Overunity.com Archives
Discussion board help and admin topics => Half Baked Ideas => Topic started by: sirmikey1 on August 10, 2008, 05:25:24 PM
Title: Steven Mark's TPU "No Battery" Startup Current?
Post by: sirmikey1 on August 10, 2008, 05:25:24 PM
Hello people,
   I stumbled across a youtube video yesterday which
appears to use the same startup method as Steven Mark,
where you drop a magnet into a coil (generator).  Well, it
dawned on me that the current generated could be put through
a self-oscillating circuit in order to achieve self-running surge
overunity like so many others are doing.
SM
Title: Re: Steven Mark's TPU "No Battery" Startup Current?
Post by: sirmikey1 on August 10, 2008, 09:54:51 PM
 I am wondering if these magnets vibrate violently, self oscillate,
thus generate current? Has anyone figured out this part of the device?
Post by: sirmikey1 on August 12, 2008, 06:11:03 PM
This video he has the startup generator magnet
vibrating slowly, but Steven Mark's claims to be
6000 cycles per second.  Would 6000 keep the
magnet closer to center?  Anyone tried this?
http://www.youtube.com/watch?v=anYxNitcrm0
MIke
Post by: sirmikey1 on August 13, 2008, 06:42:54 PM
Hello people,
   I spoke with Gil about his youtube video on pulsing oscillationg coil/magnet,
asking that the add another coil as generator; and then to play with the frequencies
and see what happens with volts and amps.
Language barrier, and so I hope that everything is clear.
Here is a better video of his oscillating magnet/coil device:
http://www.youtube.com/watch?v=YMCk8zBE-4U
Mike
Post by: Magnethos on September 20, 2008, 12:25:50 PM
Well, first of all I don't know how Steven Mark's TPU works, I think it works using radiant energy from earth (Schumann Resonance) and then amplifying it. That is what I think, but you say about magnets? Here you have picture of TPU, I don't see magnets
(https://overunityarchives.com/proxy.php?request=http%3A%2F%2Fwww.randallsteward.com%2FTPU%2Fbuzz-ard%2FTPU1%2FTPU1-2.jpg&hash=281ab6a3cc4ce53a5012f6ba2b0fd4d868f597be)
The video that you have seen in youtube uses other system to create energy. Of course, you could build a better one device using more coils instead of one and make a self-running system. But I repeat, TPU extracts energy from the Earth Resonance, or maybe the coil is made with an special alloy like the Rod Generator (http://peswiki.com/index.php/Directory:Elemental_Rod_Generator), but Im almost sure the TPU system doesn't have moving parts. It's a motionless generator.
Magnets are a thing that we know only a very little part, if we want to know more about them we must to read at Howard Johnson, Edward Leedskalnin and more authors. Floyd Sweet, changed the configuration of the magnets, because with a common magnet you can't do all. If Steven Mark claims 6000 cycles per second I think he is saying about the resonance, not about a moving magnet.
Here you have a video of resonance dancing magnets
http://video.google.es/videoplay?docid=5540717206741162529&q=marcos+magnets
Post by: turbo on September 20, 2008, 01:34:19 PM
When the magnets are put into the system a reed switch is closed.
This activates the photo-flash-capacitor charging circuit and charges up the caps to high voltage from a small battery.
Then the first kicks comes from from these pre charged capacitors and feedback takes over to keep the caps charged at all times.
Marco.
Post by: pese on September 20, 2008, 01:59:35 PM
This Viedos all are not wondering me.
the firstones  are nothing es as JUNGHANS Watch Germamy used this in an horloge.
( 1 magnet , 1 moving weel , double coil. 1 germanium-transistor (delivered from me (about 500.000 pcs in one year) , al driveb from single 1,5v battery.  This shown is same (if not using addititional reed relais. (another german watch manufacturer have done this. (I have both movement in my inventory)
The dancing magnet . Give attention that any "mass" have an resonce frequency !!
So it they is 8 hz  (or 16) so it will also ance at all subharmomics of this frequencies. 4  2  even 1 hz !
But with weeker power.
So long , not wondering over this to mutch . all is simly physics
PESE
Post by: khabe on September 20, 2008, 02:18:50 PM
I have tried to ask several times before - no results.
Lets try one time more:
If SMÂÃ,´s written communications with some members published in this forum are truth - then magnets by my opinium must play some kind of not small role,
Or perhaps Im the only idiot who did read about neodymium magnets?
Nobody instead me never read about? He (SM)  told he has spent a lot of money ( $10k ?) for  ordering neodymium magnets ...
Possible of course that my feeble English caused missunderstanding. Perhaps he told he did not use neodymium magnets  ::)
When those published letters from "SM" was just fictions - then why to believe videos ... >:(
Sad of course - SM device is(was) one of scant units I like very much.
cheers,
khabe
Post by: Magnethos on September 21, 2008, 06:12:32 AM
@Marco
Of course, the first kicks could come from the precharged capacitors and then a the feedback system keep the caps charged all time. This is a good theory. I read the description of a very similar device and the system worked in a similar fashion, but it used a 9 Volt battery instead a precharged capacitors.
@Pese
Yes, as you say all has a resonance frequency. I posted the link of the video only to give ideas.
@khabe
A lot of people had tried to replicate some of these experiments without positive results. There are a lot of little factors that you have to know, if you want to succesfully replicate an invention. People see magnets, and people think that they are common neomidium magnets. But there are, as I said, a lot of little factors that if you don't know them, the replication won't be succesfully. Floyd Sweet preconditioned his magnets, and Im sure perendev do it also. We know almost nothing about magnets, there is a Secret World of Magnets that we have to know, because if we don't know in deep a thing, we only can develop the experiments of other people: uncessfully results. People that build succesfully results, use them own theories. So... the best way is experiment and discover our new science theories.
To know more about magnets:
(https://overunityarchives.com/proxy.php?request=http%3A%2F%2Fecx.images-amazon.com%2Fimages%2FI%2F51Bx75LL08L._SL160_PIsitb-dp-arrow%2CTopRight%2C21%2C-23_SH30_OU01_AA115_.jpg&hash=8d3a892b052e5bac75af83d3d57fe94a7b85fa1b)
(https://overunityarchives.com/proxy.php?request=http%3A%2F%2Fg-ecx.images-amazon.com%2Fimages%2FG%2F01%2Fciu%2Fd6%2F6b%2F3ba3024128a05d7894baf010._AA240_.L.jpg&hash=de4fb93e41e2d67a6fff0f4175a469e21090c2ba)
Post by: khabe on September 21, 2008, 07:23:34 AM
Thank you very much for reply,
I know about magnets bit more than average people do ...
My question was not about how-know,
My question was about - did SM use magnets inside TPUÂÃ,´s or not.
I did read that he spent 10 kilo dollars for Neodymium magents --- my opinion is that these money he spent not just for "starting" magnet knobs.
perhaps he ordered special shapes ... or .. who knows what.
Perhaps he ordered from Mr. George Mizzell, Birmingham, Alabama - was Mr.George in this business in those years ???
I bought from this good man(!) years ago when not much NeoÂÃ,´s was available in Europe, when cost was much more higher than today,
Myself I have spent at least 10 kilo for neodyms as well - but not for one project of course, I do spend ca $1000 per year for magnets, mostly for generators Im building,
Only part of  magnets I waste for OU experiments Im doing at nights ::)
Hereby my question:
Do I have the only person on this forum who did read about SM spent $10.000 for neodyminum magnets?
Perhaps I saw it deep asleep ??? Was illusion? Just my phantasm?
With due respect,
khabe
Post by: BEP on September 21, 2008, 08:22:03 AM
@khabe,
People see and hear what they understand or want to see and hear.
The magnets are in the text and the videos. This cannot be denied. There are many theories about the use of a magnet in the TPU. I do not agree with the theories posted so far. Since my thoughts about magnets in the TPU are just another theory they will not be posted here.
Post by: Magnethos on September 21, 2008, 08:39:25 AM
@khabe
So, if you want to know if someone has heard about SM has spent 10K $ in magnets... I haven't read that, but I don't know if anyone else has read that. But you must to know that I have read very few about SM and the TPU. I remember that I have some big documents about TPU, maybe 2 or 3 books in pdf format. I will try to find these documents and post them here.
You know that the TPU videos that are online are very low quality, but there is a DVD with a high quality where you can see the video more clear.
Here you can find the original DVD files and see the entire TPU experiment in high quality:
http://www.mediafire.com/?sharekey=bcb5de0bd0f181ea8c9e7c56ba37815f5a52c02ec6da2cd7
I'm dowloading it and I will see the entire video maybe today or in the next days, because today Im watching other DVDs about free energy.
Post by: turbo on September 21, 2008, 10:10:21 AM
The extreme audio labs were designing and producing.... SPEAKERS.
Speakers use magnets.
The tpu is made up of wire wrapped on..... speaker frames.
Steven owns patents on speakers too.
So really why is it so strange that he spend money on magnets?
Marco.
Post by: Magnethos on September 21, 2008, 10:36:55 AM
Here you have the files that I told you:
http://www.mediafire.com/?sharekey=fb859f018d1d8dd6d2db6fb9a8902bda
More than 100 pages explaining TPU
Post by: Chad on September 21, 2008, 10:40:46 AM
@khabe
i do remember reading that SM spent vast amounts on magnets, as i understand it he was maybe using these as a power source, because he says something along the lines of 'its amazing how much power a magnet holds, im sure he then says something like the magnets were then discarded because they were spent or used up.
my memory isnt 100% on the exact words but im sure it was something along those lines, i will just take a quick look to see if i can find it in the pdf's.
maybe he found a very efficient way to draw power from a magnet but ultimately rendering the magnet spent/drained, so then maybe he modified his device to run off the earths magnetic field or some other raidient energy that was pretty much limitless?.
Post by: Chad on September 21, 2008, 10:47:52 AM
@all
here is the part khabe talks about, this is taken from the pdf's that are sticky's in the tpu section.
" We have done a great deal of experimentation with permanent
magnets with some very astounding results.
I could stop now and start over again with that subject alone.
Has anyone ever read any of the reports about our experiments with what
was called, the Magnetic shadow casting material?
No it wasn't some kind of paint.
But you would be fascinated with the amount of renewable energy
you can extract from a permanent magnet!
We went through about ten thousand dollars worth of Neodymium and
Super Cobalt 404 magnetic material in our experiments.
I could write volumes of information about that stuff.
Those experiments tie in to our development of the power unit".
Chad.
Post by: khabe on September 21, 2008, 11:01:52 AM
Mh-mhh, and neo magnets  are good explanation why spoked about "selfdestroy", about "I have to touch ... is it too hot ..." , I dont believe he had high temp. ones these years ago ...
Also he did know very well from what exact places to cut pieces for video-show,
Hopefully all this SM TPU story was not bug bluff  :o
cheers,
khabe,
Thanks for Sthepen Mark Ring (TPU Device) files - why Sthepen  ???  - but anyway good readings for next nights,
now I have forced to go to make some home works, my wife is very angry >:(
Post by: turbo on September 21, 2008, 12:15:40 PM
I find it funny to see that Magnethos first posts the magnet video i have made and then he posts the document that i have made.
But as usual nobody reads what i am posting and if they do they call it a theory so i am not going to add anything anymore because there is no end to it.
Marco.
Post by: Magnethos on September 21, 2008, 12:15:43 PM
@khabe
Sorry, I meant Steven Mark. These files are from a little time ago, I had to search them in my big hard drive. I was confused between Sthepen and Steven, but now I know the correct name (Steven).
Of course, there are 2 kinds of extracting energy from a similar way SM does:
1. Extracting energy from magnets
2. Extracting energy from Earth Resonance (like T. Henry Moray)
I don't know how TPU works, 1 or 2. I have read more about Howard Johnson and Ed Leedsahlkin and other author about the Secret World of Magnets and it's very interesting. I have write some schematics and personal theories in my notebook about the stuff I have read about magnets.
I think SM spent some money of magnets because if you read carefully he post says:
So, one of the most important keys is use the correct material. We here use copper as a conductor wire, but we probarbly don't know that using a speciall alloy instead of copper, we can achieve free energy device very easy. The problem is copper as an extremely low relaxation time value. The speciall alloy, aluminum + iron, has a relaxation time value of 1ms, good to make something with that.
If we make a doped semiconductor (the special alloy) we only need a very simple circuit to get free energy device. So, I think SM spent a lot of money, not only buying magnets. He spent a lot of money buying SPECIAL MATERIAL, like Super Cobalt or something else.
Maybe he speaks about self-destroy because there are systems that can draw infinite energy at an infinite increasing power.... so... the system could start drawing 1 watt in the first second, and in a few time could be drawing gigawatts... so, if you stabilize the system to draw energy until a certain amount, the system will destroy itself because it would be drawing more and more and more energy each time.
Post by: Magnethos on September 21, 2008, 12:19:23 PM
Quote from: -[marco]- on September 21, 2008, 12:15:40 PM
Marco.
Sorry Marco, I don't knew that you made the video and the document. I posted it to show some examples, but I have never said that I made the video.
P.S: You can add more post because I read all posts from anyone. I don't know if the rest do it, but me yes.
Post by: Magnethos on September 27, 2008, 09:29:06 AM
@sirmikey1
Sorry, but as you said, the TPU has magnets inside. I have just seen the TPU DVD and I can see how the guy put 2 magnets inside the unit. Of course, it seems that there are some versions of the TPU because I can see 2 or 3 differents prototypes.
Post by: sirmikey1 on September 27, 2008, 10:15:06 AM
   Stanley Meyer explains TPU (solid state generator) very clearly in
Video #3 at this link: http://site-city.net/stan_meyer/
Use the free VLC Media Player if you have problems viewing.
   Stanley was using an oscillating coil "not" to rotate flux, but to pulse
the flux in the solid state rotor (frame).
  Do you guys think that maybe the magnets were used to align or standup
the magnet poles before pulsing, as shown in Gundersons's device, attached?
SM
Post by: innovation_station on September 28, 2008, 11:30:14 PM
i see a few problems with the last pic posted
first the magnets should be cube neos...
and second i think the control winds should go on last over the collector
aswell
we still need to figure out the spin and how to tune it .....
call me worng please...
i hope it is simpler than it looks
ist
Post by: sirmikey1 on September 29, 2008, 12:30:16 AM
ist,
  Meyers Switzerland video shows the actual magnet
gas TPU.  I tried to printscreen, but they didn't come
out.
SM
Post by: gigawattgratis on January 17, 2009, 11:16:40 PM
Dear Magnethos
You are right, I order the Al+Fe alloy at the mixture 98% of Al and 2% of Fe for get the doped semiconductor, I attach the builded alloy photo and it works as you expect, 1 millisecond of relaxation time , voltage without current draw for charge capacitors and get free electrical power
Bye
