Stop saying bullshit, first
If you have 4 nobel price that mean 4 millions dollar, You don't have one million just by looking at your setup and you need money.
Bill Gate Created microsoft not a dumb ass like you.
I can continue......
GOD dont exist. Its pure fantasy. Jesus never existed ether. Its just story from maya "formatted" to the new age to enslave the world. Liste Jordan Maxwell if you want to know more about it.
So stop saying shit, nobody here believe you
More you talk more you look stupid.. Talk about your device not you.
Everyone's so quick to judge in here, sheesh. :)
What's wrong with being a legend and a hero in one's own mind, not as if it's a crime, is it?
I think the point is whether this person has anything valuable to offer, when it comes to ideas or findings. Whether this person needs to be "monitored" or not is not up to us to decide, furthermore it is not up to anyone. Contrary to what the current "sane" norms are or what shrinks believe is, they don't know either, we just let them tell us because we think they are smarter than the rest of us (and they really aren't).
So, bottom line is whether any of these circuits presented make any sense or have any value, that should be the our target...and not the OP.
Quote from: amigo on November 06, 2007, 07:06:49 PM
Sorry mate,
When someone starts fantasising about blowing up people with bombs and puts this out on an open forum I think monitoring might be a prudent precaution.
If this should not be up to someone to decide, I don't know what is.
Hans von Lieven
Quote from: TheOne on November 06, 2007, 06:12:02 PM
You should find better words to use against this guy. It doesn't matter if he's a sociopath, schizo, or whatever disorder we could find in psych books. Keep your garbage off the thread.
As for browser man, to be more genuine to others on the forum, I suggest keeping your beliefs to your self. Some people do not have the intelligence to block out the things you say and get right to the point; they will mix all your words together and then build your credibility. I'm pretty sure your theory will grow much faster if you get right to the point, and not post things connected to religion.
For a deaf person to read your lips, you must stare directly at them and speak clearly. (Not saying your guys are deaf, just a statement that relates to what I just said in some way)
So, in conclusion, no religion or ancestory, JUST TECH STUFF. ok? :)
Oh God, please save us from your followers!! lol.. :-\
I can't believe I just wasted my lunchtime reading this topic,
but it was like a car crash, as awful as it was, I couldn't look away.
I realised some ten years back that some of the things I was studying
had the ability to send a person mad. I had to make clear lines what was
essential to know and what was essentially unknowable, lest it all get muddled up
like Barry's tangle of wire and I end up with a flat battery and nothing gained.
Barry is obviously a well read individual but has not drawn the lines necessary for
a healthy mind to take in this sort of information and not spiral into chaos.
What to do? Barry, you can only help yourself.
Quote from: Goldsphere on November 08, 2007, 09:20:28 PM
I could not say it better.
;D ;D ;D ;D ;D ;D ;D ;D
I have as of 6 days ago received a technology from an extraterrestrial civilization. The technology uses pi as a mathematical source for generating Love. It is the same as Vril. It uses plastic drinking straws to generate Love directly from space and you can feel the love and kindness it generates.
If you say "Oh God please save us from your followers" and you do not accept Love, which is a thing which all creatures respond to, then you are in error. You need to be covered in Love to work with all free energy devices because ultimately they get their power from the Love of God.
The Civilization is called the Terbluthycian Civilization and they come from another parallel Universe down the hydronautical stream from ours. Their message is of the Universal Truth of Pi being a form of Transcendental Constant of Love and the straws bent form the letters L.-O-V-E in squiggly lines thus forming the word Love and invoking or tuning into the Universal Love frequency. This Love you can feel in your Hara or lower stomach like a laughing gas has been placed there. The three dimensional word Love is formed thus tuning in and broadcasting love to all sentient beings in the nearby vicinity and anything that has consciousness including air molecules which are transformed into a gas which humans more likely love than the previous and can breathe better and a better room atmosphere.
Overall the project of the Ah wan de wan de wan de wan de Oh I'm in Love (that was the song they gave me) is successful. The universal Love Song is good along with the telepathic video of the mathematics of Love showing 0=3.1416=Pi.
2;15 I just recieved another vision of a terbluthycian man showing his dark blue hands circulating around and around, both of them in sort of a Choku Rei symbol. The left hand counterclockwise and the right hand clockwise and then the left hand clockwise and then the right hand counterclockwise. This shows the Love energy spiraling from inner spaces to outer spaces and forms a space circuit for the growth of Love. I immediately followed the motions holding my Vogel Crystal and tracing them with my hands after I saw the vision and focusing on the Love Radios in the next room and I immediately felt my lower base feet to lower base Chakra warm up with energy of Goodness indescribable.
I will take pictures of these two radios side by side tomorrow as I have traced the motions and made them out of the plastic straws. This amplifies the Love radio by 10 to 20 tiimes a factor and is very important.
Thanks to the Blue Men of another Civilization for getting ours correct in Love, which is the ultimate Power we need to solve mankind's problems.
LOL
G'day Bowser,
Do the colours of the straws play an important part in the "Love Generators" or is it just the shape that counts?
I can only get uniformly pink straws here and I don't want to cause any unwanted effects with my replication.
Hans von Lieven
Hmmm....
This is interesting. I have plenty of wire. It certainly hasn't increased the love around me.
I think I'll work with some straws. I could use some more love. Maybe we all could?
LOL (Lots of Love)!
Dear Mr. Bowser,
you are right.
Relative Chaos and Relative Super Chaos.
Using self ordering and distortion at the same time.
The distortion comes in in the massive (max overdrive) overdrived semiconductor.
You are not a pinky.
Self ordering due to the selfoscillating characteristic of the seike landau oscillator.
An selfordered chaotic link to the hyperspace.
Because of nothing will go in, something must come out.
But the frequency shift is due to the temperature shift of the semiconductor (maybe not).
But if he got another resonating structure intermediating the pulsed rotating fileds, they are linked to anotherm prommising "sweet" structure.
Cold or Warm, Love or no Love, dualism in its highest degree.
Don't be confused about my applause.
I've refered JLN and asked him about his interpretation of his measurements in the ring (without coils (only one transistorized)winding):"JLN:...I was only comparing my results of the measurements with seikes proposed results. They fit! Nothing m,ore".
See you in the future.
To do what you think is the best for you (low resistance).
This mail is only for Lovers, not for bad enthusiastic low time sharer.
o.k. Now let us start to introduce love waves as much as the light in your heads will flicker for a short time.
Then you know that this waves are for real.
Don't stumble about others works.
Real lovers shut down their ego when contacting higher teachers.
There is another light which we share together in contemplated situations.
This resonant waves fulfill all harmonic octaves.
The truth.
Have a nice workful day
.:DAKDUEMGUEDLIMK:.
kaRLfunkel
"...I have only
Bowser,
all your claims of being a superhuman cia nobel-prize winning genious son of God and Hitler at the same time aside for a moment,
can you please give a clear description of a VRIL energy generation device, and how to build one?
In a previous post you said "VRIL technology in an electromechanical homopolar-like full flux design" and even that it can also be achievd using electromagnetic field coils. What exactly do you mean by this? Can you please descibe in more detail and greater clarity what you mean?
Are you talking about two counterrotating metal discs in a homopolar magnetic field? How is the resulting effect any different from the Biefelt-Brown electrokinetic effect between two highly charged capacitor plates?
And how do you imagine a propulsion unit would actually produce output energy? Or is the VRIL propulsion not the same as the VRIL energy source? In that case, are you certain you have described the energy source or are you happily throwing VRIL-related remarks around that actually concern 2 entirely different devices?
and @Karl: "chaotic self-ordering characteristic" and "freq shift due to temp shift of (semi)conductor"... Are you sure you are not talking about an "adiabatic energy pump" here? Aka harnessing the 'natural' barkhausen jumps, temperature gradients, and spin variations, by forcing them into sync with the pulsed activator coil/circuit...? If not, then maybe you can explain what you mean in greater detail?
This Bowser guy may be in an altered state of consciousness, due to drugs or some spiritual technique.
In this state he may be identifying himself with some historical and archaetipal beings, such as Jesus. He must not be definitely mad, he may be receiving all kinds of informations from the collective consciousness and since his Ego may be temporarily vanished because of this altered state of consciousness, he believes he is the beings that he receives information about, on an open paranormal channel.
By the way, the bunch of straws in the last pictures looks like one of the Grebennikov devices for creating some bioenergy.
Just an idea.
Quote from: bowser03 on November 14, 2007, 09:13:17 PM
I have as of 2 days ago received a technology from an extraterrestrial civilization. The technology uses pi as a mathematical source for generating Love. It is the same as Vril. It uses plastic drinking straws to generate Love directly from space and you can feel the love and kindness it generates.
http://www.overunity.com/index.php?action=dlattach;topic=3538.0;attach=14338;image
http://www.youtube.com/watch?v=-xHw9zcCvRQ
ehhhh....
It was on the night of the 10th, just after the Shabbat/Sabbath that I was contacted by the extraterrestrial civilization of the terbluthycians (ter=terrain, blu=blue, thyc=skinned, ians=people) which showed that they were anxious to get me the information, yet honored the Shabbat just as it says to do in the Bible, the seventh day of Creation. This goes in meaning with the Kabballah and the fact that David Cone, the extraterrestrial who had a conical head and was also from another universe downstream had mentioned that the English language was the most common spoken language in all of the Universes. Therefore Kabballah has much to do with convergence in the English language in addition to its base 10 mathematics, and fibbonnacci sequence numbers like 3,5 and 7. Love is spelled out with the straws using Pi as the delineator and the bends as L and V e. The Magen David symbol is Kabballah and part of the Tree of Life Geometry while the Choku Rei symbols are part of Universal Life force expansion and contraction expressions.
The photos are taken and as soon as my nonbiological mother emails them to me I will post them.
In addition, it should not matter what color the straws are, for convenience sake. Color adds spice but nothing more.
In addition, to say what I am, what drugs or mental state I am in is useless. I remain in the state of a Buddist Monk that I am, since zI trained high up in the Tibetan Mountains Monastery in Northern India where the Monks raise the temperature of their bodies so that they cannot freeze in the cold and draw steam off of wet blankets.
I have and remain a freind of Sai Baba's in India.
I am still the reincarnation of King Arthur and know Jimmy Lin, who is the reincarnation of Merlyn the King's Wizard, who helped me found Microsoft and Apple. I am also the Blood Grandson of Jesus Christ, trained to be a Jedi knight and Christened a Knight aboard his SpaceShip. I know a great many Civilizations and this includes the underwater City of Atlantis in the Atlantic Ocean. I have visited there and talked with the King, who told me that they had given surface dwelling civilization Pi and that is the secret of the free energy systems for lighting and power.
boy, you sure cant make much sense of the data but it's fascinating nevertheless.
Most races in the universe are sculptured out of the same genome stuffs. The blue is just like people get brown from the sun and after generations they eventually turn black. They become blue from the silver in their diet. Without silver humanoids can only get 200 years old or so. Not sure why the greys are grey tho.
PI is the angle under which our dimension exists. In other dimensions a circle can be 720 degrees for example or 180. To us it would appear as if everything is the same on both sides.
We already see this spinning particles in the micro world. It's just like the moon faces the earth after zero degrees of rotation.
In our universe Ãâ,¬ = 20612 / 6561 there is just a slight variation from one end to the other. If we didn't have that variation matter wouldn't have a location. Location is merely an illusion after all. :-)
The English problem yes, English has to much emotional parameters. It's not hard to learn but hard to stomach. hahahaha
You forgot to post the construction drawings btw.
How do you expect us to build this machine like this? pff??
The 2N2222 circuit is dead, and didn't recharge the battery, however, with the extraterrestrial correction of the Universal Love Transceiver, or Love Radio, we have new possibilites in addition to a free energy circuit. To get free electricity from it, we will have to try some interesting techniques. Maybe the battery can be sustained by Love directly and recharge from the nearby radiation. Or it may charge up an electrolytic or supercapacitor.
Let us pray: Dear God the Most High, thank you for the Civilizations and you yourself. Thank you for the Atlanteans and the Terbluthycians and their progress into Love and Free Energy. Please help us to match or equal theirs as we learn from them and make them to feel they can rely on us to transfer their aged wisdom and knowledge. In Jesus name we pray. Amen.
_
mvvghhjuizvo68970ughvjkjhgvcrtzi8760#*'??oi09zj,-m,nvgcio6p98z8hhhhhhh?oihip08? ? l gzgguih#
?ok,o?pokpo?onzo877huhpuiphmk+?om?z87rc76h
#?ppoioiiuz986632^12e5r21%())?`Pkdfhkposh<df&%&?(?=()&/)78ituzlgfbjciojg?3?wlb ?lgh
4w50oizs?+?h0fxdgh0iifpokhlvc??fghlkf?h+?n0
?z?
n
ebycolisp#canescens
Quote from: karl on November 16, 2007, 03:49:04 PM
?z?
n
ebycolisp#canescens
Just when I thought this thread could not possibly get any sillier,
IT DID ! :-(
Hans von Lieven
Quote from: hansvonlieven on November 16, 2007, 04:00:17 PM
Just when I thought this thread could not possibly get any sillier, IT DID ! :-(
Hans von Lieven
How is this Hans? ;D
QuoteCOUNTER ROTATING FIELDS
ABSTRACT
Delayed magnetomecanical entrainment utilising 3 point interaction[1] by means of inductive shielding[2].
http://magnetmotor.go-here.nl/text?counter-rotating-fields
Well Gaby,
for one, the Kalathumpian Dialect that Karl uses is unfamiliar to me ;D Perhaps to other people too??
Hans
You have to read between the lines. And between the lines between the lines. And so on.... Just reading the headlines is not good enough.
What about my paper for example?
...between the lines we have to read...
and deeper...
and more abstract...
and then intiution takes place...
and then fusion happens because of the clearness according our own life and existence...
and then we have to pray for forgiveness because the fire will clear our mind and our bodys...
and then we feel our different point of view in the resting time of our life...
and then we let it flow in and out without wanting to manipulate further the background of our existence...
and then we get back to our roots and feel the perfect compositino of life...
...and maybe sometime we learn to understand that the earth is the middle of our universe in uor self....
and then you understand Mr. Bowser
...and then to respect each others opinion also without over unity...
...but with "unity" with the inner and outer spaces of our existance...
.:then we open our eyes:.
"...teach me to walk softer" BLACK ELK SPEAKS (HAWKWIND)
fight or flight...
...then
http://www.youtube.com/watch?v=fGLoCoBGt3A
YouTube - MerKaBa star tetrahedron fields - crystalline body of light
I thought this was a serious forum, a scientific forum. Some of you people would be better off on the SVPVril forum, they discuss at great lengths the rotational direction of love energy. >:(
It's fine to be open minded and all, but when someone claims to be the son of Hitler and the grandson of
Jesus then shows you a bunch of crumpled up straws and claims it to be an alien technology, then you really
got to ask yourself if they're playing with the full deck here!!
Gaby, that video showing the animation of Garrett Lisi's theory was very interesting, thank you for sharing; but
to relate it to bowsers badly made star of David from straws is by no means any proof whatsoever
that Mr Bowser here has anything useful to contribute.
Top gaby de wilde:
similar effects as on your side but while using aluminium instead of mu-metal:
http://jnaudin.free.fr/html/qmm11r3d.htm
and here the possible explanation (fast as light):
http://jnaudin.free.fr/html/revlenz.htm
Are there some results of your experimentation?
Is this compareable with the neutral line experiments while interlacing two magnets fields?
I know this experiments from swiss SAFE workshops using a copperwire or sheet as sensoring material while moving two
magnets synchronus away from the copperline. No induction appears Mr. Leenz! But there are two strong fields which are changing.
This is the basix.
Many greatings also to all FSRE (FriSpuureRingIurop) sponsors and donators spread over the united kingdom of the great Queen.
Best wishes for your further work and distribution of fresh and rare knowledge.
Verry nice work and collection.
Best wishes
kaRLfunkel
Blue Men's Circuits attached.
Reminds me of that song that goes "Love my way, its a new road .. . ."
To get Love from a Machinie is a new Road, and you should love the Way the Terbluthycians communicated to us.
Cheers to All, Victory is Ours.
In addition, because of the Psionic Link, the Love should be able to be felt, or its effects made through that image being displayed on your computer screen.
LOL
This has to be the silliest thread on this forum !
Hans von Lieven
I think i've got it. The answer to this whole thread.
Bowser must have eaten too much lsd and is trapped in a hallucinogenic state.
I believe this happened at a young age in combination with playing super mario brothers, So basicly I'm Sure that since then he has been communicating with Jesus, Hitler and lets not forget the cia, THROUGH THESE MAGICAL Straws He may actually be some guy trying to make his own personal catheter (tube which you pee out of in surgery) so he dosent have to move out of his seat.
Now since these straws have been in the special area, it then allows them to be over unity energy receiving communication devices.
Guess that's where the "LOVE" comes in Joe :-)
Connection with the "special place"
Hans von Lieven
Quote from: karl on November 17, 2007, 07:59:08 PM
Top gaby de wilde:
I didn't intend to use mu metal, just iron. My concept is very different. One of the main goals in my views is to create an approach that is vastly different from the departure. The motor shown here at best has only a slight flux difference between those. If it would work you would need a motor bigger then your house to power a light bulb.
QuoteIs this compareable with the neutral line experiments while interlacing two magnets fields?
Yes very good, this is an important part of the invention. Forgive me for being to lazy to add a link to such page. That should absolutely be included. :-)
http://magnetmotor.go-here.nl/wesley-gary
Wesley Gary - MAGNETMOTOR.GO-HERE.NL
What could be considered "the joke" is that the conductive medium is placed closer to the primary as to the secondary magnet. This allows us to rotate the primary in order to change the polarisation of the medium.
You will find when placing the "shielding" exactly in the center no field is inducted into it, like Wesley described the magnets cant see each other here.
QuoteI know this experiments from swiss SAFE workshops using a copperwire or sheet as sensoring material while moving two
This is the basix.
yeah. :-)
My proposed Sun-Son generator is not a homopolar even though it looks as if it should be. It uses full flux however, from North to South in a circle. I beleive a 1' diameter model should deliver 20kW at least.
In addition, it also comes from an extraterrestrial civilization, the Church of Jesus Christ.
Quote from: bowser03 on November 18, 2007, 09:11:58 PM
Is this what happens when cults get kicked off of other planets ?
WOW !!! They have Jews on Aldebaran??
AMAZING!!!
Hans von Lieven
There is another civilization that contacted me who call themselves the Onomatopoeians. in Wikipedia, "Onomatopoeia (occasionally spelled onomatop?ia) is a word or a grouping of words that imitates the sound it is describing, suggesting its source object, such as "click," "buzz," or animal noises such as "oink", "quack", or "meow". The word is a synthesis of the Greek words ÃÅ'νομα (onoma, = "name") and Ãâ,¬ÃŽÂ¿ÃŽÂ¹ÃŽÂÉ (poieÃ...Â, = "I make" or "I do") thus it essentially means "name creation"."
This civilization showed me origami paper pyramids arranged in a 10-point Kabballah format 2-d array which modified the first Love Radio and gave it 100 times the power output of Love.
I will photograph the Kabballic Array and place it here later on today.
It is interesting that the pyramid is an onamatopoiea for Love too, spelling out the letters LO and V with the O as a square or the base of the pyramid.
Onomatopoeic words exist in every language, although they are different in each. For example:
* In Ancient Greek, brekekekex koax koax: a frog croaking.
* In Chinese, miÃ,,Âo (Ã¥â€"µ): the sound a cat makes.
* In Dutch, kukeleku: a rooster crowing.
* In French, pan: a gun or cannon firing.
* in Finland hau hau: a dog barking
* In German, peng or p?ng: a pistol shot.
* In Haitian Creole, bip: the sound of a collision (ex. a car crash).
* In Hindi dhadak and Urdu dhakdhak (pronounced /ˈd̪Éâ,,¢Ã‰â€"Éâ,,¢k/): a person's heartbeat, indicative of the sound of one beat.
* In Icelandic, "tikk, takk" is the sound of a clock ticking, and "b?mm!" or "bamm!" is the sound of an explosion. Atsj?! is also the onomatopoeia for when a person sneezes.
* In Japanese, doki doki (ãÆ'‰ã‚ÂãÆ'‰ã‚Â):e the (speeding up of the) beating of a heart (and thus excitement).
* In Korean, meong meong (ë©Âë©Â): a dog barking.
* In Latin, tuxtax was the equivalent of bam or whack and was meant to imitate the sound of blows landing.
* In Proto-Indo-European language, kwkwlos = "wheel", from the noise that it makes when rolling[citation needed]: from which English "wheel", Greek κÃ…κλοÂ, etc.
* In Russian, gaf gaf: a dog barking.
* In Turkish, hapÃ...ŸÃ,,±rmak (the verb for to sneeze): is based on the sound hapshoo made by a person who sneezes.
* In Vietnamese, vi vu: the sound of a gentle breeze, and v? v?: the sound of strong wind.
* In Malayalam, "umma": the sound of a kiss
Sometimes onomatopoeic words can seem to have a tenuous relationship with the object they describe. Native speakers of a given language may never question the relationship, but because words for the same basic sound can differ considerably between languages, non-native speakers might be confused by the idiomatic words of another language. For example, the sound a dog makes (help?info) is bow-wow (or woof-woof) in English, wau-wau in German, uau-uau in Interlingua, ouah-ouah in French, gaf-gaf in Russian, hav-hav in Hebrew, wan-wan, bau-bau, or kyan-kyan in Japanese, guau-guau in Spanish, bau-bau in Italian, vov-vov in Danish, woef woef [as English woof] or waf waf in Dutch, wou wou in Cantonese, voff-voff in Icelandic, hau-hau in Finnish and Polish, haf-haf in Czech, hav-hav (pronounced like English how-how) in Slovak, guk guk in Indonesian, bub bub in Catalan, ghav-ghav in Modern Greek, wou wou in Teso, g?u g?u in Vietnamese and meong meong in Korean.
In the case of frog croaking, the spelling can vary because species of frog found in another area may make another noise: Ancient Greek brekekekex koax koax for probably Rana ridibunda; English ribbit for species of frog found in North America; English verb "croak" for Rana temporaria."
This also goes for Vogel crystals since they contain 3 pyramids. And my father, the Son of Jesus Christ and I invented the crystal telepathically and I ordered the lathe for Vogel to cut his first crystal at IBM.
In addition, on a separate note, the 6V lantern battery that was dead due to the last experiment was charged by the Love Radio number 1. That is some free energy success.
Man there's this little voice in the back of my head screaming DOS ! do yo know what that means bowser, Denial of service, you better spread the love man or else i think the spy bot may come for you and well with him comes denial of service so make sure your energy transmitter is transmitting .. I wouldn't want someone to send you maybe a script that would over clock your video card processor and well that burning up counts as DOS. Its nice how modifiable n tune is now days.
One thing I've learned in life is that everyone will get exactly what they are looking for in people - and everyone will get exactly what they need from people if they simply just let them be.
Altho Joe B. makes some claims that do not make sense - it really means although it doesn't sense to you, it doesn't mean it doesn't make sense to someone else.
To that I can say that I have personally seen, heard, and felt things that still do not make sense to me - but yet they happened.
Oddly enough, during yesterdays football game the receiver caught the ball, was tackled, and upon rising tossed the ball to the ground with a spin - the ball spun so beautifully thar the referee who came to retrieve the ball stood back to observe - until an opposing player walked by and kicked it over - and I so wanted, and so did the ref it wood seem, to see how long the ball would have spun - but due to an unforseen incident, I do not have that information for this report.
Bombers win and move on to the Grey Cup game against Saskatchewan next Sunday tho.
:) A pyramid also generates a spinor vortex in the middle from the tip to the base. This is Vril or Love Force also, being three-dimensionally Onamatopoeic also. I have attached the photos of the Love Radio no.1 with the 10-Pyramid Energy Matrix (Kabballah), a photo of Love Radio no.1 on top of the mysteriously recharged 6V lantern battery, and 2 example Vogel Crystals.
With all of these Love Radios in the house radiating this energy, and two extras for Thanksgiving Gifts it is like being on a vacation on a Tropical Island, like Bora Bora for instance, as relaxing as. ;D
LOL
brekekekex kukeleku,
doki doki tuxtax dhakdhak umma? vov-vov g?u g?u ouah-ouah miÃ,,Âo!
meong meong ridibunda
How is my Onomatopoeian coming along Bowser, I really want to talk to these people, if that's what they are.
Hans von Lieven
Incidentally, why the upturned chairs on either side of your altar? Ancient Onomatopoeian custom perhaps?
What is the sound of electricity if it so be? Hisssssssssss, or ssssssssss or zzzzzzzzzzzt. Well we isolate S and Z and get a zig-zag shape, which will be the amorphous metal core of my next experiment to derive electricity directly from space as a 2-d to 3-d onamatopoeia. I will take several strips of metglass, tape them together to make a core, wrap wire from one end to the other and bend the core in an S or Z format and connect either to my tongue or to a volt or ammeter to measure if there is any resultant current.
If the Onamatopoieans are correct, electricity in the high voltage should result, or high current enough to make the sound SSSSSSSSSSSSS or ZZZZZZZZ when near shorted.
I heard thats possible if your take apart a disposable camera and stick your tung to the capacitor while holding the charge button .. its like sending your self everywhere and nowhere all at the same time you should really try this bowser. :o :o :o :o :o ASAP, STAT, yesterday, Now ,THIS SECOND , Catch the drift :o :o
Mmmm.....please let us know how you go with the experiment.
If successful, can you post all your results and methods of obtaining them so that we can reproduce it.
Thanks.
Bowser, don't forget that tensor/twistor theory allows for antimaxwellian longtitudional waves to be generated which obviously occur in infolded vortex mode, as in the one vortex wrapped inside the other. This presents a possibility for a biased scalar division over the 4th dimensional axis, which should allow for direct tapping of the all-encompassing energy sea. You may call that sea "love" or "prana" or "chi" is you want, fine with me. As long as you don't forget that we do want to get usable power out in some form, and current technology needs that to be in the form of electrical output for it to be of any use.
Rotating the tensor/vortex system along one axis to achieve direct output of "love" energy is not directly usable in any electrical application, so we may need to split the positive and shunt the energy into the tangiable electical realm. You could do this be counter-rotating the Heaviside components in the electromagnetic vortex at the right angles and speeds, but that seems very tricky.
I can't get that to work using a handfull of crumpled straws...
:P
Hans:
Please please please no vogon poetry. I wont be able to stand it after all this. There dont seem to be an entry in my guide for this?
ROTFLMFAO.......
thaelin
Quote from: hansvonlieven on November 19, 2007, 10:51:30 PM
Hans von Lieven
I am planning to build the Love Radio out of 12"x1/8" copper tubes at $1.00 each, so I will be using about 20-25 tubes total. We will see if that generates electrical current at one of the tubes. I know that a copper pyramid generates more pyramid energy than most other materials of the same size. I should do well for the onomatopoiea Love too.
Goldsphere? :o
We shall see what gold there be. ;)
Welcome to the forum. :D
Quote from: Thaelin on November 20, 2007, 10:47:41 AM
Hans:
ROTFLMFAO.......
thaelin
No Vogon poetry thaelin, I only used the Onomatopoeian words that Bowser gave a definition for in an earlier post.(you can check)
This is serious stuff indeed. We mustn't upset the creatures that show us a whole new technology only using crumpled straws and folded paper napkins. Free LOVE energy, here we come.
Hans von Lieven
Bowser, great that you're into Love and all, but could you focus on energy in a usable form, like ELECTRICAL for example?
Come on. The VRIL thing was still ok-ish, since VRIL research seemed to show a clear and direct conection with electromagnetism, and a VRIL energy source fits nicely in the category of potential overunity devices. But crumpled straws and wrinkled napkins combined with lots of nonsensical utterances about Love and Christ clearly do not. Can we get back to the TOPIC please, which is after all "VRIL counter-rotating fields"?
And please stop the Oompaloompa crap man... :-\ Half of the "examples" you gave of onimatopeic words are not even correct. And besides that, using imitated sounds as words does not actually qualify as "extraterretrial civilisation". And even if it did, who do you think you are kidding with your straws?
Are you sure you haven't been eating the wrong kind of mushrooms? Here's a quick check: does the dog speak to you? Do you see lovely rainbow colours all around? Do the trees dance?
"Some day, after we have mastered the winds, the waves, the tides and gravity, we shall harness... the energies of love.
Then, for the second time in the history of the world, man will have discovered fire."
Teilhard de Chardin
"The wise exist but it was said to go ye out and hide amongst the foolish."
Bowser03
.:Dear Lovers and Neophytes of all grades:.
Study the following well thouhast then an plus on knowledge.
Pure Electronics Meets Philosophic Insights In The Inner Sanctum To Chill (PEMPIITISTC)
"THE WALKER
Ana Vi?es S?R?C?
Brothers and Sisters:
When beginning this manuscript a thought came to me of a fragment from a poem that says: "The walker is not made for the road, the road is made for the walker."
I pause a moment meditating on the reason this sentence came to mind and then realized that those expressed a great truth since within them the seven Hermetic Principles may be found in a condensed form.
Let us see then how this sentence applies to the first principle.
MIND
This principle says, "EVERYTHING is mind"
Life as we know it, the universe, energy, matter etc. is the ALL; and nothing can exist outside of the ALL, because if that were possible it would not be the ALL.
What is this ALL? Is it matter? No, because it is greater than matter. Is it then, energy? No, because it encompasses the entire universe. Is it the universe then? No, because it contains life also, so is it life? No, rather life proceeds from the ALL. What then, shall we call it? We can conceive of it best as MIND; an infinite and living mind that can only be understood when compared to a living but finite mind since things can only be understood in comparison to one another.
This is revealed to us; that everyone and every phenomenon in the universe, though they are distinct parts, are united and exist as the mental creations existing within the MIND OF THE ALL in whose being we move and have our very being for all eternity. Truly, the ALL is the walker who creates the road by walking it.
CORRESPONDENCE
This principle declares: "As above, so below; as below, so above." .
If we meditate a little on this old axiom we will notice that it fits with the fragment of famous poetry. This principle tells us that there is always a correspondence between the laws and phenomena of the various planes of existence.
This principle of correspondence applies to the universality of manifestation in the various planes of existence, material, mental and spiritual. It is a universal law. From this we can deduce that if man is a mental creation of God and is made in the image and likeness of God, then according to this principal of correspondence man is also able to create at his own level of vibration.
Therefore, regarding this principle we can also apply our sentence since the walker is the one chooses to create the route in going toward a destination.
VIBRATION
Everything is in motion, everything vibrates, and nothing remains at rest."
This principle indicates that the differences in different manifestations of matter, energy etc. is entirely a variation of the vibratory frequency. Emanating from the ALL, which is pure spirit, from the highest down to the densest matter, all is vibration.
The vibration of the spirit is of such a strong intensity that it seems almost to be at rest. And at the opposing pole, that is to say matter, are forms whose vibrations are so low they too might seem to be at rest (a stone for example). Between those two poles of course, millions and millions of varying degrees of vibration manifest the different planes of energy field, all as mind taking form.
If everything is vibration, as presented, constantly in motion and generating movement, then it also applies well to the words of the sentence about the route being made by walking.
POLARITY
"Everything is dual, everything has two poles and everything has its opposite. These opposites are alike in kind but differ in degree."
Humanity has always recognized something similar to this principle and expressed it in maxims such as: Things both are and are not, at the same time, there are two sides to every issue, all truth is half true and half false, and so on. In this we express realization that the ALL and the many things are the same thing, varying only in degree of manifestation of mind. In this sense, the LAW and the laws are two poles of the same thing.
Applying this to the material plane we can observe it in multiple aspects, such as cold-hot, light-dark, east -west, white-black, etc. These terms are not absolute; we often call one end of a scale good, and the opposite polarity bad. Let us however, keep in mind that for every good thing there will always be one that is better still, and vise versa.
The mental plane is the same. Let us consider the example of love-hate: which we consider diametrically opposed and irreconcilable. However if we apply the principal of polarity we recognize that there is no absolute love or absolute hate, totally different from one another. Rather by ranging across the whole scale from one end to the other and then coming to rest in the middle, we realize that those terms are so relative that is hard to say where one leaves off and the other begins.
A profound knowledge of this principle can lead us to a better understanding of our mental state and the mental states of others as we come to understand that things are relative, it is only a question of degree. We can use our will to move up or down the vibratory scale and in this way stop being enslaved by our mental states. We need to remember that we are all walkers, creating our route by our walking it.
RHYTHM
"Everything flows, rises and falls; everything has its tides; the oscillation of the pendulum is manifest in everything, the swing to the right in equal measure to the swing to the left, the rhythm compensating to retain balance."
For every action there must always be an equal reaction. This is the way of everything in the universe, the way of worlds, the way of men and animals, the way of the mind, of energy and of matter. This law is manifest in the creation and destruction of worlds, in the rise and fall of nations, in the lives of all beings and of course in the mental states of men.
If we learn the previous principles and how to apply them we can adjust our rhythm by polarizing it to the point that we feel at peace, neutralizing in this way the oscillation of the pendulum that would otherwise carry us from one pole to the other with the inertia of its constant movement.
CAUSE AND EFFECT
All cause has its effect, and all effect has its cause. Everything happens in harmony with the LAW; the Law is called causality for good reason.
Regarding this principle I will surrender myself to the inspiring KYBALION, where the principal is expressed in a very clear way. The Kybalion explains that everything occurs in harmony with the LAW. It says that there is no such a thing as chance and that, while there are causes and effects on various planes, both higher and lower, nothing escapes the LAW.
The mass of people respond to the environment in which they are, to the will and desires of those others who are stronger than themselves, to suggestion, and to other external causes that move them about as pawns in the chess game of life. Those who have begun on the Path, if we apply ourselves in this learning, will eventually rise to a higher plane, rising above the dominance of our moods, character and power, as well as our surrounding environment and become the movers instead of the pawns. In this way we come to be the players in the GAME OF THE LIFE instead of being played and moved by the will of others.
The foregoing reflects the value of understanding in the journey toward a higher state.
GENDER
Everything has gender. All things have their masculine and feminine principle and gender is manifest on all planes
The word gender is derived of the Latin root meaning to engender, meaning to create, to procreate, to generate or cause to take place. We know that gender manifests in all things, the masculine and feminine principles being present not only on the physical plane but the mental and spiritual planes also.
The principal of gender always works in the direction of generation, regeneration and creation. All people and things have this dual aspect within their being. On the physical plane gender is most apparent as sex, on higher planes it takes on subtler forms but the principle is the same. No physical, mental or spiritual creation is possible without this principle.
On the mental plane we confront the objective and subjective minds. In them we can say that the masculine principle corresponds to the objective mind, active mental consciousness, and the feminine principle corresponds to the subjective mind with its passive, subconscious control of involuntary actions.
When we say "I am" it seems, at first, to be a very final statement about our consciousness but when we look deeper we discover that this I am can be separated in two parts, two different aspects. Initially "I" seems to declare a singularity of self but on a closer observation we note that within "me" exists also a "my". The "me" represents the masculine part of the mind, the "my" represents the feminine principle. The total "I" represents the total of being, that which is and that which is and that which is becoming.
The feminine principle carries on the work of generating new thoughts, concepts, ideas etc., while the masculine principle addresses the work of the will in its varied phases. However, without the active help of the will of the masculine principle the feminine principle would be doomed to generating single mental images expressing impressions received from the senses instead of producing original mental creations.
How many thoughts or original actions do average people execute? Do the majority of people not follow as groups and echo others who have wills or minds than their own? The problem is that the average person dwells completely in their self-conscious thoughts, and never realizes the greater totality of what we mean by "I".
By reflecting on these teachings we will learn that in all the creative manifestations the principal of gender is always manifest on the spiritual, mental and physical planes. This manifestation of masculine and feminine principles works in practice because it is based on the unalterable universal laws of life.
CONCLUSION
Completing this presentation I have come to the conclusion that these seven principles, seemingly independent of each other, are really insolubly united because any one of them needs the others in some measure, large or small.
"As above, so below. As below, so above". "The walker is not made for the road, the road is made by the walker".
Peace Profound!"
This is what Mr.Bowser wants to tell you with his symbols, but hard to understand for a novice.
Further insights to come.
Let the good vibes be with you.
.:kaRLfunkel:.
I have a Phd in Electrical Engineering and Phd in English. Combine the eclectics and we see how to get free energy from the English language since English is the most popular language in all of Universes and energy has shape and shape has energy.
I already have plans to build the Love Radio out of aluminum and copper 1/8"x12" tubes to increase the love 1000 to 10000 fold. This will allow me to place a solenoid near the device's hot spots and pick off AC electrical current in plenteous nature.
As the former writer says, Peace in Abundance to you all, including the Naysayers since their one failure is that they are treating me badly because they do not have enough Love. The machines will love and purify their thoughts.
Since I manned the planet I have discovered 2 things...the hard way:
1
not to make statements of definition or conclusion about things outside my area of experience
2
that some words are chunky and extremely difficult to chew and swallow
My best regards today :)
Here is one more way the Love Radio's circuit straws form such a loving effectiveness in the person it modifies. OM is spelled out by the circle in the straw and the zig zags forming an M. Thus the circuit radio forms an alpha brain wave state in the person which causes her to relax or him to relax greatly.
Another civilization has contacted me, Maxolotyl Ambystoma, related to the walking fish Axolotyl which became fully technologically developed under the influence of the Holy Spirit of God, became computerized and developed UFO technology and free energy/spacetime travel. It was they who took the Terbluthycians' Love Machine and used different metals in it to generate many watts of Love and also took triangles of successive sizes overlapping each other using alternate metals like aluminum and copper sheets to produce free energy and antigravity. I will be building their unit as soon as possible.
As you can see from the schematic, alternate layers of al and cu are used to form a battery of metal triangles all which tap L O V and shadow E. The polarity is of the electronegativity of the metals of the plates.
In addition, the Maxolotyl have told me they come from this Universe, the Constellation Centaurus Centii, or Taurus Centii.
Ah, great, you have contacted the newt from the Taurus Centii system.
Now it is only a small step to reach the Spleen from the Beta Carotene star system.
When they finally channel you their knowledge of how to crumple up aluminium foil in the shape of an origami bunny, you will definately be able to receive the oxymoronic energy they use to generate anti-gravity love AC current energy power. Woohoo! ;D
Oh, and be sure to wear your aluminium foil cap on your next flight over the cuckoo's nest eh?
ROFL....Koen1, that's got to be the best reply yet!!
OH YEEES,
Ambrosia Mexicanum.
Nice to get contact over an electronic forum.
So we can do conversation in all languages at once.
...just a moment, my babelfish wants something to eat...guchiguchiguchiguchi...
o.k. im ready again, conversations can start.
...synchronisation complete...
...frequency lock in at 0,00000000000.....minutes later.........years later.............00000000000314Hz
...ultra clear signal (no ploblem, there is no other frequency in this range because the wave is reflected at the end of the universe and back to the middle)
Ambrosia: Hi earthling, how are you?
Earthling: Fine thank you.
Ambrosia: Could somebody switch the light on, because im to small to reach the switch?
Earthling: ...and so on and on and on....
Hi Karl,
oh yes that's right.
Whats up?
Karl is talking to Karl?
Yes from left to right and back.
....braindamaged....
But thats no problem.
But here is the Key to free energy burried alive.
A coil in the middle (between left and right hemisphere) of the two overloaded brain spheres could be the transformer for that vibratory Love energy.
Yes, know we are at the inner sanctum.
A coil. Copper Venus Green Hirse Wednesday.
Thank you Mr. Bowser for your free Love energy.
You see something is comming back to you.
You have a good filter circuit and a good portion of humor.
A three is better than a coppercoil.
When I point my antenna at the constellation I get this data feed. ehm, you should pretend it's just a thought. You know? Thinking as usual? Would be interesting to know where that comes from in the first place. I doubt we deserve any credit for it. :P
Here is the SMS:
normal waves:
SSSSSSSSSSSSSSS
ZZZZZZZZZZZZZZZZZZ
IIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIII
333333333333333333
777777777777777777
longnitudial waves:
WWWWWWWWWWW
MMMMMMMMMMMMM
NNNNNNNNNNNNNNN
nnnnnnnnnnnnnnnnnnnnn
UUUUUUUUUUUUUUU
VVVVVVVVVVVVVVV
Mixed (alike) waves
AAAAAAAAAAAAAAA
888888888888888888
YYYYYYYYYYYYYYYYYY
RRRRRRRRRRRRRRR
KKKKKKKKKKKKKKK
Wave colisions:
TTTTTTTTTTTTTTTTTT
LLLLLLLLLLLLLLLLLL
HHHHHHHHHHHHHHH
XXXXXXXXXXXXXXX
FFFFFFFFFFFFFFFF
Trasisional/multidimensional waves: (edit to add *vortex*)
666666666666666666
999999999999999999
gggggggggggggggggg
GGGGGGGGGGGGGG
There are a lot of mistakes in this, pronunciations has changed a lot but it gets the general idea across.
Apparently we have always known they are vibrations? I mean why did we pick words like Sinus and Amplitude? How long ago did that happen?
Doesn't take 2 looks to see the fake letters?
http://en.wikipedia.org/wiki/Image:English-slf.png
Well I don't know what hookup you are using Gaby, but you're certainly receiving a lot clearer messages than I am. ;)
I have been considering te construction of a Rudy Rucker type fractal reality alien communication setup but haven't gotten 'round to that yet. :)
It's basically the famous pic-in-a-pic-in-a-pic effect you get when you take a handheld camera, hold it upside-down, and aim it at the tv that shows the camera's output, now darken the room and flick your lighter once to get a spark. This creates a cellular automata -like effect, looks somewhat like moving fractals.
Ok, well, using this effect, we do a double or triple setup (tv1 shows pic of camera1, filming tv2 showing pic of camera2, filming pic of tv3 showing pic of camera3, filming pic of tv1), with the lighter spark replaced by the static received by TV aerial from the Crab Nebula.
Lol. But really, mr Rucker does describe such a setup in one of his books. nutty? ;)
Perhaps a friend of mr. Bowser? :D
Dear Gaby de Wilde,
I let the NET speak for me:
http://xyzzy.freeshell.org/trinary/
"Magnetism naturally has North, South, and unmagnetised states. Materials respond differently depending on if they're diamagnetic, paramagnetic, or ferromagnetic. Diamagnetism is a phenomena all materials inherently experience, but it is very weak. Diamagnetic materials repel both North and South magnetic flux. Ferromagnetism occurs when magnetic domains align, forming a temporary magnet. The magnetization is greater than the applied magnetic field. Paramagnetic materials have magnetization proportional to the strength of the magnetic field applied to it."
A relay's coil normally is wound around a ferromagnetic material to increase its strength. The contacts themselves however are for the most part paramagnetic. This means the COM contact is attracted to the NO contact if there is any magnetic flux radiating from the coil, no matter the direction.
A ------)|| | /-----NC--- C
)|| | -------COM-- Q
GND-----)|| +---------NO-- B
Shown above is a standard relay. If A=0V=0, Q=C, while if |A|>0 then Q=B. |A|>0 means both 1 (+5V) and 2 (-5V) cause Q=B. Therefore, the truth table looks like this:
A Q
0 C
1 B
2 B
Possible functions where C != B:
011 022 100 122
The relay's inability to distinguish between positive and negative voltages, in this case, is an advantage as it allows the shift up (122) function to be implemented.
To tell negative and positive voltages apart, we can have two relays with diodes to separate the signals:
-----------------)|| NO---- D
v y-trit 2 )|| COM-----+
--- GND--)|| |
A ---+ +----- Q
v GND--)|| |
--- x-trit 1 )|| COM-----+
-----------------)|| NO---- C
Dual Diode/Dual Relay -- 2D2R Config (you know R2D2?)
A Q
0 B
1 C
2 D
With dual relays, functions in the form x1y can be implemented because an input of zero voltags results in an output of zero volts:
010 \]A
012 A
011 \/A -- used within minimum binary function
110 [/'A
112 /\A -- used within maximum binary function
210 A' -- inverter
211 ]\'A
212 /['A
I've successfully physically constructed the 2D2R configuration, created a tritwise inverter and it worked great. However, the relays required large voltages and where generally unpleasant to deal with.
2D2Q, that is Dual Diode/Dual Transistor, is a similar configuration but the relays are replaced with transistors. It has not yet been tested."
"Unfortunately,( RSFQ (Rapid Single Flux Quantum) [rochester.edu] circuitry is beyond the scope of SPICE simulations, but this appears to me to be a natural fit to the trinary logic paradigm.
Some circuits have already been physically built and tested - and at least one person feels that they lend themselves to tristate logic gates [sunysb.edu].
The basic principles are already in the category of proven technology - ever heard of a SQUID sensor?
Josephson junctions work equally well for either positive or negative currents - and so do magnetic flux quanta. (But this circuitry has to be the ultimate in low-power computing - you can't get much lower discrete amounts of energy than a single quantum of magnetic flux.) "
Some believe Enterprise's Board System eworks with this kind.
....channeld via the ipx3 information shifting quant....
Please ask me not further about details...
<removed>
This has got to be the most entertaining thread I have read anywhere.
@bowser
I was wondering if the paper was common garden variety or if it was acid free.
It seems to me the acid in the paper would provide a higher charge rate in your love receivers.
Where is the love guys?
I built the all-metal aluminum and bronze Love Transceiver, which I call a Transdimensional Equilibrator, and it will allow me to travel to different dimensions through time and space because it taps the zero vector, namely thought(6)xtuning(360)=2160(resonance),where 216 is the zero vector. On the coils of Choku Rei which the Blue Man showed me I backed with gold leaf since gold taps the zero vector.
Let's have a photo of it then please and give the Blue Man our regards.
Hans von Lieven
@ all,
i really find it amazing that the zero vector is right where marco rodin predicted. look at all the nines. 360=9, 2160=9, 216=9. and that is the zero vector. amazing!!! utterly amazing!!!!
lol
sam
Ha, well I must be truly brilliant then; I created a Transdimensional Equilibrator without evben knowing it! ;)
It works like this: I took one (1) dump, which was flushed with three (3) liters of water (25), which obviously makes for a 1/3*25 = 1/75 = 0,0133333333333.
And 1,3333333333 is of course the zero vector.
Now I did not use any gold, but there was quite a lot of ferrous and carbon compounds in the dump, which needless to say helped to tap the zero vector.
It was not until the Spleen from the Beta Carotene star system channeled me this information that I realised what I had constructed.
I did not use any coils to stimulate dump energy extraction, partly because Abra Cadabra told me not to use them, and partly because I have trouble understanding the oxymoronic speech patterns they use on Gamma Globulon 3 so I have no clue what those freaks are trying to tell me. And that's only when I don't get so distracted by their third and fourth eyes and the perpendicular redundant spine protruding from their noses. Or at least I assume they're noses...
lmao! :D ;)
If you guys like marco rodin and tesla ,you should all check out the thread "long distance love and a means to send it" .http://www.overunity.com/index.php/topic,3750.0/topicseen.html (http://www.overunity.com/index.php/topic,3750.0/topicseen.html). after a short read its a pleasant surprise. Multi vectored torus......man that sounds like its da-bomb or not.
[Click the star to watch this topic] Sun-Son Disk Generator parts ordered TODAY , Actual Flying Saucer Power Plant to be built that I actually was visitied by in the Mojave Desert and went into outer space in
The Sun-Son disk generator posits spaces for energy to be create d
within magnetic holes in the disk. Electrons are born in the holes due
the the counterclockwise clockwise circulation of magnetic vortex
energy in the magnetic material and the copper. The Copper becomes
magnetic! Amazing! It also provides antigravity.
Go see section 3 of htttp://geocities.com/brrybowser/spacecraft.htm
for the schematic.
I just purchased and gave the orders for the copper disks today, and
purchased the magnets at a surplus store. The magnets are old used
hard drive magnet assmeblies and I purchased 10/$5.00 x2 for 20 and
all I need is 12, = 6 for each disk. I also purchased the 2 motors to
drive the 2 disks.
Spacecraft I have been on
1. Jesus Christ's, which is an electrostatic Mobius Coil Ion Drive, which I gave to the Shriner's and in return they gave Osama bin Laden my plans for 9-11 and the bombing of the Navy Section of the Pentagon, since Captain Bowser was never rewarded for his creation of the Airplane, and IBM.
Not a bad opening line for a web-page Captain Bowser. So it was you that invented the Airplane and IBM. And the bastards didn't pay you. Shame on them. And your plans for 9/11 were handed to Osama bin Laden for execution because you were cheated.
What a nice fellow you are.
Hans von Lieven
Quote from: Koen1 on December 14, 2007, 06:35:13 AM
Hmmm....
Now there is an idea!
With all the iron (as you mentioned) in the material for extraction, it should be a small matter to make it all work like a solenoid - BETTTER YET! A particle accelerator. Just don't have reversed polarity ;D
Now then we would all have a very identifyable form of energy to send to each other!
i received the magnet and motors today but will have to wait until thursday for the 2 copper disks. i will then test the voltage generation part of 1/2 of the generator,that is,1 disk and plan to design a TPU for the uplift of the voltage to motor driving specifications of 12 V for the device.
Alright so basically i USE THE POWER OF THE NUMBER 2 to activate it and then do i stick my number 1 maker in it for thrust and uplift?
Well, seems that any trial of discuss the Vril or Haunebu Motor leads into diffrent political and/or religious/esoteric statements.
That's too bad because it's an interesting topic from the technical side of view.
I rode a book about the Haunebu Drive and used to research for a couple of years before I started actual writing.
To my opinion - and I think I could proof this very well - the Hanebu (or Vril) Drive didn't have anything to do with antigravity or free energy.
What I found was a clear indentifieable research and production line of Germany in WWII into progressive thrust generating drives.
Also I found a man who was never named in connection with the Haunebu or Vril drives and who is almost unkown (though he got a nobel price in physics) but who was actually the man who did the basic research for that kind of drive.
So...whatever people think what these drived have been and how they were working....I'm absolutely sure that they were working much much easier than the most people think and they were build with materials and technologies at hand....straight foreward and brand new at that time but no extraterrestrial knowledge and (of course) no "Vril"-Power.
Holger Erutan
Quote from: yaz on October 31, 2007, 09:32:36 PM
@bowser0
I stumbled upon this vid today.
Is this what your're talking about?? How do they get it to levitate?
http://www.youtube.com/watch?v=IAfnK7-4Mpc
Cool video, it is a mechanical gyro, there is a rotor piece racing round the hollow plastic toroid, it is propelled by the coils. The coils are driven in quadrature. You can hear the thing rattling as it runs, also that´s why they say "The world's first motor that doesn't have an axle" in the vid description. Very interesting device though.
Yucca.
Quote from: Erutan on November 06, 2008, 09:53:31 AM
So what kind of drive was it then? The craft are usually claimed to have flown on either Schauberger-type vortex drive,
or some electrokinetic "T.T.Brown" type drive, or some hypothetical counterrotating mercury plasma drive, or even more
exotic ideas...
Or must I buy your book to find out? ;)
QuoteSo...whatever people think what these drived have been and how they were working....I'm absolutely sure that they were working much much easier than the most people think and they were build with materials and technologies at hand....straight foreward and brand new at that time but no extraterrestrial knowledge and (of course) no "Vril"-Power.
... well I'd certainly like to know more about the drive... ;D
regards,
Koen
test
Take away all the religious talk and over-engineered solutions and you have in this thread MOST of the fundamentals of the Vril saucer. It is based on three counter-rotating magnetic fields just as explained by Norbert Juergen-Ratthofer in the late 1980s. They interact as in the Sun-Soen explanation popularized by Bruce DePalma. Experiments have been done using rotating magnetic field but only small ones conderning energy production and they were incomplete in that they failed to tell us the orientation of the magnetic fields, opposing or similar, and even if they were rotating in the same or opposite directions.
The Juergen-Rathoffer solution applies only to the Vril saucers built by the Germans during WW2. The principle behind it applies to the more sophisticated Haunebu but the machinery behind it was completely different. That relied on plasma vortex technology originated by Tesla and improved by Schappeller, the Reichsarbeitsgemeinschaft, the Vril Society, and the SS research facilities under Hans Kammler. It was not perfected until about 1952 in South America.
The priniciple itself is similar to the Beifield Brown Effect but on steriods. The mechanism applying to both the Vril and Haunebu crafts and the underlying physics can be found in a book by Dr. Paul Potter, a British Astrophysicist. It is very simple but I fear if I were to write two key words down here, all associated computers would crash. This happened to me and my computer plus four computers associated (but not connected) to me. Dr. Potter's book describes astro-physical principles of the universe and heavenly motion as they relate to possible propulsion of domed, disc craft. His first and easiest principle is the one under discussion here.
By the way, it is also the physical basis of Vril energy (prana, chi, or, etc.). And it can be generated in the human body through breathing exercises.
Quote from: hansvonlieven on November 01, 2007, 07:44:22 PM
G'day all,
Just received in my personal mail entitled "My Fathers":
Nice ancestry :-)
Hans von Lieven
His father's last name is "Solomon'? Would he be Jewish? I am Jewish. I'm also German and my father was derived from Norwegian vikings. There a little village in SE Norway called Mosby. That was my father's and my last name. I'm happy to be the way I am. This guy may not be as happy, especially if he likes Nazis. Does he? I'm referring to bowser03. And those who think like him. Oh, by the way, somehow I get the hunch getting off the ground with your own 'flying saucer'---vril, or otherwise---will be a more serious feat than anyone here realizes. Just a gut hunch I have. If aliens can do it easily, they probably have had a lot more experience and practice at it than anyone has here up 'til now. --Lee
Quote from: hansvonlieven on November 01, 2007, 04:08:31 PM
G'day bowser,
Perhaps a silly question, but how many fathers do you have??
Hans von Lieven
Yeah, that's a good question. The Jews have a specific belief about the Almighty, and what might be considered his female part as set forth by afew authorities, She being called,
Shekhinah The Orthodox Hasidimsay that Shekhinah left the presence of the Almighty when she pointed out that even though Adam and Eve had disobeyed the Almighty by eating from the Tree of Knowledge, they---Adam and Eve---should have been given a second chance to do better the second time, and the Almighty refused to change His mind. She left and went into the world to "dwell" (Shekhinah also means "dwell" in Hebrew) amongst humanity.
Jesus may actually be their only Son.
--Lee
